Question about Philips 32FD9954 32 in. HD-Ready Plasma Television
When i connect my my hd cables on my philips 32fd9954 tv the sound will not work
    Problem Solver:
  • 9 Answers
It is likely you are connecting via the DVI or VGA connectors. By default, these do not carry audio. You will need to bring audio into the display through one of the other sets of connections, then manually select the input with the remote.
Posted on Nov 17, 2010
How do u connect up surround sound to my samsung tv
Connect the surround sound to cable box or use a optical wire
Jul 27, 2012 | Samsung LN-R3228W 32 in. HD-Ready LCD...
Can't find where to hook up tv coax.
As far as I can tell your TV is just a monitor. You would have to buy a separate tuner. I had the same problem with mine and found it was cheaper just to use an old VCR. I hooked up the coax wire up to the VCR and hooked the VCR to my TV with composite cables and changed my channel through the VCR. That will only work now if you're using cable because of the switch to digital. If you're using an antenna you will need a digital tuner.
Aug 08, 2010 | Philips 32FD9954 32 in. HD-Ready Plasma...
I have a phillps model 32fd9954 flat screen tv . The tv will say on for about 30min then it shuts off and the light gos from green to red and the tv will not stay on at all unless you wait another 30min
your tv has a defect.maybe loose connection on the board.or theres a shorted parts im the main board. you need a qualified technician to fix that problem.
Jul 11, 2010 | Philips Televison & Video
How do i connect a xbox 360 to a philips hts 3555 and hd tv?
Connect audio out cables (L and R) from HDTV to far left audio input at back of hts 3555. Then connect HDMI output from XBOX360 to HDMI input slot on TV. Setup XBOX 360 for audio through HDMI turn TV off and then on and all should be good. It worked for me.
May 25, 2010 | Philips HTS-3555 System
HDMI Connection
Yes it does, HDMI can handle more information and provide better picture and sound. Works like this, Cable-OK, Component-Even Better, HDMI and DVI-both Digital and the best sound and video. The only way to get full HD is with HDMI or DVI. Hope this helps
Jan 17, 2009 | Philips 52 In. LCD HDTV
Connecting a Playstation 2 console to a Phillips flat screen tv
They may have those inputs disabled on the tv. call the front desk and ask for the house electrician.
Jun 09, 2008 | Philips 32FD9954 32 in. HD-Ready Plasma...
How to find part and repair 32" philips tv light bulb
I see that your TV was manufactured in Feb. 2004 Probably the only place u will find parts maybe a damaged TV on ebay. Or check with a repair shop and see if they have any old plasma tvs laying around. I work in a remanufacturing facility and I see these tv's everygreat once in a while. I believe it has a mitubishi panel or hatachi panel in it one of the most common problems is the power supply. If I remember correctly on the power supply you should see several resistors (at the top left of board) burnt up along with a couple for FET's burnt also (the fet's are all in a row on the left side of the powersupply. You might try and changing these out if this is the problem. But if there is a problem with the Plasma panel I highly doubt u will find a replacement to match.
May 02, 2008 | Philips 32FD9954 32 in. HD-Ready Plasma...
Needs to download new software
Hey there bethymofo, the problem is with your cable box. Your TV is fine. You should contact your cable provider but most likely result is to bring in for a new replacement. Good Luck!
Mar 25, 2008 | Philips 32FD9954 32 in. HD-Ready Plasma...
How to associate the av sound with the HD video out
DVI connections do not carry sound. The only feasible way to get sound from the PS3 is through a standard twin phono-phono lead (red & white RCA)
Oct 20, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
Tv
I don't know if this will help you or not, but we had that problem, and it was a loose connection. After all cables were plugged in tight, on both the receiver and TV we had color again.
Aug 25, 2007 | Philips 32FD9954 32 in. HD-Ready Plasma...
Philips 32FD9954 32 in. HD-Ready Plasma Television Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
