Question about Frigidaire Laundry Optional Pedestal APWD15W
My Frigidaire washing machine keeps pausing - Frigidaire Laundry Optional Pedestal APWD15W
  • 35 Answers
Make sure the door switch is being made. Tap on it during the pause and see if it starts back up. At what time did it start pausing? Is this a new problem. Did anything happen before the problem began? If it's not the door switch and it's not suppossed to do that it might be another switch or sensor that's the problem.
Posted on Sep 30, 2010
5 Suggested Answers
chris0fer
  • 5 Answers
SOURCE: Agitator
Yes, it is normal. ;)
Posted on Jun 19, 2008
SOURCE: My Frigidaire Affinity washing machine says it
my affinty washer is stuck in pause mode
Posted on May 02, 2010
SOURCE: frigidaire affinity washing machine pause error
Because our machine was new and covered under warranty, we had a maintenance person come out three times for this issue, but the only solution he could provide was to use less soap. Apparently, too much soap disrupts a sensor. So, if you let the machine run without adding any more soap, it will (theoretically) fix the problem. And this solution did work, to a certain extent.
Even though I started using much less soap, the problem is still persisting. For awhile, I was successfully able to fix it by running a few cycles without soap. Now, however, it just won’t work. Maybe others will have more success with this solution than we did.
At this point, the washer is no longer cover under warranty and our best solution is to buy anything but a Frigidaire or related Electrolux product.
Posted on Aug 21, 2010
SOURCE: Frigidaire Affinity keeps pausing mid cycle.
there is an access panel on the back of the unit. 6 screws and on the bottom is a rubber hose that comes from the tub. inside that rubber hose is a filter cup. i have the same unit and mine did the same thing. took it out pulled clog out put it back together. works like a charm. hard to get at but you can do it. use a drill with a phillips head to make it quicker. Also have pliers and a pair of channel locks. Good luck and it aint the Timer TRUST ME
Posted on Nov 24, 2011
Why did it continue beeping nine times after the pump was unclogged and it was unplugged over night?
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
https://www.youtube.com/watch?v=gP51k2bhbbg
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... How To Replace .
Nov 19, 2015 | Frigidaire Washing Machines
Why does it keep pausing during cycle?
Hello friend, thank you for the post!
I understand that your Frigidaire washer, ATF6000es, keeps pausing during a cycle. Generally that means there is a disruption in the cycle. I would try resetting your appliance, unplug the power cord or flip the household circuit breaker, for ten minutes. If that does not resolve the issue it could be a problem with your control board or wiring harness within the washer. I would recommend having a technician come out to the home to diagnose and repair the appliance. Hope this is helpful. -Matt
Jul 31, 2014 | Frigidaire ATF6000ES Front Load Washer
Pause lock keep showing up on screen
Hi Lance - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Sep 16, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire front loading washer keeps pausing during sanitize cycle
Sounds like the unit might be sudsing up too much or something is not allowing the sensors to operate and advance to the next cycle. Contact your purchasing dealer and have them come out since it is so new and under warranty.
Jul 30, 2012 | Frigidaire Affinity FAFW3577K Washer
Keep stopping pausing
If you leave the machine to itself, will it go through the whole wash satisfactorily? If it does, then the start and stop is designed into it. What it is doing is stopping and reversing the washing action. That is so the clothes will not wind up in a long rope shape, like the winding up of a towel like you use to do to a towel to snap your bother or sister in the showers or at the pool. It UNWINDS the load... It goes a few turns one way, then pauses, then a few turns the other way and pauses. Hope this helps..... 2529817.gif
Nov 27, 2009 | Frigidaire ATF6000ES Front Load Washer
Pause Error - Frigidaire Affinity LTF6000ES0
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
May 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
625 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
