Machine gets to the spin cycle and stops. Clothes are soaking in water because it won't drain.
  • Washing Mach... Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 30, 2010
  • 176 Answers
Check the lid switch
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
I have a Whirlpool LHA 5700 old school washer. It works great. It wash clothes with no problems. It just stop spinning the water out tub and clothes. The water drains as far as it can but that's it. W
Don't know the model but with the old basics with electric motor drive as a 1st step always check for broken wires to the motor as they flop around a fair bit and eventually break them or corrode them from water and washing detergents.
Apr 19, 2014 | Whirlpool Washing Machines
I have a Maytag Bravos top loader washer and it seems to agitate during the washing phase but when it comes to the spin cycle the water drains but the clothes are still soaked at the end of the cycle, as...
This happens to me to. It is because it believes it has gone out of balance and has stopped and gone ahead and timed out making you think it has completed it's cycle. I do not have a solution to this other that I am thinking of chucking this washing machine out the door and buying an older machine.
Nov 20, 2012 | Washing Machines
Kenmore washer 80 series does not drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump: Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Washing Machines
Washer is completing all cycles, but water from wash cycle.is left.in washer and clothes are still soaking wet. No water drains out.
check the Lid safety switch, if its shorted the spin cycle won't work, so your left with wet clothes ,, you can jumper the 2 wires together to test the switch , if that makes the cycle work, Replace that switch
Jul 06, 2011 | Washing Machines
Clothes are sill soaking wet after sin cycle
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Aug 18, 2009 | Maytag EPIC MFW9700S Front Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Not draining
it will be the pump they have a small fan inside them they get weak and with the pressure of the water they stop spinning which doesnt push your the water through the motor fast enough to drain properly replace and you will see the difference
Aug 22, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
