Question about Lexmark C500n Laser Printer
Error msg appear set belt cg dont know what to do.. am i have to replace the photodeveloper cg?
  • Official Brand Answer
  • 3,344 Answers
The error can either be caused by the OPC/OPC Marker assembly or the Main Motor assembly. Please follow the recommended troubleshooting steps:
  1. Power the printer off, remove and reseat the OPC unit, and power the machine back on. Print a test page. If error continues, proceed to step 2.
  2. Power the printer off and remove the OPC unit. Check the OPC Marker Sensor. If it is unsnapped or unplugged, reseat or replug it, and power the printer back on. Print a test page. If error continues, proceed to step 3.
  3. Remove the OPC unit and check it for scratches or defects. Also check the the markers on the OPC to make sure they are not damaged. Is the belt scratched or damaged? If the OPC is at or near the end of its life, OPC unit must be replaced. If the belt is in good condition, contact Lexmark technical support (if printer is under warranty) or your local authorized service provider for assistance.
Posted on Sep 30, 2010
Reset replace OPC belt
Here's the link on how to replace the Photodeveloper Cartridge on the Lexmark X500/X502: http://bit.ly/bzQQtH.
Here's the link on how to reset the photodeveloper (OPC) count on the X500/X502: http://bit.ly/9BxHqz.
Hope this helps.
May 25, 2010 | Lexmark X502N All-In-One Laser Printer
Menu screen comes up with (Replace Belt CG)
The 'Replace Belt CG' message on the 8008 indicates the OPC Belt (Green Reflective Belt which is located in the top of the printer) has reached the end of its life and needs to be replaced to ensure the print quality is maintained.
If you are happy with the print quality you can clear the message via the control pannel on the printer, you will however need to remember you have cleared the error in the future when print quality is reduced you will then need to replace the OPC Belt.
The ‘Replace Belt CG’ message can be cleared in the following way;
With the printer OFFLINE hold down the MENU button for 2-3 seconds until the display changes UTILITY MENU and then release the MENU button
Press the MENU button once more
The display will read "Utility Menu Clear Belt CG", press the MENU button once more
The display will change to "Clear Belt CG Not Execute" by pressing MEDIA/> key again the display will change to "Execute"
Press the MENU/ENTER key again after 10 seconds the display will change to "Completed Clear belt CG"
Press the UP ARROW button twice to exit the Utility Menu
Press the ONLINE button to return the printer to the ONLINE state
The ‘Replace Belt CG’ message will now be cleared.
Jan 28, 2010 | TallyGenicom 8008 Laser Printer
What does Replace Belt CG mean?
When the Replace Belt CG message appears, the photodeveloper cartridge has been exhausted and will need to be
replaced. Order Lexmark part number C500X26G.After a new photodeveloper cartridge is installed, reset the
photodeveloper count.
1 Make sure the printer is on and the Ready message appears.
2 Press .
4 Press and hold for 3 seconds until you see Utility Menu, and then press .
5 Press until you see Clear Belt CG, and then press .
6 Press until you see Execute, and then press .The photodeveloper belt count is now reset.
7 Press to return to Ready.
Jan 12, 2010 | Lexmark C500n Laser Printer
C510 printer displays "994 Service Engine Error". How do you address this?
From a previous post: Posted by waynechurch on Apr 24, 2009 Is this error on a C510?, because the manual lists 994 as OPC belt marker sensor error.
Normally with an engine service error i reflash the engine firmware first, if that doesn't cure the fault i would then replace the engine board. If you need the firmware, visit the Lexmark site get the contact phone number for your region and ring them. They're normally quite helpful and of coarse can tell you how to reflash it.
Sep 25, 2009 | Lexmark C510 Laser Printer
Here you go, courtsey of Lexmark's Knowlwdgebase.
Don
994 Service Engine Error on a Lexmark C510 ID: ENUS21233 If your printer is unable to move the photodeveloper belt to the correct position during printing, a 994 error will occur. However, it may simply be the case that the photodeveloper is either contaminated with excess toner or improperly installed. To test for and resolve this issue, please do the following:
  1. Power the printer off and remove the photodeveloper cartridge.
  2. Rotate the green metallic photodeveloper belt by manually turning the white drive gear on the bottom of the cartridge until the black positioning markers are visible.
