Question about Whirlpool Washing Machines
Sir, My whirlpool washing machines front panel does not work properly.What I have to do correct this problem? Please advise as early as possible. suresh.r
  • Whirlpool Master
  • 17,130 Answers
There is only one option but to change the board as these boards are difficult except if you have a possible power fault , as the board is filled with epoxy , so difficult to service..
Posted on Sep 30, 2010
How do i know if machine is condensing moisture properly?
Washing machines are not designed to condense moisture, they are designed to clean fabric. It is always advisable to use the correct appliance for the correct purpose. Please take it from personal experience that you cannot cook a turkey with a blender ;)
May 26, 2014 | Malber WD1000 Front Load Washer/Dryer
My Whirlpool Duet washing machine's front panel lights quit working and now it will not run
Make sure you still have proper voltage at the plug. try plugging something else in. If voltage is good you most likely have a bad electronic control, or user interface board.
Mar 23, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
Hi Sir, This is dominic from visakhapatnam. The problem with my whirlpool machine is when I am touching the body of the washing machine while washing the clothes, I am getting current shock. Can you...
Your house elctric current is not grounded correctly.
You can attach a solid copper wire from the washing machine to a cold water inlet pipe to ground the machine.
Have an electrician check your power grounds at the circuit panel.
Sep 14, 2010 | Whirlpool Washing Machines
Gorenje washing machine wa 72145 washing clothes but doesnt spin keeps comimg up child lock
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 13, 2010 | LG WM2301H Washer
Sounds like rocks in my front loading washing machine
did you try removingthe lower acess panel and checkin g the drain pump for possible obstruction??
Mar 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool LHW0050PQ4 compact front loading washing machine does not agitate or spin. When you put it on wash, it fills then a short time later drains and then shows the cycle complete but has not done...
probably motor control bd but on some early models when both control bds (1 under top and 1 under bottom panel)came together in a kit worked great since sometimes hard to determine exactly which control bd was actually causing the problem if you are sure wash motor is not running and belt is not off
Jul 04, 2008 | Whirlpool Washing Machines
Whirlpool door lock
hi
We have a whirlpool AWO?D4705 washing machine. The red light is flashing to say clean pump.wee cannot find our manual , can you help please?
Jan 20, 2008 | Candy CNW136 Front Load Washer/Dryer
Whirlpool ADP951 Dishwasher
Processor board sound bad. May be a loose plug ( or corroded connection on the plug ) . Unplug the dish washer from the wall plug before servicing. The open the front panel to expose the panel control board. Unplug the panel plugs and inspect them to assure no corrotion is apparent. If you see corrotion, use a pencil erracer to clean all contact points on the board and clean the plug the best possible. Plug the dishwasher plug back in the wall and check the unit for proper operation. If the operation is not correct, replace the circuit board. I hope this helps
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Dishwashers
Washing Machines Logo
27 people viewed this question
Dan Webster
Dan Webster
Sal De
