Question about Linksys SRW224G4 24-Port Ethernet Switch
I have a Linksys SRW224G4 switch and WRV210 router when i create 5 vlan on the switch separate each port to the designated vlan. the problem is each vlan is interconnected and all I want to do is to deny accessing each vlan. let say when I'm in computer that connected to vlan 2 and trying access the vlan 3 it must be denied but i my settings it allow me to access the all the vlan i've created. What configuration that i must do to fix this problem?
2 Suggested Answers
SOURCE: i've created 5 vlan on srw224g4 switch on 5 ports
are all the VLANs in the same subnet?
If Not,Can you ping the router?
IF So, you need to configure NAT for all subnets.
Posted on Feb 10, 2010
How to create vlan
Login to the router's built-in web-server interface, and use that web-based application to assign individual ports to a specific VLAN.
Jun 05, 2011 | Linksys SRW224G4 24-Port Ethernet Switch
How to create vlan with linksys srw224g4
Login to the built-in web-server interface, and use the interface to add specific ports to a specific VLAN.
Jan 24, 2011 | Linksys SRW224G4 24-Port Ethernet Switch
I have linksys srw224g4 layer 2 switch how can i create trunk port in this switch
Log into the web management of the switch.
Go to settings --> Vlan Tabb
Under the VLAN click on the VLAN and you can see the ports .
Click on the trunk box under the switch port which you want to make as trunk.
Jan 10, 2011 | Linksys SRW224G4 24-Port Ethernet Switch
Sir I have 4200 series 26 ports Switch i want to Configure intra VLAN But I am Getting a problem to Configure that switch . After Cnfigure VLAN on Consol prompt. I am not accessing to my Server & WAN...
If you are creating only Layer 2 VLANs on the switch , you wont be able to ping the servers and Routers as they are in default VLAN1.
you can do the below steps
1. Create sub interfaces on the router LAN interface
2. Provide a new ip range to the new sub interface
3. Make the switch port connecting router as trunk, so that it will carry both the VLAN info
4. on your Labtop/PC give the IP address in the newly defined range
5. Make your switch port to be in the new VLAN
This will work , if you wont be able to configure the above settings, let me know i will give you the detailed config
Nov 01, 2010 | 3Com 4500 24-Port Ethernet Switch
Hello, I have a Linksys SRW2016 and 2048 switches with one cisco 1800 series router. I have successfully created two vlans on one switch and when i try to connect a trunk port to cisco router it...
Make sure that the frame encapsulation is set on the router to 802.1q on each of the sub-interfaces. You could also try fixing the speed and duplex on both the router and the switch in case there is a problem negotiating the speed and duplex.
Hope that helps!
Oct 04, 2010 | Linksys SRW2016 (745883562435) 16x1000...
I have a Linksys SRW224G4 connected to a Netgear DG834 ADSL 2 modem 4 port router. It seems to drop the connection every 5 minutes or so. I've checked all the ethernet cables with a tester to ensure no...
The linksys may be assigning IP addresses that conflict with the router. Usually you need to disable Dynamic IP assignment in downstream routers and switches.
Sep 27, 2010 | Linksys SRW224G4 24-Port Ethernet Switch
Linksys SRW224G4 24-Port Ethernet Switch Logo
137 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
