Question about Motorola Mobility V600
Keys or bottom half of phone lights up, but top half does not. Can no longer dial or use the phone. I was talking on it, when it just dropped my call and "locked up". I shut it off and went to restart it and now only the keys light up. The phone is old, so I assume it's just finally gave out. However, I had some important text messages from family members that I wanted to keep. If I can't fix the phone, any way to get the text messages off of it?
  • 30 Answers
Time to get a new phone. You might be able to find one on CraigsList.
Posted on Sep 30, 2010
My phone showing a message push to talk is off.switch on now.but i got hang.please help me
Might your push to talk or PTT button had stuck up or the switch itself,if this feature is not activated in your country,better remove the switch if it is not working anymore,resoldering the 4 terminal of that switch and detaching it will solve the problem, message will no longer appear on screen as well it will not hang anymore that affects the other keys,if you can provide replacement,much better.remove front cover and unscrew 2 screw on the top,release the side clips of the keypad board located at the back housing,now unsrew 2 screw at the bottom,lift up the entire module and start working on the ptt switch. Otherwise, bring it to a service center to fix this problem.
Sep 10, 2011 | Nokia 6070 Cellular Phone
How to set speed dail?????
1. Go to phonebook.
2. From the drop down menu at top-right side of the screen, select 'Favourites'.
3. This should open up the list of keys from 2-9. Tap on any one of the digits and assign a contact to that number. 1 is reserved for voicemail so you cant assign it to any contact. Your speed dial is now set.
4. To speed-dial, go to the numeric keypad from the main menu, and keep the key pressed for a longer duration. ( for example, number 3)
Jan 01, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
No sounds . no voice . no noise on numbers. cannot hear people talking. cannot hear voice mail. will ring. cannot answer
take it your phone has been dropped a couple times? lol..
Does the screen work normally? either way if you havent fixed this yet (seeing as this is 23 days old as i post) your going to have to take your phone apart. you can try the easy way and take the bottom half apart but dont try to take the screen off. there is a flimsy ribbon cable that runs from the top corner of the bottom half through the hinge that is easier than heck to break. after you get the bottom half apart try pressing down on the plug of it to see if it is loose then try your phone again.
the reason i asked if the screen is working is because that one cable usually handles everything in the top half and when one thing in an electrical device (expecially a small one that has a bunch of tiny components) doesn't work there can be no telling what else will go with it
Nov 12, 2010 | LG VX8350 Cellular Phone
How do we change the phone numbers on the speed dial
Feb 27, 2010- Speed dial numbers 001 -255 (256-279 are personal speed dial entries) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
Press the show key (top right arrow)
The display should say speed dial#:--
enter in the speed dial number you wish to program.
Press the show key (top right arrow) .
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
Apr 16, 2010 | Nortel T7316E 2-Line Corded Phone
I dropped my phone today and now it wont work
When you dropped it you loosened up the digitizer connector which is number 2 under the screen. Open your iPhone and resit that wire firmly back in. That should fix the digitizer not working.
If its a 3G just unscrew the 2 screws at the bottom and use a suction cup to remove the screen. Easy. But if its a 2G then Good Luck.
Jan 29, 2010 | Apple iPhone Smartphone
How to multitask with the samsung impression ? on the directions there is a ''key'' you are suposed to push to multitask..but i dont see the button anywhere ..while on the phone..while on the web..? help!!
At the bottom of the Touch screen are three icons: Dial, Contacts, and Menu. Below these, on the phone case, are three keys: Talk/Send, Back, and Power/End. Below those is the microphone. On the left side of the phone are the Multitask and Volume keys. On the right side are The Lock key and the Camera key.
Jan 14, 2010 | Samsung SGH-A877 Impression Cell Phone
Brushes not spinning in Wash mode
take apart the unit at the top (Behind the cleaning fluid container) Inside there is a wire coming up from the motor at the bottom of the unit. This can come unlpugged no longer powering the scrub brushes. Simply slip the wire back on the plug.
To open: remove all visible screws from top half of machine. Remove the rubber mode dial by pulling off, and remove screw behind that. Pull the front off, and the power plugs are located right on the inside of the machine by the mode dial
May 04, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
BLANK
the problem of your phone is the flex cable, just go to your nearest repair phone shop if they have a spare of flex cable for your phone.
peace!
Nov 27, 2007 | LG PM-225 Cellular Phone
BLANK
there is a ribbon connector between the bottom half and the top half of your phone, this carries all the information for the top half ie picture & sound etc. It is more than likely that this cable is damaged someway. you would need to disassemble the phone and check the plastic ribbon carefully to be sure.
Jul 02, 2007 | LG PM-225 Cellular Phone
Open Questions:
See all Motorola Mobility V600 Questions
Motorola Mobility V600 Logo
16 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
