Question about Samsung LN32A330 32 in. LCD TV
NOT GETTING ANY POWER WHEN TURN ON/no red light when hook to power outlet? checked power source okay. just bought this led tv about 3-4 months ago.
  • Samsung Master
  • 17,130 Answers
Possible that the mP section is not working , As confirmed the power supply SMPS unit is working but the secondary voltages must be checked to see if the regulator for the processor gets the supply. If not check and replace, if supply is through then the mP must be checked.
Need to check is warranty cover is availabel to you , if so call without tampering.
Posted on Sep 30, 2010
Philips Magnavox Plasma TV went off.
The red LED merely indicates that power is getting to your TV. There may have been a power supply failure, especially since your TV is a 2008 model
Jun 28, 2013 | Philips Magnavox 42MF521D/37 Television
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
Jun 30, 2011 | Panasonic PT-52LCX66 Projection Television
My kds-r60xbr1 sony wega projection tv is blinking green then red and wont go on how do i fix this problem .i also just replaced the bulb about 3 months ago.
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
TV will not turn on, no red light
First make sure that it is plugged and properly connected to the power source. If it's properly plugged in and you still don't get the red light, check the power outlet by looking at your circuit breaker. Make sure that the breaker supplying the outlet for your television is turned on. If not, reset the breaker by turning it off and then turn it on again. Bottom line is, if you do not have a red standby light, it is most likely that you are not getting any electric supply to your tv.
Fix14
Jun 16, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Protron lcd tv getting no power
Replace the power supply inside the tv. I have found ther here. They are the cheepest place that has them.$60 not $100 at shop jimmy.
http://www.power-on.com/lcd194-3f.html
May 26, 2009 | Protron PLTV-32 Television
Won't turn on
I bought two tvs and after about 3 months one of my tvs would not turn on; this tv was used more than the other one that is still working. I noticed that the power cord has a box that connects the two parts of the cords together, well the box gets very hot. I thought that the problem could be the power cord (may be it burned out) and not the tv. I switched power cords from the working tv to the nonworking tv and that sovled the problem.
Dec 17, 2007 | Proscan 19LA25Q 19 in. LCD Television
Samsung LN32A330 32 in. LCD TV Logo
51 people viewed this question
Jerry Greenberg
Jerry Greenberg
