Question about Whirlpool Refrigerators
Refirigerator overheating - Whirlpool Refrigerators
  • Whirlpool Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 30, 2010
Repair manual for magic chef refirigerator, model CTB1720ARW
Magic Chef is now owned by CNA International. Mark St., Wood Dale, IL. You can contact them at: 1.630.238.9800. They may be willing to send you the manual that you need (see below how I do it).
For repair I have found an amazing online resource to help me fix my own appliances. It is called Repair Clinic and can be accessed at this URL: http://www.repairclinic.com/
The Repair Clinic (no I don't work there and I don't own stock) has troubleshooting directions on there searchable website and suggested causes for your units problem (search will require part number and you choose which problem closely resembles your situation). The best thing is they have very good videos on how to do the repair (DIY). I have had great success fixing my appliances with no previous experience (I am handy with fixing things though).
The manufacturer probably will send you a manual if you are chatty and talk about how great their products are. I have had success with this in the past.
Other than that I usually will do a online search with the specific thing I am looking for... In this case it would be, "free manual for my magic chef refrigerator freezer - model CTB1720ARW". I found so much info on just typing in the CTB #.
Have you tried Sears Direct? or the current owners of Magic Chef which I mentioned above?
Hope this will help you.... cmilton111
Jul 18, 2014 | Refrigerators
I have a Kichenaid Refirigerator Model# KSRB22FKBL04 it is not cooling or freezing. Light is on, there also a running sound and sometimes no sound but run again but still not cooling or freezing. I need a...
Are both fans running, in freezer and in back? Remove rear panel on back of unit. Check to see if noise is coming from compressor area. If it is you either have a bad start device or a bad compressor. Use your model number to look up and order a new start device here, the cheaper of the two. est. cost at $25-45
Mar 24, 2011 | KitchenAid KSRS25CNBT / KSRS25CNLK /...
At work one of our units gets too cold in the fridge and the tenant says it freezes her eggs.Do I need a new t stat?
if the eggs are placed directly where the cold air from the freezer enters the refirigerator section, they would freeze. The temp of air coming into the ref. sect. is about 12 degrees, by the time it fills the ref. section it is around 38 degrees. try moving the eggs to a middle shelf (just not on the top shelf), If that doesn't work then I would replace the thermostat.
Mar 05, 2011 | Whirlpool ET1MHKXM Top Freezer...
Dispenser does not dispense water
is the refirigerator getting water,if so i suggest the main water dispensiour is not fully back into the water dispensor,there is little that can go wrong on this type of machine and i still suspect the dispencer is not fitted proply.adrian,,,,
Dec 04, 2010 | Kenmore Refrigerators
The icemaker in my 10 year old side by side Galery series refirigerator doesn't work. How can I turn it off so that it doesn't use water every 15 minutes or so?
lifting the arm on the side of the ice maker will prevent the ice maker from cycling, assuming there is nothing wrong with the ice maker. However, simply turning off the ice maker may not prevent any problems you may be experiencing
Oct 01, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refirigerator emitting electrical odor
the relay on the compresser is going bad pull fridge out and unplug and remove back panel smell around compresser if that is where smell is replace relay
Apr 13, 2009 | Refrigerators
Maytag refirigerator not freezing/cooling
Turned out to be a bad circuit board on the back of the unit which caused the refrigerator/freezer to freeze up. Replace it, thawed the refrigerator compartment, and it works fine. Cost me less than $200 including service call.
Jun 22, 2008 | Refrigerators
Locate evaporator condensate drain tube
next remove the evaporator fan cover and under the evaporator will be a silver tray with a hole in it this is the drain for the defrost systems and some times they get frozen the best way to clear them is with a eureka 350 hand held steamer you can get at Lowe's fairly cheap you can also find about 1000 other uses for it a round the house
Jan 26, 2008 | Refrigerators
Needs instructions to remove the front panel to replace the microswitch near water dispenser arm
Kenmore model#10658562891 side by side refirigerator.
Need instructions on how to remove front panel to check or replace the heater that keeps Ice from freezing in the Ice chute.
Jan 04, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Refrigerators Logo
51 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
