Question about Frigidaire FGR341AC Electric Dryer
Dryer will not come on at all now. Not even the light on the inside like it's not getting electricity. At first it would go off and after about 5-10 minutes I could turn it back on the it would go off again. I also could not put very much in there at all or it would not even turn. Then sometime it would go off and I could flip my breaker and it would come back on for a bit then go back off. Now it will not come on at all and it's not even 2 years old
  • 347 Answers
Jan, It sounds like you have a few separate issues going on. I would call a qualified repairman.
Posted on Jun 14, 2017
  • 247 Answers
SOURCE: kenmore electric dryer throwing breaker
Might not be a dryer problem. Following assumes that the breaker that's going is an overcurrent device (something in place of a fuse - what we in the UK usually call an "MCB") rather than an earth leakage circuit breaker. MCBs often have two trip devices - an electromagnetic trip which protects against major faults, and a thermal backup which protects against chronic overload. It could be that you're cooking the thermal element. How much current is the dryer meant to take? (Calculate by dividing power consumption in watts by supply voltage). Is there anything else coming off the same circuit breaker at the same time? Calculate the current drawn by the other loads, and add them all up. If the total current is more than the rated current of the breaker, not only have you found the likely source of your problem but also you've identified that you are overloading your wiring (finding this out is a good thing, as it gives you the opportunity to stop before you set the place on fire). If the total current is below, but near the rated current of the breaker, then you may have a problem with the breaker itself. Possibilities include inadequate ventilation around it or location in a cabinet which is picking up external heat (both need sorting out urgently) - or it may be that the breaker is old and tired and has gone out of calibration. Investigating any of these needs more skill than it's wise to try to acquire from a stranger on the web. A.
Posted on May 24, 2007
  • 10 Answers
SOURCE: Maytag Dryer quit running
If your not a handyperson, this could be expensive...
a)  you didn't tell us if this is a newer electronically controlled dryer, or just the old reliable type...  newer types, in my opinion, will generally have more controls fail than the older types, but sometimes something on the older types fail also...  to replace the newer stuff will cost lots -- cheaper to buy an ol' reliable...
b)  besides checking the lint trap, you should periodically inspect the outside vent to make sure the airflow is good...  also, it's always a good thing to take apart the dyer every now and then and clean it out if the dryer has run a lot... in most cases, the dryer would be replaced before it really needs to be cleaned out (I kept mine for many, many years)
c)  in the dryer heater duct, there are a number of safety switches -- if for any reason, the dyer air should over heat, it shuts down the dryer -- some are resettable, some are the replaceable type, but both types will be used; unfortunately, even if a resettable switch operates, the replaceable will almost always operate...
d)  since it appears nothing works, I suspect the heating element is still probably good, but...
e) if the breaker was not tripped, then the motor is probably OK...
f)  I'm not sure, it's been awhile since I've had my dryer torn apart, but I think it will also shutdown if the drum drive belt breaks...
My suggestion is to call a trustworthy repairman, determine the potential costs up front and then decide whether to replace or repair... or call a trusted friend to fix it if they have the knowhow...
Posted on Jul 27, 2008
  • 57 Answers
SOURCE: My new maytag centennial electric keeps tripping
Hi Matt
I'm not sure that swapping out the breakers to higher rated ones will give you a solution so I'll throw in 2 cents to see if my advice holds true. Let's start by asking this. Is the appliance "rated" at 220 volts at 30 amps per leg. I assume this from your post as to what it has been rated. Next - How long is the "run" of wire from the junction box to the outlet where the appliance plugs in? This usually does not matter in most households but if the run is of significant length it may need a larger gage wire to support the current draw of the appliance. Lastly, and perhaps most importantly, are the lugs and wire connectors tight at the outlet, the plug, and the breaker box. A loose connection will ramp up the current fast. This is assuming the first two items were met. Tell me if any of this helps and we'll work it out from there.
Posted on Feb 28, 2009
SOURCE: Does anyone know where the reset button is on an
Make sure your breaker is "RESET". turn it all the way OFF, then back to ON.
