Question about Logitech EX110 Mouse
Advise uses of all F Keys.?. - Logitech EX110 Mouse
    President:
  • 1,932 Answers
F1
Almost always used as the help key, almost every program will open the help screen when this key is pressed.
Windows Key + F1 would open the Microsoft Windows help and support center.
Open the Task Pane.
F2
In Windows commonly used to rename a highlighted icon or file.
Alt + Ctrl + F2 opens a new document in Microsoft Word.
Ctrl + F2 displays the print preview window in Microsoft Word.
F3
Often opens a search feature for many programs including Microsoft Windows.
Shift + F3 will change the text in Microsoft Word from upper to lower case or a capital letter at the beginning of every word.
F4
Open find window.
Repeat the last action performed (Word 2000+)
Alt + F4 will close the program currently active in Microsoft Windows.
Ctrl + F4 will close the open window within the current active window in Microsoft Windows.
F5
In all modern Internet browsers pressing F5 will refresh or reload the page or document window.
Open the find, replace, and go to window in Microsoft Word.
Starts a slideshow in PowerPoint.
Posted on Sep 30, 2010
  • Udhaya Rajan
    Udhaya Rajan Sep 30, 2010
    F6
    Move the cursor to the Address bar in Internet Explorer and Mozilla Firefox.
    Ctrl + Shift + F6 opens to another open Microsoft Word document.
    F7
    Commonly used to spell check and grammar check a document in Microsoft programs such as Microsoft Word, Outlook, etc.
    Shift + F7 runs a Thesaurus check on the word highlighted.
    Turns on Caret browsing in Mozilla Firefox.
    F8
    Function key used to enter the Windows startup menu, commonly use to get into Windows Safe Mode.
    F9
    Opens the Measurements toolbar in Quark 5.0.
    F10
    In Microsoft Windows activates the menu bar of an open application.
    Shift + F10 is the same as right-clicking on a highlighted icon, file, or Internet link.
    F11
    Full-screen mode in all modern Internet browsers.
    F12
    Open the Save as window in Microsoft Word.
    Shift + F12 save the Microsoft Word document.
    Ctrl + Shift + F12 prints a document in Microsoft Word.
    F6
    F7
    F8
    F9
    F10
    F11
    F12
Hp pavilion, some keys not working including space bar. the bottom keys and some number keys, please advise
If the computer is under warranty, I recommend contacting HP for support, otherwise you will likely need to have the keyboard replaced, or if the computer is over 3 years old, I would recommend purchasing a replacement.
Nov 14, 2016 | HP Computers & Internet
I need to remove keys from my keyboard for cleaning
Most keys should 'pop' off but the tricky bit is getting them back on...
If you remove them I would advise taking a photo of the keyboard ... may sound obvious but putting the unfamiliar keys in the right place can be a test on your memory/recall skills to say the least.
1. First up, you need to use a small screwdriver to carefully remove all keys from your keyboard. Then loosen the rubber pieces from each of them and place them separately.
2. Once all keys are removed from your SAMSUNG NP-N145- keyboard, you can either use an ear bud or a cotton swab dipped in water to gently clean the inner regions of the keyboard. However, make sure that you do not use too much water for this cleaning purpose.
3. After cleaning the inner regions of your keyboard you need to start cleaning the individual keys using a light fluid and foam rubber. After cleaning these pieces you need to leave them alone to get dried up.
4. Once the keys are dried up you can assemble them back into the keyboard carefully. Make sure that the rubber pieces too are assembled in their appropriate places.
Regards
Jul 01, 2013 | Samsung NP-N145-JP02US NETBOOK
I am having problems getting my keys into the ignition lock barrel on my 2005 cbf600 n, have lubed barrel but still still giving problems can you advise if and where I can purchase a new ignition lock and...
You should not use liquid lubricants on key switches, in the long run it will gum up and just get worse. You can use powdered graphite for lubrication problems...However if its a worn tumbler or key problem you will need to replace it im thinkin.
May 06, 2011 | 2005 Honda CBF 600
How do i remove the keys to clean underneath?
What do you want to clean? Use a can of compressed air, vacuum cleaner, or buy a new keyboard. it is not recommended to remove the keys.
Mar 05, 2011 | Computers & Internet
How do I remove the bottom of my AX 60 model so that I may at least spray the keys and hope they would stick LESS. What should I use to Lub. the keys? Please advise Psimons@new.rr.com Help
When you say stick I assume that you mean they go down but won't enter. If so what you need is a new contact pad that is sandwiched in side the keyboard. Not for the weak of heart.
DickyO
Aug 28, 2010 | Nakajima Office Equipment & Supplies
My hyundai 1.6 petrol matrix has intermittant
answer from the uk.you will only have a problem showing up if the engine management system records a fault within that system, so, the only solution is, if you have remote locking,change the batteries and use to unlock car not using the key.or if no remotes,change keys on a regular basis.(they are coded to the car) do not use grey (service key) only 2 x black keys supplied with car....check handbook re keys....
Mar 23, 2010 | 2007 Hyundai Sonata Limited Sedan
H, G and backspace keys stoppe working on
Though you could be having a hardware problem with just faulty keyboard keys, it could also be a trojan virus where someone has disabled those keys.
I advise rule out the virus with Mcafee virus free scan: http://us.mcafee.com/root/campaign.asp?cid=45694
you should also use a "trojan" scanner. (the type of virus)
Jul 11, 2009 | Computers & Internet
Keyboard symbol keys now showing as accent keys
Or maybe you can try to hit the control en shift button at the same time and then try again.
Jan 26, 2008 | Logitech Cordless Desktop MX3200 Laser...
Sony vaio keyboard VGC-M1
Could be that you just need to clean it. Use a air spraying tool to clean out the keyboard. You could also try taking these keys off the keyboard, clean it, and then put the keys back in. Shouldn't be that hard to do. I wouldn't take it in to get it fixed though as you can pay for a new keyboard for less.
Apr 03, 2007 | Sony VAIO M1 (VGCM1) PC Desktop
Logitech EX110 Mouse Logo
545 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
