Question about Electrolux C101 Bagged Canister Vacuum
2100 comes on but will not keep running, I have changed filter and bag.
  • 694 Answers
The dial on top of the machine should be set about mid-point. If it is, then turn until the small dot and the arrow are lined up. If this doesn't help, turn all the way around so large dot and arrow line up.
2. Detach hose from vacuum. Turn on. If it continues running, place hand flat against the intake. If it shuts off immediately, there's probably a problem with the "Control Valve Assembly". This is a part that can be purchased at your local Aerus Electrolux store. I highly recommend allowing them to replace it rather than trying to yourself.
If you don't know where the closest store is, go to aerusonline.com, click on "store locator" button at bottom of page, type in your zip code and click on the find store button.
If your vacuum runs fine without the hose attached, then check hose and power nozzle for a clog.
Posted on Sep 30, 2010
Testimonial: "Thank you for your input, it appears to be the control valve, I'am taking your suggestion and going to a repair shop."
What does it mean when my electrolux 2100 vacuum's protection light is on and the vacumm won't start
hellllllllo.......in short....youtube....."is your electrolux not turning on" [a] bag sensor [b]carbon build up............tkx....g.scott
Sep 25, 2014 | Vacuums
How do i get the funky smell out of my 2100 electrlux
Hi, it's Allie from Crucial Vacuum!
Vacuums are supposed to help your home smell better, but when they don't there is definitely something wrong. Odors in vacuum cleaners can be caused by several things. If the vacuum is a bagged unit, replacing the bag often will help in minimizing any odors from debris caught inside the bag.
Keeping your unit's filters clean and replacing them periodically will also reduce unwanted smell in your unit. Washable filters are recommended to be washed at least once a month and replaced, as non-washable filters, every 3 to 6 months.
Finally, if your unit is a bagged unit you may benefit from using a scent tablet that you can put inside a new filter before running your unit. You can try these fresh scent tablets: http://www.crucialvacuum.com/vacuum-scent-tablets-10pk.html
You can purchase direct your replacement filters and parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=LE-2100
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Sep 15, 2014 | Electrolux Vacuum LE-2100 Canister Filter...
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
Why does my change bag light keeps coming on even after i change the bag, on my electrolux 2100?
The bag or main vacuum switch could be malfunctioning and in need of replacement. Hope that helps!
Jun 26, 2014 | Electrolux Vacuums
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Jul 06, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Where is the reset button on the electolux 2100
There is no reset button on the 2100. If it shuts down, the indicator lights will tell you why. If it has been overheated, there is a self-resetting switch which will shut the motor down and the light will come on to indicate that particular problem. When you turn the machine off and then back on, it should re-start provided you have given the motor ample time to cool down. This will not solve the problem as to why it overheated in the first place. There are also lights and auto-switches that will control full bag and no bag. The machine will not run with no bag and a full bag will cause it to run for a few seconds and shut off.
Mar 20, 2008 | Vacuums
Electrolux 2100 canister vacuum
check the hose by putting a penny in one end and see if it comes out the other, you might have a possible clog, lux canisters are designed with a fail safe
Jan 19, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux C101 Bagged Canister Vacuum Logo
300 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
