Question about Samsung SyncMaster 740N 17" LCD Monitor
-blank screen -power indicator- blue (blinking) -works fine after 3 hours of waiting
  • 11,361 Answers
It may have dying caps in the power supply.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 30, 2010
I have problem in power supply board ip-19125a.that 12v is getting come.what is the solution
Posted on Mar 15, 2011
My toshiba at200 table 10.1 wont turn on
1. When you press the power button to turn it on, do you see any thing on screen, like the toshiba boot up screen or something like that. Or is it completely blank (black color) always.
2. Can you see a faint image of your desktop (try to see it in dark place with flash light). This is important to confirm.
3. Also, when you press power button, do you see the LED lights on laptop blinking or solid green (which ones are in blinking/solid) and do hear any sound ? Or do you feel that your laptop doesnt even try to boot.
4. Can you hear any Beeps when you try to turn on the computer. If yes, what is the sequence of those beeps.
Continued......
If you answers are -
1.
blank
2.
no image
3.
only the satellite light is blue, the powercord is blue and the battery is blue
4.
no noise
Please do the following carefully and let me know result :
1. Shutdown and Unplug your laptop.
2. Remove the battery from the laptop.
3. Wait 2-3 minutes
4. Now press ON (power button on laptop) for 1 minute
5. Then release the finger and wait one more minute.
6. Now plug in the power cable (dont insert battery yet) and press ON button.
7. Did your screen start working now ? (do you see windows loading)
Jan 04, 2015 | Video Game Consoles & Games
Display blank Sharp LC70LE650U
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/.If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 21, 2013 | Sharp Aquos Televison & Video
Blue light turns on but tv screen stays blank
The blue light indicates power is getting to your TV but there may have been failure of the internal power supply
Jul 07, 2013 | Sceptre Televison & Video
Samsung 906vw blank screen
if the power light indicator is just blinking with no display, you must checked the power supply the common cause bulging electrolytic capacitor. just replace with the same value and rating then the problem solved.
Jul 22, 2012 | Samsung Computers & Internet
-blank screen -power indicator - blue (blinking) -works fine after 3 hours of waiting
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Sep 30, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
My monitor goes blank and the power light blinks on and off and the power switch does not work? I have to unplug it and wait a few minutes then turn it back on and it will work for acouple of hours then go...
The problem is with the power board inside the screen, when it gets hot it shuts down the screen unit it cools off.
It could also be that the power in is not connecting properly to the board i had that before and had to replace the screen it is cheaper in the end parts are to axpensive
Oct 22, 2009 | Dell Computers & Internet
Directv dvr will not power on. The record light
Unplug the DVR for about 20 minutes and then plug it back in. If that doesn't work its probably time to contact DTV for a replacement.
Mar 23, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Power indicator light blinking
Check soldered in micro fuses...F850, F851 etc.....
1) solder jumper wires on signal board = 008,010,017,048,600
2) Check / replace STK392-110 convergence IC's with Toshiba
part # 23135090 or upgade to Hitachi part # CZ01341
Let me know....................T.
Jan 04, 2008 | Toshiba 65HX81 65" Rear Projection...
Samsung SyncMaster 740N 17" LCD Monitor Logo
847 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
