Question about Kodak EasyShare C743 Digital Camera
I put new batteries in (several different sets) and the camera will not come on at all. The lens is stuck out also.
    Brigadier General:
  • 3,006 Answers
Your camera almost certainly has a lens error. This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Kodak service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Posted on Sep 30, 2010
The camera lens is stuck and thats causeing the camera to not come on
There are some things you can do to try and "free" the lens. If it's just dirt or sand or dust jamming the tiny gears that drive the lens in and out, you can sometimes blow it out with compressed air. Sometimes you can put the camera down on a towel, and press gently (while pushing the on/off switch), and sometimes the gears will catch. Here is a good blog of different things to try on cameras with a lens error or stuck lens. If you have bumped it and broken a gear, it's expensive to get it repaired, so get an estimate first, should you decide to do that. Here is the web blog:
Good luck, hope this helps!
May 05, 2010 | Kodak EasyShare C533 Digital Camera
Lens won't retract
some cameras you can just push the lens in.
Jun 29, 2009 | Pentax Optio M20 7MP Digital Camera with...
"Lens error - restart camera" message, but won't restart
I just had the same issue when one of my children drop the camera. I'm not wanting to break anyone's camera but I was able to open the lens cover and pull the lens out and then turning it on it retracted and worked just like it should.
Apr 19, 2009 | Canon PowerShot SX100 IS Digital Camera
Lens and camera are frozen or stuck
if the lens is stuck out , twist the lens to the left with your hand and it should go back in. thats what happen to mine and i fix it . hope this helps you.
Apr 10, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
My camera will not come on. and also the lens is opened out and will not go back in, i have put several new batteries in it, and if i put batteries in it and close the battery door, and push on, the light...
my camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Camera wobn't turn on & lens stuck in out position
My camera stopped working during a wedding. The lens is stuch out, it will power on, but right after turning on, it beeps 3 times, then turns off.
Hope we find a solution!
May 14, 2008 | Samsung Digimax A7 Digital Camera
Lens stuck open
try little rubbing alcohol around outer surface of lense this should loosen up the sticky ness of it
remove the memmory card and turn on this should reset camera
May 13, 2008 | Samsung Digimax 4500 Digital Camera
Digimax samsung s500 beeps 3 times lens stuck wont stay on
Mine got stuck with lens out. The batteries were new so I never imagined it could be the batteries, but they were cheap ones so I recharged a pair of good ones and once I put tried them on it worked just fine again. Conclusion, the "new" cheap batteries had only enough energy to turn it on and then they couldn't give it enough energy to make it work anymore and that's why I couldn't retract the lens or even turn it off properly. So in your case, try using a couple of good and new batteries.
Dec 14, 2007 | Samsung Digimax S500 Digital Camera
Same problem
your batteries are dead.
Oct 27, 2007 | Samsung Digimax S500 Digital Camera
Jammed camera
A temporary fix to power up is to press the menu and power button at the same time. When the lens is extended and it beeps, on my camera , the lens is *stuck* Give it a gentle tug , then try the power button again
Oct 19, 2007 | Samsung Digimax S800 Digital Camera
Kodak EasyShare C743 Digital Camera Logo
23 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
