Question about Maytag 24 in. MDB6600A Jetclean II Built-in Dishwasher
WATER IN BOTTOM OF THE DISH WASHER - Maytag 24 in. MDB6600A Jetclean II Built-in Dishwasher
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 30, 2010
Will run thourgh cycles but only a little water will go in
Check fill line for a kink, (remove kick panel on bottom of dish washer)
If no kink then replace fill valve. Unplug dish washer fill valve is where water line is hooked on.
Aug 10, 2014 | Frigidaire Dishwashers
Tip
How to fix a plugged up dish washer
things you need shop vac or vacuum that could get water in it thats it first take apart the bottom inside of the dish washer vacuum out the water as best as u can put it on a quick cycle if still backing up stick vacuum in where the water can go but food cant vacuum up remain water/ food if you don't rinse off your plates your food will back up the drain so that is as easy as pie
on Jan 14, 2010 | Dishwashers
LG 2131SH Dish Washer giving error code E1
That is a leakage error, pull the access panel and check for water underneath the unit that might be cuasing it to fault out
Jan 31, 2014 | Washing Machines
Dish washer
The drain tube is stopped up, use a metal coat hanger pull unit out unhook drain stick wire in and swirl around.
May 09, 2013 | Dishwashers
My dish washer sucks
Does it fill? You should be able to hear it fill and then see water in the bottom of the tub when you open the door. If it is not filling it is one thing, if it is not spraying it is another issue. Let me know
Apr 28, 2013 | Dishwashers
Dish washer will not empty all the way out when cycle is complete
Try checking the outlet pipework, it may not be all downhill, problem with dishwashers is they tend to have standing water in the drain, you need to make sure the pipe has a good tilt, and flush your pipes regular with a cleaning agent for dishwashers.
Jun 09, 2012 | Dishwashers
How do you reset the spring on the door? the door falls down when opened.
just need to on do the unit from the two screws that hold the top of the dish washer in,,,make sure you have enough hose and power cord to pull the unit out just a little ways,,,but it is always best to unplug the dish washer,,,but the unit needs to be pulled out and the springs just need to be hook back on towards the bottom of the dish washer,,,always work safe,,unplug the dish washer. water and electrical never works together
Feb 19, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
Dish washer is retaining water in the bottom of dish washer. not draining .
Check out this tip that I wrote... it will give you some things to check and see what is happening...
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
Heatman101
Feb 25, 2010 | Frigidaire Dishwashers
The dish washer will not drain. There is water in
there is probably astuck peice of glas in the propeller. manually drain unit. take a torc screwdriver and remove screw in bottom of unit. you are removing a piece that looks like a plastic cover. now carefully spin the propeller and take out what is stuck ,put back screw then hit cancell and drain. that should do it. let me know if this was helpful
Feb 23, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Du401 doesn't drain water
there is a little pump at the bottom of the machine,called the askoll pump".this is what pumps out water before and after a cycle.the pump needs replacing.
Nov 01, 2009 | Dishwashers
Maytag 24 in. MDB6600A Jetclean II Built-in Dishwasher Logo
122 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
