Question about HP OfficeJet 6110 All-In-One InkJet Printer
Hi. My HP 6110 has been turned off. When I turn it back on it is saying "scanner failure" and advises to turn it off again. When I turn it off and on again it is saying the same thing. I have done this about 10 times without any success. Do you know how to fix this. I don't really use the scanner but this is preventing me from faxing, printing and photocoping.
  • 2 more comments
  • markjcasey Sep 30, 2010
    Hi supernova,
    Thanks for that. Do you know where I would buy the required screw driver.
    It doesn't appear to be a phillips screw driver.
    Cheers
    MC Hammer
    thanks
  • markjcasey Oct 01, 2010
    Thanks for the proposed solution. I have tryed what you suggested but it is still not working. Is there any way to disable the scanner in order to get the other functionality working. Thanks again.
    Finally got it working after using some CRC on rod.
    Thanks again.
    President:
  • 1,932 Answers
this caused due to the dirty glasses.
Follow the procedure below
1.Unplug the unit, removed the 3 screws above the glass, and the one screw on the right of the glass. 2.Pop off the silver display (the plastic part that tells which each button is.) Revealed under is the button control panel. 3.There is a locking latch on the right side of the button control panel, push it up and move the whole panel over to the left. 4. Lift that piece up and you are left with (2) tabs (one on each side) that hold the scanner onto the unit,placed a flat screw driver under them and pop it up the scanner. 5.The top of the unit should be loose, keep all the cables plugged in and carefully turned over the top of the unit. 6. use eyeglass cleaner. 7.Lubricate the rod also.
Your scanner will work fine
Thank You
Posted on Sep 30, 2010
  • Udhaya Rajan
    Udhaya Rajan Sep 30, 2010
    You can get the screw driver in your local hardware shops.Hope that wont be a problem at al.
    Thank You
  • Udhaya Rajan
    Udhaya Rajan Oct 01, 2010
    Thats good
    Thank You
How do I solve the "scanner failure power off and on again" message for an h.p. 6110 officjet all-in-one printer/scanner/fax?
Hi Paul,
Scanner Failure usually results in Hardware Failure. However there is one step you can try. Try connecting the printer directly to wall outlet or any other power outlet and the issue should be resolved.
Regards,
Sean
Apr 19, 2013 | HP OfficeJet 6110 All-In-One InkJet...
Scanner failure
The message 'Scanner failure' displays on the control panel of the product. This error can occur when the product is warming up after you turn it on. Please visit the below mentioned link.
If still face the problem then need to contact the hardware vendor.
Aug 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Scanner Failure message on my HP 6110
have you tried plugging into a wall socket, sometimes using power supply or powerstrip or surge procter will not let enough elect through to the unit.
Jul 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110 all-in-one
maybe you could try to reinstall the driver?
Oct 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanner failure hp 6110 - Noise and stuck head
the error message refers to the hardware issue of the printer. Below is the document that i need you to follow to somehow resolve your issue.
CLICK HERE==>> DOCUMENT
Please let me know if the document that i gave to you resolves your issue.
thank you so much.
adonscott
Jul 19, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
647 people viewed this question
Seeker5211
Seeker5211
