Question about RCA HD52W59 HDTV Projection Television
53 inch rear projection tv bowed piture
I have gone to convergence controll and lined up all the red and blue lines in the grid this took care of 97 percent of the picture but the edges still have a bowed effect how can i fix this jeff
    Genius:
  • 1,030 Answers
THis set is notorus..bad to converge ...here at the shop seting the convergence takes up alot of my time... you may have to get a technician to converge in factory or service model.. this is something a non tech should not due "you can mess it up good" there may be a convergence amplifer board problem too. suggest getting a tech to chech it out. IF you can converge at all is a good sign that it might just be adjustment. average repair for this is 100 to 200
Posted on May 31, 2008
Can not get the focus grid to line up correct green adjusts fine but blue upper left corner will not adjust and the red grid is way off and will not fix
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 08, 2011 | Samsung HC-P4752W 47" Rear Projection...
Double image on television with blue hue
<SPAN id=ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution>Projection <A href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target=_blank><FONT color=#0033cc>TV</FONT></A> sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look <A href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target=_blank><FONT color=#0033cc>3D</FONT></A>, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. <BR><BR>This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem. <BR><BR><B>Common Symptoms include....</B><BR><UL class=h_mi><LI class=h_mi>Screen looks 3D <LI class=h_mi>Colors don't line up <LI class=h_mi>One or more colors can't be adjusted when using the convergence menu. <LI class=h_mi>Screen is bowed or warped. <LI class=h_mi>TV shuts off after powering on. Power light will blink. TV may also make a chirping noise. </LI></UL>Here are some <A href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target=_blank><FONT color=#0033cc>photos</FONT></A> of convergence problems.<BR><BR><IMG class=h_mi src="/uploads/images/42D3683.jpg"><BR><BR><IMG class=h_mi src="/uploads/images/7859B01.jpg"><BR><BR><IMG class=h_mi src="/uploads/images/E87380C.jpg"><BR><B>Here is a quick tes</B><B>t....</B><BR><BR>Using your original remote go-to the settings menu then goto the convergence section.<BR><BR>Try to adjust the red and then the blue convergence.<BR><BR>You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight. <BR><BR>If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem. <BR><BR>Note: If you TV has as flash <A href="http://www.fixya.com/#" target=_blank><FONT color=#0033cc>focus</FONT></A> or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix<BR><BR><B><IMG class=h_mi src="/uploads/images/69189A5.png">CONVERGENCE SOLUTION<BR><BR></B>You can see some more examples and find a fix using this link on Fixya <A href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull" target=_blank><FONT color=#0033cc>http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull</FONT></A></SPAN>
Aug 28, 2010 | Hitachi 53UDX10B 53" Rear Projection...
HDLP50W151 50 in. Rear Projection HDTV Television: have a 48 inch rca projection tv and the picture i...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
I have a 57 inch rear projection t.v. the color looks 3d and the screen looks warped. the t.v is about 10 years old but i would like to fix it myself if i can. please help.
  • Screen looks 3D
May 15, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Multi-point convergence -- Lower left quadrant of screen distorted. Red ok. Blue arched up and then done to normal in Lower right quadrant; left-right adj moves vertical gridline but is s-shaped. Blue...
Look in users manual or internet you should find how to access service mode, this is different from regular setup CONVERGENCE, this involves getting into changing parameters to tweek convergence, even after amps are changed. These projection tv's are known for loosing convergence if bumped, moved and amps go bad in time.
Jan 03, 2010 | Pioneer PRO-520HD 53" Rear Projection...
I have a Mitsubishi WS-65809 Rear projection TV the fisheyes or bent screen.
Try to describe problem better----is picture concave or bowed with colors out of place or is is just not straight?
If in doubt go into customer menu and select convergence and then advanced(instructions will be on screen) it will bring up a grid of lines--what you are looking for and I need to know is is the grid not square or are there red or blue lines with or without a bow in them?
The more you can tell me the better the chance I can help you--I am in California and will be here for the next few hours.
SD TECH
Oct 27, 2009 | Televison & Video
Have a 53" Hitachi HDTV that bows at the top and the bottom. I was told one of the transitors or transformes blew. I also do not have the regular magic focus just the static focus now. I tried to alli
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 03, 2009 | Hitachi 53FDX20B 53" Rear Projection...
Replaced ic's but green is still seperated from the blue and red
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 14, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Panasonic projection tv
  • Screen looks 3D
Sep 08, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Convergence
Did you remove 1 leg of each resistor out of circuit when you checked the resistors? sounds like thier is still one resistor open or maybe one of the new IC pins need abit more solder.
Apr 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
80 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
