Question about Philips Universal PH301S Remote Control
I need The code table chart for philips universal remote
5 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: universal remote codes for a philips remote
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 07, 2008
VOTIT
  • 2071 Answers
SOURCE: philips universal remote codes for zenith t.v.
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
Line up your original remote and the head-to-head before completing thefollowing steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
  • 5 Answers
SOURCE: need code to program philips universal remote
most philips universal remotes have the "code search" option this is done by:
1: Manually turn on ur tv
2:hold setup untill red indicator stays on and release button
3: press and quickly release what you wanna program (i.e tv,vcr,ect.)
4:press channel up repeatedly untill your t.v changes channels(up to 300 times) if you over shoot the channel change press down til it changes again.
5: press and release MUTE to install the code.
Posted on Jul 17, 2009
SOURCE: i have a philips universal remote code-cl043 and
I just move and lost my code sheet for my phillips universal control is there some where i can get some codes,i have a emmerson television thanks.
Posted on Oct 02, 2010
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
Dec 28, 2015 | Philips Televison & Video
Need codes for phillips tv
Hello
Three digit universal remote code for Philips TV are:
003/ 004/ 006/ 008/ 062/ 068/ 069/ 074/ 075/ 076/ 086/ 087/ 089/ 133/ 163/ 183/ 184/ 205/ 206/ 207/ 208/ 212/ 213
Three digit universal remote codes for Philips Magnavox are:
183/ 184/ 208/ 213
Four digit universal remote codes for Philips TV are:
0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
Four digit universal remote codes for Philips Magnavox are:
0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jun 10, 2011 | Televison & Video
I can't find the code I need to program my universal remote to my television.
Hello
Three digit universal remote code for philips are:-
Four digit universal remote codes for philips are:-
Four digit universal remote code for Philips Magnavox are:-
Proceedings:
NB: Switch OFF and ON your TV with its FRONT PANEL POWER ON/OFF SWITCH each time before trying an other code.
Direct Code Entry
OK.
Jan 14, 2011 | Philips 42PFL3603D/27 42 in. LCD TV
Hello im looking for the code for my philips universal remote i need the code for comcast cable box
hi bddbratpak,
Universal remote controls are a dime a dozen these days. The only problem with these thingsis that you need to know the codes of the remotes you want to emulate,and those codes are usually in the manual. But I understand there are times we tend to losemanuals like pens so I would rather suggest to put the codes online where you could find them right away.
Also, try to check your signal provider's website since they would have an updated code chart to see if there a code that would perfectly match your brand.
For your convenience, you may log on to http://www.urc.philips.com/ for more details and remote control technical assistance.
best regards,
Jazerblue
Aug 25, 2009 | Philips Televison & Video
Need Codes for a Philips universal remote
You did not specify model but you can try this. Repost if you have a specific model #.
Direct Philips Magnavox Universal Remote Code Entry PM335
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
3. Enter the 3 digit code from the code tables. Note:
4. With your device on, press CHANNEL Up. If the
equipment, try one of the other codes for your
brand.
SONY .................. 202 708 801
Dec 29, 2007 | Philips PH-DVD5 Remote Control
I have a philips unavisal remote
I am not sure if you have followed the code table. There are 4 codes for SONY TV. You can use the Philips own code table for your convenience I am adding the link below
http://www.geocities.com/aviorix/pm435.pdf
Good Luck
Dec 28, 2007 | Philips Magnavox Learning Universal Remote
Lost manual in move...
Here is the Link for the code table
Hope it will help
Good Luck
Dec 26, 2007 | Philips Magnavox Learning Universal Remote
Philips universal remote code for direct tv.
I have a code table for you, you may try this if its different than yours. Here is the direct link (You need Adobe Reader to open it)
Good Luck
Dec 25, 2007 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
310 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
