Question about Estate TEDX640JQ Electric Dryer
Heating element heats up for about 20 sec. and cools down over and over.
  • Estate Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 30, 2010
Is it normal that a whirlpool oven current varies between 9.7 and 20 amps
The heating elements on any stove vary in resistance as they heat up and cool down. When cold, the elements offer more resistance thus less current flows. As the coil gets hotter, the resistance drops and greater current flow develops. The thermostat cycles the elements on and off to maintain the temperature measured in the oven, thus the cycling of power used.
Jan 10, 2013 | Ovens
Kitchen aid dryer / heat flame not staying on after 20 secs
Sounds like your gas valve is fine, if it comes on at all, its good. A air flow restriction would cause a overheat condition and shut down the burner. Once it cools back down the burner would re-ignite and repeat the cycle. The sensor on the left of the burner is the flame sensor and the flame wouldn't come on at all if it was bad. You've already changed the coil kit so the valve is fine, disconnect the vent from the back of the dryer and see if the problem goes away. If the problem stays, I would suspect the thermostat. Good luck.
Mar 16, 2010 | KitchenAid Dryers
I have model a105 s4064 laptop. when i power up the computer the light comes on but nothing turns on.
dissarm all the laptop turn around the main board put around the video chip masking tape and then proceed to heat the chip with professional heat pistol be carefull dont fried the chip just for 20 or 15 sec, let cool down a litle. take out the masking take reassamble the pc and turn on if does not work repeat the proceadure and go on more time heating the chip
Oct 07, 2009 | Toshiba Computers & Internet
After 20 minutes my whirlpool LGR3624EQ0 dryer
Your motor is bad on this unit or your saftey t-stat is stopping so it won't over heat. Look at the t-stat first. Hope this helps!
Aug 18, 2009 | Dryers
I have a brand new makita hg5002k heat gun,i use it to dry the ink on the t-shirts that i print,after 1 hour of continous usage,i shut it off to switch designs in my printing machine,no more than 5 minutes...
do you make sure to cool it down after use before switching off.
if switched off imediately after using on hot, the heat from the elements will keep increasing , causing short life of heating element and maybe the gun has a thermal trip that needs to cool down before it will switch back on. This sounds like what is happening with your machine.
shutdown instructions are in the users manual.
hope this helps
Jun 26, 2009 | Makita HG1100 Electric Heat Guns
0ne of the surface units does not heat. Frigidaire Electric Range
HI, You will need to change the burner switch. When the element shorted, it took out the switch also. If you need help with part#, please let me know
Thanks
Vic
May 17, 2009 | Kitchen Ranges
Dryer heating element(s) are inconsistent
there is only 1 element. were you taking these readings with the wires on them?
the other 2 were thermostats.was there lots of lint?
sounds like you may have bad thermostat.
Nov 23, 2008 | Whirlpool GEQ9800P Electric Dryer
Maytag MDG16CSBWW heating problem
I have a Miele Novotronic T560C. The tumble drier is working fine except the air circulating is cold - it does not heat up at all. What could the possible reason for this and/or solution?
Oct 05, 2008 | Maytag MDG16CS Gas Commercial Dryer
Continually running/heating
Coffeemakers have two heating elements: a brew element and a keep-warm element. When the water reservoir has run empty, a thermostat switches power from the brew element to the keep-warm element.
The keep-warm element will cause the thermostat to stay in this condition until more water is added [or power is cut off] which will cool it down to switch back.
However, if the keep-warm element has quit working, the thermostat may be reactivating the brew element. With no water in the reservoir, the brew element will heat up till the thermostat trips again, then cool down, etc. This cycle will repeat until power is switched off.
Mar 31, 2008 | Keurig B50 Coffee Maker
Estate TEDX640JQ Electric Dryer Logo
46 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