  3. If necessary, carefully wipe any excess toner powder from the positioning markers using a soft, lint-free cloth or tissue.
  4. While the top cover of the printer is still open, inspect the sensor that is used to locate the positioning markers on the belt. CAUTION! The photodeveloper is very sensitive to light. Cover the green metallic surface of the photodeveloper with a piece of paper while it is outside the printer.
    • Refer to this image, this image, and this image to identify the location of the sensor.
    • Verify that the sensor has not come loose from its housing and that it is not contaminated with excess toner powder. If necessary, clean the sensor with a soft, lint-free cloth or tissue.
  5. Re-install the photodeveloper cartridge and power the printer back on.
  6. If the error remains, it is likely that a service call will be necessary to resolve this issue. Please contact Lexmark Technical Support, having first obtained the serial number of your printer. NOTE: If practicable, attempt to order another photodeveloper and replace it first to avoid the inconvenience of a potentially unnecessary service call.
Jun 22, 2009 | Lexmark C510n Laser Printer
Error message 83 - photodev cart exhausted
The photoev cart is the photo developer cartridge.
See User Reference
http://www.lexmark.com/publications/pdfs/c510/eng/userref.pdf
Understanding printer messages
pages 184 and 185
"Message:
83 Photodev Cart Exhausted
What this message means:
The photodeveloper cartridge is completely used.
What you can do:
Replace the photodeveloper cartridge.
See also: Replacing the photodeveloper cartridge [page 73]
Continuing below
Message:
83 Photodev Cart Life Warning
The photodeveloper cartridge is nearing the end of its life.
What you can do:
• Press Go to clear the message and continue printing.
• Replace the photodeveloper cartridge.
Continuing below
Message:
83 Photodev Cart Missing
The photodeveloper cartridge is either missing or incorrectly
installed.
What you can do:
Correctly install the photodeveloper cartridge to clear the message and continue printing.
See also: Replacing the photodeveloper cartridge [page 73] "
Dec 08, 2008 | Lexmark C510 Laser Printer
Lexmark c510 error message ;83 photodeve cart missing
See User Reference
pages 184 and 185
"Message:
What you can do:
Continuing below
Message:
What you can do:
Continuing below
Message:
installed.
What you can do:
Nov 26, 2008 | Lexmark C510 Laser Printer
Tally Genicom 8008
The Set Belt CG message on the 8008 indicates the printer is not detecting the OPC belt (the green reflective belt located in the top of the printer)
Try removing the Belt Cartridge and relocate this in the pritner, if this fails to fix the problem remove the Belt Cartridge from the printer then look down one side of the belt- (I think the left side of the belt), for black squares (I think there are two) the printer uses these to detect the Belt Cartridge is rotating. Check for damage to the Belt in this area. If the printer does not detect the belt as rotating it will indicate this error.
If the Belt Cartridge looks ok, remove the Belt Cartridge from the printer then look down the hole left in the printer when the belt cartridge is removed. Look for any obstuctions, also look at the black belt which is towards the back of the printer when you look in the top ( the transfer belt, I think) Look to see if there is any damage to this it may cause the Set Belt CG message.
Apr 02, 2008 | TallyGenicom 8008 Laser Printer
Error Message ('replace belt CG')
To reset page counter after replacing the OPC belt or FC Roller please follow the steps below:
  1. Power the printer on while holding down MENU/ENTER key
  2. Release the key when the display shows "Utility Menu Clear FC Roll"
  3. If you have replaced the FC Roller then select this option by pressing MENU/ENTER key. If you have replaced the OPC belt then change this option by pressing MEDIA key so the display changes to "Utility Menu Clear Belt CG".
  4. When one of these options is selected Press the MENU/ENTER key and the display will change to "Utility Menu Clear FC. Roll/ Clear Belt CG Not Execute". Press the MEDIA key and the display will change to "Execute"
  5. Press the MENU/ENTER key and after about 10 seconds the display will change to "Completed Clear FC. Roll / Belt CG"
  6. Now power the printer off and after waiting few seconds power it on again, after it's initial self-diagnosis the printer should now work normally without the error message.
Jul 12, 2007 | Tally T8006 Laser Printer
Lexmark C500n Laser Printer Logo
681 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
