Question about Swiss Army Wenger 73000 Pocket Watch
How do i set the alarm on my wenger73000 thanks
How do you set a timex ironman wathc and how do you use the stop watch and alarms
Hi hdirkse,
To set the digital time and date on your Timex Ironman, please follow the steps below.
1. press and hold the "set" button for two seconds.
2. Use the "advance" button to reach the correct hour.
3. Press the "mode" button, followed by the "advance" button to set the minutes on your Timex Ironman.
4. Repeat the procedure of pressing the "mode" and "advance" buttons to set the month, date, year and day of week.
5. When you are finished setting the time and date, press the "set" button to save.
Setting an Alarm
1. Begin by pressing the "mode" button until the alarm screen appears.
2. Press the "set" button and use the "advance" button to set the hour for your alarm.
3. Repeat the same procedure to set minutes and seconds for your alarm.
4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
Hope it helps.
Thank you for using FixYa.
Sep 25, 2010 | Timex Ironman 53151 Wrist Watch
My husband would like the alarm off. i don't know how i did it but i set the alarm. please help me remove the alarm setting. thank you.
* Press the MODE button until you are in ALARM mode
* Press STOP/RESET (-) or START/SPLIT (+) to cycle through alarms
* When you have selected the alarm you wish to erase, hold down STOP/RESET (-) to clear the selected alarm
Aug 19, 2010 | Timex Watches
Looking for instructions for a Seiko digital alarm chronograph solar powered back has 8n1913 the 8 could be a B. Thanks
seiko chronograph set the alarm etc pull the crown out 2 clicks.... set the alarm the same as your current time on your watch..... push the crown in 2 clicks..... than pull the crown out 1 click ..... set the alarm at the desired time with the lower button..... than push the crown in 1 click .... the alarm is ON
or go to this address http://caliber.seikowatches.com/ select the desired language than - alarm chronograph and play the alarm option on your right
May 14, 2010 | Watches
SKAGEN 521LBLB1 ALARM INSTRUCTIONS
everything you will need is right here.
http://www.skagen.com/service/watchInstructions.fx
p.s. there is another little stem on the lower right side that controls the alarm it must be pulled out.
May 08, 2009 | Skagen Alarm Watch Black Square 521LBLB1
How do i set alarm on a gap sport watch?
For setting Time & Date...
1. Push "MODE" button three times (change Mode to TimeSet)
Time -> StopWatch -> AlarmTimeSet -> TimeSet -> Time ->...
2. Flashing Second Number Digits
3. Push "RESET" to select...
Second -> Minute -> Hour(12hr<->24hr) ->...
Date -> Month -> Day of Week -> Second -> ....(repeat)
4. Use "START" to set each item...
For setting Alarm ON/OFF
1. Push "RESET" button then Push "START" same time...
Alarm ON -> Alarm OFF -> ... (repeat)
Jan 09, 2009 | Columbia All Sport Digi Watch l
How to set the alarm?
Just answered this question for someone else so I thought I would just copy and paste my response.
Now sure if you are still looking for a solution or not but just came across your problem. The lower right-hand button, the one used to turn the alarm off and on, can actually be pulled out to set the alarm. Pull out the knob, adjust the alarm time, push back in and push one more time to actually set the alarm. Hope this helps.
Dec 31, 2008 | Citizen Calibre 2100 AV0031-59A Wrist...
I just got a Freestyle Tide Watch 3.0 for Christmas. I set the alarm, and now I don't know how to turn off the alarm. It only seems to give me the option of which days I want the alarm to go off, no...
I had the same problem. Emailed Freestyle support, it's pretty simple: Go into the alarm setting, and before you do anything else, push the reset button. That'll clear it. If you push the set button first, that'll put it in the set it mode, and the reset button will just advance you to the next setting.
Dec 26, 2008 | Freestyle Shark Tide Data 4 Alarms All...
Old model timex compact disc digital audio
Hi catlady05,
Setting an Alarm
Hope it helps.
Oct 29, 2007 | Timex Ironman 53151 Wrist Watch
Watch isn't recognised by computer
Hi Hoffman518,
To set the alarm on your Timex Ironman, please follow the steps below.
Hope it helps.
Aug 08, 2007 | Timex Ironman 53151 Wrist Watch
Swiss Army Wenger 73000 Pocket Watch Logo
79 people viewed this question
Top Swiss Army Wenger Watches Experts
Ansel Alberto
Ansel Alberto
Michael Vincent Cruz
Are you a Swiss Army Wenger Watch Expert? Answer questions, earn points and help others