Posted on Mar 17, 2009
  • 331 Answers
SOURCE: Dryer trips breaker after 5 minutes...BRAND NEW!!
Hi Shel,
Based on your description of the problem, I came up with a theory. Your new dryer is of higher wattage than your old one and is therefore pulling more amperage. I'd also make a bet that your dual breaker in the basement has the number "30" printed on it. Whether it does or not, your breaker should be replaced.
NOTE---> Ideally, you'd begin by removing the breakers (there are 2 of them) from the panel and take them with you to Lowe's, Home Depot or Ace Hardware and ask one of the sales associates for a 40 amp version. This way, you'd be sure to get the right ones. If you don't want to do that, then open up the breaker box and copy all the information off of the dryer breaker (also take not of how wide it is... 1/2", 3/4", etc...). Basically you'll need who made it (Square D, G.E., etc...) and how wide it is. Use this info to shop for a 40 amp version.
I don't need to tell you that working inside a breaker box can be EXTREMELY DANGEROUS if you are not careful. Here is a picture of the inside of the box, NOTICE THE LUGS AT THE TOP! THEY ARE ALWAYS "HOT" AND SHOULD NEVER BE TOUCHED!!!!!
Before you remove the panel to access the interior of the box, TURN OFF YOUR "MAIN BREAKER" (it's shown in the picture above).
Now that all of the safety stuff is covered, all you gotta do is pull the bad breaker out and install the new one! Piece of cake, really. Here's a video on how it's done.There ya go! If this has been helpful for you, please remember to rate this solution. Thanks for using FixYa!
Posted on Apr 03, 2009
Fridigdere up rite stackable dryer keeps beeping and shuts off after running for about 5,10 seconds,what do I check,?????
Google the model and codes. You should find instructions in how to to retrieve the codes and that will point you in the right direction.
Oct 14, 2016 | Dryers
Dryer (electric) cord and outlet get extremely hot when dryer is on. I even think it is melting the prongs to the cord.
for some reason the dryer is drawing too much amperage. maybe the cord connection inside the dryer is loose or falling off? i assume this is an electric dryer?
Apr 05, 2014 | Dryers
GE (Rheem) SmartShield Water Heater. it rained on the hot water heater and now the pilot won't light. Any ideas?
Does it have an electric ignition? If so, remove the pilot light access panel, blow inside the chamber with a hair dryer. Do this until there is no more moisture inside. Then follow the lighting instructions. Try this even if it's a match start. Thanks and please rate.
Sep 05, 2011 | General Electric Water Heaters
LG DLG0452W: Light inside the drum stays on even after closing the door tightly and dryer does not start. It flashes to check the lint tray but there isn't anything in there. HELP!!
If that light stays on I would say something definitely is wrong with the door safety lock mechanism. I have an LG dryer service manual that may help you: LG GAS& ELECTRIC DRYER repair manual
Jan 10, 2011 | LG DLG0452W Gas Dryer
The dryer runs but no heat is there a pilot light inside the back of the dryer
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Oct 17, 2010 | Roper Dryers
Won't start or heat up
Check your breaker box for fuse box. sounds like you are only getting 1 leg of the 220VAC to the machine.
Sep 19, 2009 | Maytag SDE3606A Electric Dryer
Dryer won't turn on
Check for a blown thermal fuse. It is about one inch long and is located just inside the rear of the dryer and is usually mounted on the exhaust duct. It can be tested for continuity using a multimeter. A lack of continuity indicates a blown fuse. Hope this helped and best wishes.
Aug 05, 2009 | General Electric DHDSR46EGWW Dryer
Whirlpool Electric: Light is on, but no turn or no heat
Hi, Good troubleshooting! If the light stays on and nothing works it indicates the door switch is the problem. Best of Luck to you! Please rate my response.
Feb 09, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore 110.96588210 Electric Dryer
you can take the top panel back off and check the start button with omes meter,push button in you should get a reading,let button out no reading ,if it fails the test replace,let me know what you find
Sep 22, 2008 | Kenmore 62602 Electric Dryer
Frigidaire FGR341AC Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
