Question about Estate TEDX640JQ Electric Dryer
HAVE TO RESTART DRYER TO FULLY DRY CLOTHES--AT LEAST 2 OR 3 TIMES. WHAT WOULD CAUSE THIS AND WHAT IS THE SOLUTION
  • Estate Master
  • 43,501 Answers
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on Sep 30, 2010
I have to turn my dryer on 2 or 3 times to dry one load of clothes
Your vent ducting or exhaust hose is clogged.
Oct 20, 2015 | Dryers
Dryer shuts off before cloths are dry,then then you have to wait about 10 mim before you can restrat dryer..cleaned vent duck to out side2 times to besure it was clean..cleaned venting back of...
Check motor for lint build up around motor. Will cause motor to overheat and shutdown on motor
overheat switch and will restart after cooling down.
Feb 11, 2011 | Dryers
I have to run the dryer 3 times before clothes is dry
HAVE TO RUN DRYER 2 OR 3 TIMES BEFORE CLOTHES ARE DRY
Feb 13, 2010 | Estate TEDX640JQ Electric Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
My hotpoint tumble dryer is taking an extremely long time to dry my clothes I have no man in the house and with 3 teenagers to wash and dry for this situation is extremely frustrating!
Look behind the dryer for a kinked or crushed vent. This is the main cause for long dry times. If the dryer is on an outside wall in the house, go outside to check the vent hood for blockage. Check inside the vent hood for a wasp or bee nest before reaching inside to remove the lint that may be keeping the flapper from opening fully.
If this does not solve the problem, refer to a qualified service technician to diagnose for internal problems.
Apr 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
We have a Kenmore Elite gas clothes dryer (110.73952101). It will not completely dry large loads. We have to reset timer and restart the dryer. If we set timer for 40 minutes, dryer may run for 10 minutes...
Loads may be too large. Also when you reset and restart, the heat overload is cutting out. If your discarge is kinked or not venting properly this will cause it not to dry as well. Also check your lint screen. Good Luck!
Apr 13, 2009 | Dryers
No heat
ok so you have some heat.your dryer unless an ge one has one element so if you have heat its working.then what you have is an exust problem.once you heat up the clothes and cause the moisture to evaporate then it must be able to leave the dryer or it reclings to the clothes,hence lond dry times.to test this dry a load with the venting undone and the dryer pulled out.dont worry it wont start a fire/never!its about 180 degress to 130 of moist air. if ok then confirms that venting is blocked.some times dryers get blocked internaly also but do the other first.God bless,tom
Jan 01, 2009 | Whirlpool LER4634J Electric Dryer
Dryer takes a long time to dry.
This sounds like the vent is plugged up. The dryer gets rid of moisture through the dryer vent and hose. When this gets plugged up it will take a long time to dry or the hi limit will shut it off. When the dryer vent or hose is partialy blocked it will take vary tong times to dry the clothes and will eventualy cause the dryer to stop drying all together.
Nov 14, 2008 | Dryers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Estate TEDX640JQ Electric Dryer Logo
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
