Question about HTC S200 Smartphone
APN settings for primus canada - HTC S200 Smartphone
Settings for apn are blank. what is my apn code
Hi Edward,
Here are the steps..
Internet Setup
Step 1: Enter Settings
Step 2: Select Wireless & Networks
Step 3: Select More...
Step 4: Select Mobile Networks
Step 5: Ensure Data Enabled is checked (enabled).
Step 6: Select Access Point Names
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND Data as the name for the new APN. Under the headings APN enter internet.windmobile.ca (leave all other fields blank).
Step 8: Save the APN settings by selecting menu and then save.
Picture Messaging (MMS)
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • APN: mms.windmobile.ca
  • MMSC:http://mms.windmobile.ca
  • MMS Proxy: 74.115.197.70
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
  • Leave all other fields blank.
Android 2.1 to 2.3
Internet setup
Step 3: Select Mobile Networks
Step 4: Ensure Data Enabled is checked (enabled).
Step 5: Select Access Point Names
Step 6: Create a new APN (Access Point). Enter any name you would like to call your internet connection and the access point as internet.windmobile.ca (leave all other fields blank).
Picture Messaging (MMS) setup
Step 6: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • MMSC: http://mms.windmobile.ca
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
May 10, 2016 | HTC 7 Surround T8788 Windows 7 Wm 3.8"...
Please my LG G4 dont have APN settings. How can I download it
Hi Yewande, Without knowing your internet provider I can't help you but you can find it by googling (APN settings for) + YOUR INTERNET PROVIDER.....CHEERS..
Apr 25, 2016 | LG G4
How to use APN
The first thing you'll need to do is find the right APN settings for the network you want to use. For example below are the APN settings for Straight Talk.
Name- straight talk
APN-tfdata
Port-80
MMSC-http://mms-tf.net
MMS Proxy-mms3.tracfone.com
MMS Port-80
Once you have all this information, grab your phone. Settings>wireless/network settings. More options>mobile networks.
Once you found mobile network settings, rest will be the same on all devices. Look for "Access Point Names" then tap on it.
You should see a list with at least one APN. Add new.
This is where you will enter the settings you got from your carriers website. 2 very important things here:
    1.Not every setting in the "edit access point" screen will need filled in.
    2.Be sure to type in everything exactly as provided by your carrier. Once you have settings provided by your carrier entered, you need to save the APN. You do that by pressing the 3 dots in upper right and selecting "save" option.
    Once your APN information is saved, go back one screen to the list we saw earlier. On this screen, tap the new APN settings you just entered to make active.
What is an APN and how do change it
Oct 31, 2015 | Samsung GALAXY S4
Samsung s4 I deleted the apn on accident how can I get them back
Every carrier uses its own APN Settings to get its 3G/4G LTE network working on an Android smartphone or tablet device. Now, these APN settings are usually "downloaded" automatically to your phone when you insert a SIM card. BUT, there are times where the APN are not selected automatically OR when the APN settings are not downloaded.
In those instances, your 3G/4G LTE data will not work but that can easily be fixed.
Step 1. First, browse your Settings menu and find the "Access Point Names" menu. This is usually under "Mobile Network Settings" or "More Mobile Networks" or "Mobile Networks" under Settings menu depending on the Android device used.
Step 2. Once you are in the APN Settings menu, first thing you should check it that the APN is on the correct one. If the correct APN is not checked (sometimes this happens), simply check ON the correct APN for your carrier. That will make your 3G/4G LTE data working right away.
Step 3. There are also times where the wrong APN is listed or there's simply no APNs listed. In these rare cases, you can simply add a new APN, hit the "+" button. 25264381-evzu5111kn4ie1titkzzffdn-4-2.jpg
Step 4. For APN setting, the "Name" can be anything. "APN" setting is the most important, usually you only have to fill this out for your phone to work.
Step 6. Hit "Save" when done.
Step 7. Next, make sure to select the new APN Setting you have saved. Within 5-30 seconds, your phone should start picking up 3G or 4G LTE signals and your data should be working again on the phon 25264381-evzu5111kn4ie1titkzzffdn-4-14.jpg
Nov 01, 2014 | Cell Phones
Di ako makapagfb using myphone Q19i...paano po b dapat gawin para makakonekta ako gamit ko ung cp n un? ty.
APN Settings for Globe, Smart, Sun, WeRoam Cellular
The following settings are applicable to Smart, Globe and Sun Cellular for their APN settings (Access Point Name). The settings should work with majority of smartphones in the market.
Postpaid APN: internet.globe.com.ph
Prepaid APN: http.globe.com.ph
APN Settings for Smart Bro
Postpaid APN: smartbro
Prepaid APN: smartbro
APN Settings for Smart Buddy, Smart Gold
APN: internet
APN Settings for Sun Cellular
Prepaid
APN (static): minternet
Authentication: PAP
IP address: dynamic
Postpaid
APN (static): fbband or minternet
Authentication: PAP
IP address: dynamic
APN Settings for PLDT WeRoam
Postpaid: WEROAMPLANor internet
Note: If you’re using a variety of postpaid or prepaid SIM cards in one dongle, make sure to create a Setting Profile for each SIM card so it’s easier to set the APN when switching SIM cards.
Leave all other settings blank or as is.
Mar 05, 2014 | Computers & Internet
I just want to ask,how to connect 3g in the phillippines via globe network?hope you can help me
You need to set the APN settings. Go to Settings->Wireless & Networks->Mobile Networks->Access Point Names, click the menu and "New APN" Please try the settings below:
Name: Globe Internet APN: http.globe.com.ph APN Type: default
Note: No need to set the other fields while creating the new APN.
Select the newly created APN. To connect to the internet, tap on "Mobile Network". It will then connect using the newly created APN.
This works on my HTC Wildfire. Hope this helps.
Mar 08, 2011 | HTC Desire Cell Phone
I have internet but can't able to use YOU TUBE application always say "APN setting or unknow" but another application run as it is.... my mobile lg gs500v
dear friend,
APN means access point name....can you tell me your service provider so that i can easily give you an APN as it differs from service to service...
don't forget to vote me
enjoy & Cheers
Jan 12, 2011 | LG Cell Phones
How set up the Linksys WRT 54 g router with primus communication
hi,
login to admin page, go to WAN connection setting.
before that , please be ready your primus username and password.
after that save the changes.
Sep 11, 2009 | Linksys Wireless-G WRT54G Router
Wap settings for motorizr z3
Regular rogers wap
(not using phone as modem)
uses navigate plans
http://www.shoprogers.com/store/wir...ng/overview.asp
apn: goam.com
username: wapuser1
password: wap
IP 208.200.067.150.
or
172.025.000.107
Rogers Media settings
(for MMS/PICmessaging)
http://www.shoprogers.com/store/wir...remessaging.asp
apn: media.com
username: media
password: mda01
mms.gprs.rogers.com
ip 172.025.00.107
Rogers internet.com settings
(to use phone as modem. Or is needed for HTML phones, or wap 2.0 phones at this current time.
requires access to a Data access plan
apn: internet.com
username: wapuser1
password: wap
ip: same as goam, 208.200.067.150
Dec 06, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
HTC S200 Smartphone Logo
226 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Jerry Kramer
Jerry Kramer
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
