Question about SanDisk Sansa Clip MP3 Player
My Sansa Clip will not turn on. - SanDisk Sansa Clip MP3 Player
2 Suggested Answers
bigpaws
  • 63 Answers
SOURCE: sansa clip
battery maybe?
Posted on Jun 23, 2009
My sand disk sansa mp4 keeps on freezing on the music play all the time and the computer cannot read it
How to Reset a Sansa Clip
The Sansa Clip is a high-quality MP3 player. It holds hundreds of songs and is built for portability. The "clip" allows you to attach it to your clothing or belt while you are working out or on the go. Even the best MP3 players can encounter some problems, and the Sansa Clip is no exception. If your Sansa Clip freezes up and does not respond, you may have to try resetting or reformatting it.
Turn Sansa Clip on. Press the "Menu" (home) button.
Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
Scroll down to "Reset All" and select. You'll be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow Steps 4 and 5.
In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm that you wish to format. Select "Yes."
Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
Resetting a Frozen Sansa Clip
Push the power button up and hold it for 20 seconds. Release it, then turn it on again.
Go to the Sansa website and download the "Sansa Firmware Updater."
Select "Run" when the updater installs. (Installation will take less than two minutes.)
Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
Connect the Sansa Clip. Remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Tips & Warnings
You should download the Sansa Firmware Updater to your computer even if you aren't having a problem with your Sansa. This will ensure that your device software remains up-to-date and free of technical glitches.
Reformatting the Sansa Clip will erase all songs and data on the device. Resetting will simply change your player's settings.
Have a nice day....
Feb 19, 2011 | SanDisk Sansa e260 MP3 Player
It got hanged..it can be turned and the buttons are not functioning
Tips & Warnings
Feb 19, 2011 | SanDisk Sansa Clip MP3 Player
My player got hanged.and its not functioning? what probably the cause and how can i deal with it? it cannot be turned off..the menus are not functioning
Hi,you need to rest your mp3 player...
Instructions
Complete Reset
Tips & Warnings
Instructions
Complete Reset
Tips & Warnings
My Sansa Clip won't work. When I turn it on it says: Not enough space for music DB Please free 30 MB. But when i connect it to my computer it doesn't register. PLEASE HELP ME
Because you drag 7 drop songs or files too much into the sansa clip in MSC mode, it causes like that.
Turn it on, it will show " Not enough.....free 30 MB", and then automatically turn off. Plug it into pc, open my computer, it will be under name "Sansa clip..." or "removable disk ". If your pc does not recognize it, unplug again and replug it.
Open Sansa Clip..., or removable disk, and delete some songs.
Good luck
Apr 30, 2010 | SanDisk Sansa Clip MP3 Player
Its just frozen
Well first of all you can try the following steps -
1. Unfreeze a frozen Sansa Clip by pushing the power button up and holding it for 20 seconds. Release it, and then turn it on again.
2. Go to the Sansa website and download the "Sansa Firmware Updater."
3. Select "Run" when the updater installs. (Installation will take less than two minutes.)
4. Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
5. Connect the Sansa Clip and then remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Good Luck!!
Thanks
Apr 15, 2010 | SanDisk Sansa Clip MP3 Player
My Sansa Clip won't turn on even thought the battery is full.
Unfortunately there was a manufacturing flaw with many Sansa Clips which caused one of the battery leads to detach from the battery. A symptom of this is that the Clip will turn on and charge when connected to an external power source, such as USB or an AC adapter, but will not actually turn on using the internal power source (eg, the battery).
If your Clip is still under warranty, you should return it for a refund or an exchange.
Feb 17, 2010 | SanDisk Sansa Clip MP3 Player
The screen is dim it is on the last song played it won't do anything won't turn off but won't play either, It worked fine this morning help please It is a sansa clip 2gb I've had it since Sept. 09
Sansa Clip won't turn off right? push up power button and hold it for 10 to 20 second, your device will turn off now.
After that, you should update your new firmware from sandisk forum, you should check Sansa Clip or Sansa Clip+ from the following web,
http://forums.sandisk.com/sansa/
Good luck
Jan 25, 2010 | SanDisk Sansa Clip MP3 Player
I left my Sansa Clip MP3 Player plugged in while putting my laptop into hibernation. Now player does not response, I can't turn it on, and laptop doesn't recognize it at all.
    Complete Reset of Sansa Clip
  1. Step 1 Turn Sansa Clip on. Press the "Menu" (Home) button on the Sansa Clip.
  2. Step 2 Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
  3. Step 3 Scroll down to "Reset All," and select. You will be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow steps 4 and 5.
  4. Step 4 In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm if you wish to format. Select "Yes."
  5. Step 5 Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
  6. Resetting a Frozen Sansa Clip
  7. Step 1 Unfreeze a frozen Sansa Clip by pushing the power button up and holding it for 20 seconds. Release it, and then turn it on again.
  8. Step 2 Go to the Sansa website and download the "Sansa Firmware Updater."
  9. Step 3 Select "Run" when the updater installs. (Installation will take less than two minutes.)
  10. Step 4 Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
  11. Step 5 Connect the Sansa Clip and then remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Aug 22, 2009 | SanDisk Sansa Clip MP3 Player
How to unfreeze a sansa clip mp3 that won't turn off
plug it into the computer and shut down then take it out
Sep 07, 2008 | SanDisk Sansa Clip MP3 Player
Won't turn on
What you need to do is first make sure that you are safely disconnecting your sansa clip and not just taking it off the computer. Second you may have a virus in your sansa clip I would prefer you call Technical Support for Sansa clips, the number is 1-866-726-3475, they are open 4am-10pm PST
or 7am-1am EST. Hope this helps
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
