Question about Dryers
I need to get at the drum from the outside to tighten the paddles that are inside the drum
  • Michael Celso Sep 30, 2010
    Maytag mde8600ayw bought new in 2002
    Baffles are loose in the drum.
  • 51 Answers
Need to know what kind of dryer to be able to tell you how to get in it.,
Posted on Sep 30, 2010
  • Robert Johns
    Robert Johns Sep 30, 2010
    Look at the to lid toward the front where it connects with the bottom body ther are two clipps that you use a flathead screw drive to flip loose. Check bottom of the base front body and see if there is two screws, if so remove.
Dryer is "eating" clothes; how do we fix it?
I suggest you find someone to "get inside" the machine drum and find out what is damaging the clothes. I could not find the machine in "Sears Parts" to look at the drum. (They have pictures for most all US machines). I am not sure the drum might not need to be removed to repair it. There should be something there that is "snagging" the clothes and could be sanded down or smoothed somehow. If it has removable "paddles" to tumble the clothes, sometimes one could come loose and need tightening. I have seen heavy objects like large tennis shoes loosen a paddle.
Be blessed.
Jun 26, 2014 | Bosch Nexxt WTMC3321US Electric Dryer
The drum paddles have came loose from the machine
Have all drum paddles come loose? Generally there is one anchor bolt accesed through on of the paddle holes, usually the third from the front. Press down and away from you towards the back of the machine and tighten the bolt
The paddles have slots on there underside and coresponding hooks on the drum of the machine, hence the "push down and away" action to hook up the paddles.
Hope this helps
Duncan
Mar 04, 2011 | Whirlpool Washing Machines
Paddle in drum is loose at back of drum screw is loose how do i access to tighten ?
You need to get at the outside of the drum to reach those screws. You don't give a brand, but if it's a Whirlpool-made dryer (many are, like the Sears models), this page can help. It shows how to change a belt, and the first few steps explain how to open the machine to get at the drum.
Good luck with the repair, and thanks for using Fixya!
Mar 02, 2010 | Dryers
Loose paddle
Pop the top ... remove the front ... carefully remove the belt ... take the drumout - you are correct, the paddles are held onwith screws - tighten them.
reassemble
Oct 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Paddle inside dryer came loose how do we tighten
You have to open up the dryer to expose the clothes drum. Most paddles are fastened by two or three 1/4" sheet metal screws. Look for your lost screw in the dryer or replace it with the same. Use a drop or two of lock-tite to keep screws in place. Good time also to clean out all lint which can become a fire hazard, replace the drum belt and redo all of the screws.
Oct 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
One of the paddles came off inside the dryer
Remove the top and front of the machine. (Look for up to two screws them pop the top.) Remove the drum (be careful of the belt) Reattach the paddle - it should be self evident once you have the drum out. You might need to add a screw of two. While it is apart, Id be changing the belt.
Reassemble
Your wife will love you forever.
Simple.
Oct 09, 2009 | Dryers
One of the paddles inside the dryer has come loose, how can I fix this?
remove door screws and screws on opposite side. pull front forward and down. remove two brackets at top corners to raise top (unplug machine of course). screws are on outside of drum.
Jun 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Fin / paddle has come loose in the drum.
The paddles are the plastic things inside the metal drum. they are held in by tabs that slide into slots in the drum and a metal tab from the drum flips over a ledge underneath the paddle.
if its loose you may need to replace it, they are available as a spare part and come with instructions. you will need to varify which version you have by counting the bumps on the end of the padle, should be 2 or 3.
basically you put a small screwdriver down on of the holes in the top of the paddle, i think the 3rd one, to push the metal drum tab down enough to be able to pull the paddle towards you and out of it's slots. carefull not to push the tab down too far as it will bend inside the drum and isd pain to bend back again.
Any further help, Let me know.
Thanks for using Fixya.
Do rate the solution 'Fixya" if 100% satisfied.
Apr 30, 2009 | Washing Machines
Maytag Atlantis MDE6200AYW loose dryer paddle
You might have to remove the back, then the top, but it looks like the paddles are either held on buy a screw from the outside of the drum or they just have clips that lock them to the drum. Once the back is removed, you should be able to see how the top is held on. I think it is screwed or has clips for the back and then you slide it forward to unlock the front tabs. You can follow this if you don;t get a reply
from someone who has worked on this model#. Hope you get it apart ok and fixed by yourself.
Mar 14, 2009 | Microsoft Windows XP Home Edition
Loose Paddle in the Drum
not the right method, the paddles are the plastic things inside the metal drum. they are held in by tabs that slide into slots in the drum and a metal tab from the drum flips over a ledge underneath the paddle.
Feb 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Dryers Logo
74 people viewed this question
Top Dryers Experts
