Question about Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM Combo Drive
  • sanjay06aug Jan 10, 2009
    POWER CALIBRATION ERROR in samsung dvd writer
Yeah I had the same problem.. SAmsung drives are very unreliable . The first problem is the drive tray which will open and close or open and never close or close and never open . I even tried lubricating inside the shaft.. no luck.... try other drives when u buy new one.
Posted on Aug 01, 2008
Power Calibration error indicates that the drive hasn't been kept clean and is unable to guarantee a good write to disc...
I recommend a wet and dry CD/DVD Cleaner disk with Alcohol on the wet side (Like Tape Head cleaner liquid) and let it dry for a minute then run the disc again... if it still happens the drive is on its way out.
Posted on May 28, 2008
With Samsung DVD Rom SM352N RWcombo can a write DVD ?
This model Samsung is a combo DVD ROM and CD read/write drive.
It can play DVD discs and play CDs and burn CDs BUT cannot burn DVD discs.
Oct 10, 2012 | Computers & Internet
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
Jan 28, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
powe calibration error reffers to lens laser power
in other words the laser doesn't have enough power to write CD/DVD at specified speed
try to clean the lens (there are special CD-s for that)
and try to burn the cd or DVD at slower speed
but slowly your cd writer is dying
Jul 08, 2009 | Sony Computers & Internet
Had a drive that did the exact same thing myself. You'll need to replace the CD drive. It's cheaper than having it repaired.
May 30, 2009 | Intel Computers & Internet
Dvd recorder problem - model CMWR10D6
Might be the PCA aka power calibration area portion of the lens that reads that might not be reading it. Here is a little bit more info on PCA.  Power Calibration Area of a recordable or rewritable disc that precedes lead-in and the PMA, where the optimum laser power level for writing can be determined by a recording drive
Nov 07, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Jun 13, 2007 | HP DVD940e Burner
Cd dvd combo drive
Can you be more specific about which error messages you are getting? This is important because it will tell us whether the laser or motor is burned out, or if you are just being stopped by copy protection.
Sep 25, 2006 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM Combo Drive Logo
608 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
