Model # DGAT070BDD Furnace does not start fault code three flashes (green)
  • jason zeringue Sep 30, 2010
    whats the name brand of the heater
  • 1214 Answers
SOURCE: Igniter failure
The ignitor is probably going bad.You need to reset the cycle, then head out to get a new one before it trips cycle again.
Either that or order a new one for delivery.
If you can't leave the house to get a new one, eventually the one that is there is going to fail totally, and you won't have any heat.
When you install a new one DO NOT TOUCH THE NEW ONE WITH YOUR FINGERS. Contact and/or grasp only using the paper shield that it comes packaged in .
Posted on Jan 28, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: My furnace Coleman DGAT070BDD light flashes 4
Trying to find out what 4 flashes on the internet will be exhausting. However if you have the manual it is explained under trouble shooting. If not, look for a wiring diagram and an error code chart will be on the diagram. Sorry I could not be more help.
Posted on Dec 16, 2009
kingbrizzle
  • 407 Answers
SOURCE: Fault Code on Dayton Gas Furnace
This happens when the furnaces tries to light to many times and doesnt succeed. If you stand in front of the furnace while it is coming on, you will be able to hear the problem. If its an electronic start, there will be a clicking sound, followed by the gas valve opening to start it. If it has a pilot light, make sure it is lit, then listen for the gas to come out, it will make a hissing sound. If no gas is coming out, first double check to see if the gas is turned on to the unit, if it is, then its possibly the gas valve. Oh, if it is electronic, and you hear gas, but dont see a glow inside the furnace, or no glow or gas, it could be the ignite. Hope this helps.
Posted on Dec 28, 2009
  • 3315 Answers
SOURCE: I have a Coleman/Evcon furnace model #DGU08016UB
jump out pressure switch see if it lights check hose to pressure switch see if they are split or connections are not good ,cut off ends and put back on presure switch.
Posted on Sep 24, 2011
protohunter
  • 6 Answers
SOURCE: my furnace blows but shuts off and green light flashes
YOU MOST LIKELY NEED A NEW THERMOSTAT. You need to make sure you get the correct one they are not all the same.. you will also need to set how long the fan stays on after its stops heating the ducts If you have your owners Manuel look and see what kind it calls for. If your talking about a manufactured home it will be with all of correspondence.. I hope this was helpful and the green light is good but not blinking
Posted on Dec 07, 2012
My Xenon high efficiency furnace has a red blinking led light that blinks 4 times and my furnace will not light. What could be the problem?
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Each color will also flash a specific number of times to signify a specific error. ... 4 redcolored flashes may be signaling that the "high-limit" switch might be open. ... 3 green colored flashes on your furnace has the same meaning as 2 green colored flashes. ....If a system problem occurs, a blinking LED shows a fault code.Missing: xenon
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
Flash sequence codes 1 through 11 are as follows: LED will turn "on" ... 4 RED FLASHES: This indicates that the main limit switchhas opened ... This no-light condition occurred 3 times (2 retries) during .... My furnace trane xe80 is only flashing once my manual says something about flame being locked out ...Missing: xenon ‎efficiency
Nov 21, 2015 | Heating & Cooling
Fault code 32
Reset unit by shutting the power off then turn it back on. On the furnace cover you will see a flash code .Correspond you code with the code chart and you will find your issue
Jan 23, 2018 | Carrier Heating & Cooling
Protech 62-24084-02 troubleshooting
62-24084-02 LED CODES
POWER LED - GREEN
ON - Normal
OFF - No power to board
OK LED - GREEN
One Blink - One hour retry delay
Two Blinks - Pressure switch failure (remains open)
Three Blinks - Limit switch fault
Four Blinks - Pressure switch failure (remains closed)
Five Blinks - Twinning fault
FLAME LED - YELLOW
ON - Good flame
Rapid Blink - Flame present with gas valve de-energizing
Slow Blink - Marginal flame
Jan 01, 2014 | Protech Rheem/62-24084-82-1PK - Integrated...
Attic fan falure hed light blinking furnace wont run
Sounds like the circuit board needs to be replaced. The exact same thing happened on my house furnace. Power went to the board, producing the flashing led, but stopped there. I believe this is what you mean?
Replace the circuit board.
Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Dec 04, 2013 | Coleman Heating & Cooling
I have a Coleman/Evcon furnace model #DGU08016UB that has a concern. In my attempt to check my furnace before we need it for the winter; the following condition occurred. Condition: Flashing code of...
Sep 21, 2011 | Coleman Heating & Cooling
My furnace Coleman DGAT070BDD light flashes 4 times. Do you have any idea what causes that?
Dec 15, 2009 | Coleman Heating & Cooling
Meaning of rudd furnace trouble codes
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
increases
Dec 12, 2009 | Heating & Cooling
Furnace integrated control module
The light is supposed to be on, if there is a fault in the furnace the light will begin to give u a flash pattern... ie; three flashes...or two flashes.. on the furnace exterior or on one of the doors there should be a fault code chart.... read the chart on the unit it will tell you what light is on and when..
Jan 14, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
