Question about Maytag MSD2756G Side by Side Refrigerator
The two days ago, the freezer side began to get iced up on the inside of it, and water was somehow collecting in the bottom of the freezer and freezing up, and I could see a little bit of water starting to leak out onto the floor right where the hinge area was at the corner of the bottom of the door. The freezer began losing coldness and then stopped chilling at all. Then the next day the refrigerator side began to lose its chill, too. I can hear the fans inside both compartments running nicely and quietly and I can hear a slight clicking sound about every three minutes. I want to keep this fridge running at all costs, because we looked at new fridges today and I was horrified at the cost of a new unit this size with these same features. Can someone tell me where to start investigating the problem on this fridge?
  • Maytag Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 30, 2010
Water collecting inside fridge, under meat drawer
Yes most responses are the freezer drain even if it is in the bottom freezer. If the drain is blocked water will build up anywhere inside your refrigerator only because it has no place to go during the defrost. Defective door seals can also can make the problem much worse. See Leaking Refrigerators I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | GE Profile 22.2 Cu. Ft. Side-by-Side...
Ice forming inside freezer
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. Also note on the maytags these days they put a rubber piece called a duck bill on the bottom half of the drain which will also cause this over time. To access this piece you'll have to pull the machine from the wall and remove the lower panel and find the plastic drain and remove the duck bill
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 28, 2012 | Maytag Refrigerators
Water dispenser does not shut off
That is most likely a dual water control valve stuck open on back of refrigerator near floor. One side feeds ice maker and other side feeds the water dispenser. If the ice maker side began to leak slowly it would create quite a mess of ice flowing over ice maker and freeze every place it could inside the freezer. Part and Model Search If helpful Please Rate this solution, Thank You, Sea Breeze
sea_breeze_260.jpg Refrigerators
Freezers
Washers and Dryers
Oct 18, 2011 | Frigidaire Refrigerators
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
Sep 30, 2009 | Maytag Sovereign 60 Side by Side...
Ice collecting and water overflow from bottom freezer GE
IF YOU TAKE THE BACK OFF THE INSIDE OF THE FREEZER IT IS LOCATED UNDER THE EVAPORATOR COIL IN THE CENTER, IT IS A PIECE OF ALUMINUM SHAPED TO CATCH THE WATER, MELT THE ICE AND BLOW THE HOLE CLEAR
Aug 11, 2009 | GE Refrigerators
Water on floor under unit & ice bottom of freezer
By going online, saw several posts re this problem. In short, the water drain was clogged and there was also a problem with the defrost timer. Service man blew out the drain line with compressed air and installed a new timer. Voila! Problem fixed. Interestingly, the serviceman found a wad of what looked like putty, but was sticky like gum in the drain area. He said he had never encountered anything similar.
Aug 04, 2009 | Jenn-Air JCD2295HES Side by Side...
Water at bottom of refrigirator
Find the drain line from the freezer to the evaporation pan near the motor. Often the line is visible on the back of the fridge. That line is plugged either with food residue or the collection point in the freezer is solid ice. The self defrost feature melts the frost and drains it to the evap pan. If you remove the floor from the freezer area, you will see the collection point. When the line gets plugged with food, no water drains and then freezes to block the line even worse. So, if there is ice at the collection point, remove it somehow, maybe a hair dryer, and then clear the line by blowing compressed air from the bottom of the drain hose through to the collection point.
Jun 19, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice forming bottom of freezer leaking out the door
It is acutually a collector pan for the drain hose. When the refrigerator runs a defrost cycle (about every couple days), that pan collects the water from the ice that is melted and drains it through a hose inside the unit, to a pan under the unit. You will have to pull the back panel off the back of the freezer and melt it with either hot water or a hot blowdryer. Do it until you see the water draining freely into the bottom pan.
Oct 18, 2008 | KitchenAid Superba Architect KSCS25INSS...
Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Jul 23, 2008 | Refrigerators
Water collects and freezes in the bottom of the freezer
Your defrost drain is clogged. Get all the ice out and get to the defrost drain hole at the very rear bottom of the freezer. I use a piece of plastic tubing to run down them and clean them out, but you can use a piece of wire if it doesn't have a sharp end that will damage the tube. You can also remove the rear cover of the fridge and you will see the tube going from the cabinet to the drain pan and clean it from there. Post back if you need further help.
Sep 18, 2007 | Jenn-Air JCD2295HES Side by Side...
Maytag MSD2756G Side by Side Refrigerator Logo
132 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
