Question about M-Audio MIDI Controller Keyboard
Drivers could not be installed for my keyrig 49 usb .running on windows 7 no power , code 43
4 Suggested Answers
SOURCE: Keyrig 49 not recognized by windows 7
Thats why it won't work NO driver Windows 7. The ONLY shot you got, is to install Mode, & set Compatibility Mode for XP SP2 Run as Administrator
Posted on Jan 31, 2010
  • 71 Answers
SOURCE: Will keyrig 49 software work
Yes. Below is a walkthrough on how to do it:
http://forums.m-audio.com/showthread.php?16230-How-to-KeyRig-49-in-Windows-7
Posted on Jan 31, 2011
  • 16 Answers
SOURCE: hi ther i have lost
Go to this link and download the drivers
http://www.m-audio.com/products/en_us/Oxygen49.html
Posted on Mar 13, 2011
My Lexmark e332n shows error code 43 ,what does it mean?
G'Day Mate,
Are you running the Lexmark driver for Windows 7 64 bit.
Try down loading the driver and installing it on your p.c.
Suspect USB driver for printer is missing - Windows can't detect it as it doesn't recognise it. By installing the Lexmark driver it updates windows to recognise the lexmark printer usb interface.
you will find driver here
http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_E332N&segment=SUPPORT&userlocale=EN_US&frompage=null#1
Aug 14, 2015 | Lexmark E332n Laser Printer
LG dvd external drive not recognized by computer
ERROR 43? Check your SATA connection.
HERE'S HOW I FIXED MINE.
(IE. Computer tries to install driver for BD burner, but ultimately fails, and gives the message. "Unsuccessful" and/or "Microsoft Windows stopped device. Error 43") The SATA CONNECTION on my BD burner's EXTERNAL CASE had gone bad.
TO TEST IT. I used a SATA/IDE to USB Adapter Cable I bought for about $10 on amazon.
  • I unscrewed the external case to get at the internal drive, and plugged the SATA adapter cable directly into the internal BD burner drive (bypassing the case assembly), and plugged the other end into my computer USB port.
    • PS My BD burner POWER was working OK, so I left the big white 4pin power adapter connected to the original external case.
VOILA! Both my laptop and my desktop PC recognized the LG BD burner again and assigned it a drive letter (like it used to do).
  • Now I either need to (1) Buy a NEW EXTERNAL case ($10 - $30), (2) install it as an internal drive (could get problematic if "ANYDVD" is installed) or (3) just leave it connected via the cheap adapter cable.
It's super EASY (& inexpensive) to TEST this before spending $$$$ on a new equipment.
Hope this helps someone. It had me miffed for a while there.
Jan 02, 2014 | LG GSA-2166D DVD RW Dual Layer Burner
Windows error code 43
known problem, that might be fixed by a cold start. switch off your PC or laptop completely. even pull the power lead from the wall, (in laptop remove power supply and battery once switched off) wait a few minutes and power up and start your machine.
I hope this was helpful
Oct 31, 2013 | Computers & Internet
How do I fix the msi motherboard windows 7 USB error 43?
How to Fix a Code 43 Error
  1. Restart your computer if you haven't done so already.
    There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
    Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
    Undo the change if you can, restart your PC, and then check again for the Code 43 error.
    Depending on the changes you made, some solutions might include:
  3. Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a possible solution to a Code 43 error.
    Important: If a USB device is generating the Code 43 error, uninstall every deviceunder the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
    Note: Properly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
Sep 16, 2012 | MSI INTEL G41 INTEGRATED VGA-MATX 2DDR3...
I have windows 7 and wants to install hp psc 1310 but facing code 43
you probably have the wrong driver installed. Most likely you have upgraded to a 64 bit system, and the driver is 32 bit. Find out which system you're running (right click 'computer' and click 'properties').Disconnect the printer and Uninstall the software, then go to hp website and download the proper software and install here:
May 13, 2012 | HP PSC 1315 All-In-One InkJet Printer
Device not detected
Whenever windows reports a code 43 error msg is because the device driver is corrupted or is reporting a failure, re-install the driver if error persist contact the manufacter of the device showing the error. Best regards Luis!
Feb 17, 2012 | Gigabyte GE-S800A-D1 ODIN GT 800W POWER...
Hi ther i have lost my keys for usb m-audio keyrig 49 and the software. can u help...thanks.......
Mar 12, 2011 | M-Audio Mobile USB MIDI Controller
Now I get an anoying delay: every time I press a key it doesn't inmediately play the sound. and i get a buzz sound when i press a key too. my pc is windows 7 inspiron 1545
If this is used to generate sounds using your computer, the problem is most certainly in your computer software. Common causes are antivirus and blockers that insist upon processing every bit of data including that from devices like this. The delay to do so is unacceptable as these anti things use mass amount of computer resources. Also if you have a wireless internet link active, that sucks processing time... Turn all of these computer resource "hogs" off and see if the problem goes away...
Nov 28, 2010 | M-Audio KeyRig 49 49-Note USB Keyboard
Keyrig 49 not recognized by windows 7, and it is supposed to be plug and play, no drivers found on M-Audio's site.
Jan 31, 2010 | M-Audio MIDI Controller Keyboard
M-Audio MIDI Controller Keyboard Logo
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
dhnguyen
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
