Question about Fantom Drives 120 GB Hard Drive
When i turn on my fantom green drive the green light keeps flashing
If the light turns on (mine was blue) but the drive is not recognized on your computer desktop that most likely means the drive does not have enough power. This happened to me too, and I took it to a computer expert and he said the drive was not even spinning. So it was either the external power source that broke or the internal power source, the power panel that broke. I took it to a batter plus and tested the wattage for the external power source and it was okay so then i took the entire drive apart and disconnected the naked hard drive from the power panel. Then I purchased "SATA to USB" cables (runs around 10-20 bucks) and connected the naked hard drive that way to the computer and it worked. So the problem is basically that the internal power panel is not working, and i had 2 fantom drives that both had this problem and they both worked after i did what i just said.. so I think your drive has the same problem since the light comes on but the drive is not spinning. Take it apart, buy some SATA to USB cables and it should work.
Posted on Sep 30, 2010
I had a 2 Gbyte fantom drive beeping and blinking and the computer did not see it. This happened after several months of operation. I took the unit apart and connected the naked drive to a different enclosure. It worked fine. So, it was the fantom drive enclosure that was the problem. I did not troubleshoot further to determine if it was the power cord with converter or the small electronics printed board.
Posted on Dec 24, 2012
2 Suggested Answers
sayedmohu
  • 645 Answers
SOURCE: my fantom drive greendrive green
Its an issue with connectivity.
Check the USB connection.
Posted on Sep 29, 2010
I have a flashing light on my Fantom hard drive light. Did it crash?
The disk-drive has malfunctioned.
Search online for a professional "data recovery service".
For a significant fee, they can repair your disk-drive,
just long-enough to copy your files to a new disk-drive.
If it still has a valid WARRANTY, exercise the warranty to get it repaired/replaced.
If the warranty has expired, then open the case, remove the disk-drive, buy a new "compatible" disk-drive, connect it, and thus "revive" your external storage device.
Oct 23, 2010 | Fantom Drives 120 GB Hard Drive
Ext 500G Fantom HD turns on but won't boot up.
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the flash drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your flash drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your Hard Drive to be detected automatically.
Kindly keep me posted about the problem
Hope this helps you out.
Nov 19, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
Fantom titanium external light turns red on connecting
Red is a failure warning but if it only hasppens with the usb plugged in it's mostly likey a failure in the IDE/SATA to USB conversion board.
Take the drive to your local PC shop, ask the techs there to pull the hard drive out of your phantom and test it in a new enclosure. If it works there, buy the enclosure, if it doesn't reply back and let me kow your Country, State and City and I can recommend a pro to look at the actual harddrive if you need files recovered from it.
Hope this helps FixYa
Sep 03, 2009 | Fantom Titanium Hard Drive
MY fantom drive TFDU20072 200 gb has worked for years, but today when I turned it on it doesn't show up on the hard drive of my mac. the light is constantly red with a blue flash every second or so. it...
Try the basics first. Unplug and let sit for a while before rebooting the drive. Then if nothing, get a copy of Disk Warrior and you may be able to regain access to the drive in order to save your data.
Aug 15, 2009 | Fantom Titanium Hard Drive
How do you install a fantom drive(titanium 2 firewire usb2.0.)or how do i psave programs to it.
You don't mention what kind of OS you're using - but either Windows, or OS X should see your drive regardless.
Before use:
Windows: Format the drive with NTFS.
Mac: Finder should pop up and ask you if you want to initalize the drive, you can choose 'yes' and continue.
Dec 02, 2008 | Computers & Internet
Lights are flashing
Here is a fix.
Open the drive case up. Inside is a SATA hard drive. If you reseat the drive it may correct the problem. If not you can put it into a computer and see if you access the drive.
We used a Linux boot CD in case their was a problem with the data. We used KNOPIX. THe data was intact and we did a backup befroe we put the drive back together.
They also offer a restore service if you get an RMA.
Feb 13, 2008 | Fantom Titanium Hard Drive
Yellow light?
Tre, save early, save often, save many. I have seen, heard and experienced external hard drives failing. It is a good habit to use the "usb device safe removal tool" the green arrow on the task bar. When the device is safely removed, turn it off. When you need the drive again...turn it on save files, safely remove device, turn it off. Sometimes the turning on and off of the computer with the drive hooked up can cause issues over time. Anyway hope that helps. Good Luck. Tim
Mar 14, 2007 | Fantom Titanium Hard Drive
Fantom Drives 120 GB Hard Drive Logo
1,966 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
