Question about Dayton Heating & Cooling
Where are the oil ports on the Dayton 1HAL3 exhaust fan
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 141 Answers
If it has oil port they usualy have a yellow or red plastic plug you pull it out and oil the motor if it an older motor they may have allum plug
Posted on Sep 30, 2010
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
I have a hanging Dayton in garage pilot lights fine furnace fires up runs 6or7 min. then burner and pilot go out
Does unit fan come on ??? Is flue clear as most units have a safety klixon if exhaust not venting properly.
Nov 24, 2012 | Dayton Gas Furnace Heater
Wiring for a Dayton motor 6k857L
Wiring diagram appears on side of motor.
This motor is rated 115Volt.
Hot and Neutral wires connect to main terminals.
Connect other wires as shown on label.
For example there can be yellow, black, blue and white wires.
Dayton manufacturing is owned by WW Grainger.
Contact Grainger.
http://www.grainger.com/Grainger/static/help_contactus.html
Oct 12, 2012 | Dryers
Model # 6ale8 when the fan is run it gets a high bird like sound to it .it sounds like needs oil
Most motors now a days dont have oil ports you have to replace the whole motor.
Jun 30, 2011 | Dayton Heating & Cooling
Creme colored know shaped like a whistle that the interior broke from the wall control on the Dayton Fan--where can I order a replacement?
If you cannot mend it otherwise or fix it up with a tinkering then the part is available only with Dayton.
So check up with their dealer or the serivce outlet if this is closer to you , or search the web for the nearest centre mentioning you area of resisdence.
Sep 24, 2010 | Dayton 7F67 Shuttered Attic Exhaust Fan...
I have a dayton kitchen exhaust blower mod no. 4hz65, 1/25 hp, 1550 rpm, 115 volts, 1.5 amps, 8 inches. it does not seem to do the job, do i need a stronger one?
Remember air will only move as fast as the size of the exhaust pipe in relationship to the fans ability to push. Make sure yours is the proper size for the fans volume.
Jul 07, 2009 | Dayton Exhaust Blower to vent your grow...
Heater will not light
It doesn't seam to get fuel. It may be as simple as a clogged fuel filter.Try cleaning the filter or replace it.
Apr 12, 2009 | Dayton E48 Oil Filled Utility Heater
DAYTON 210,000 BTU OIL-FIRED HEATER WON T LIT UP
You write "FUEL SPRAYING AND FAN WAS WORKING"
If the fan was working, but the fan is not working now after replacing the whole kit, then something was installed incorrectly during the installation, possibly the rotor gap or rotor thickness is not correct or vane/vanes installed 90 degrees off.
Dec 08, 2008 | Dayton E50 Heater
I have a Dayton gas heater Model 3E225
Does the main blower fan kick on? Also, if the heater is vented outside via a flue pipe, there may be a small (about 3 or 4 inches in diameter) vent fan that kicks on to ensure the exhaust fumes are evacuated through the flue pipe. If there's a problem with that fan, the burner won't light either.
Nov 20, 2008 | Dayton (3E379) Heater
DAYTON 4LX48 HANGING HEATER
Exhaust is restricted or crack in heat exchanger. Get someone to look at it!
Feb 13, 2008 | Dayton (4LX41) Heater
Heating & Cooling Logo
133 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
