Question about Insignia Digital-to-Analog Converter for Analog TVs
No signal I have everything set up right and my antenna picks up great. But when I try to set up my dtv box all I get is no signal. HELP
  • John Hickey May 27, 2008
    I have the same problem. Took it back to Best Buy, and it worked fine. All the connections are right, but still I get no signal. I tried it on 3 different tvs
This may be a stupid question, but are these converter boxes only for use when you are hooked up to an antenna. I have Comcast cable and called them. I was told that even though I have old tvs that I don't need this box since my tv is hooked directly to cable. They said that Comcast's signal takes care of this problem and in 2009 I will see no change.
Posted on May 30, 2008
I had a similar problem. I then noticed that my antenna has a RG6 cable. This is good. My TV requires RG6 and requires TV(RF) cable that is also RG6. Insignia comes with a TV(RF) cable that is RG59! That's a cable with a smaller diameter center connector than RG6. Consequently, when that smaller RG59 was run from the converter box to the TV's larger RG6 female connector, no signal connection was completed since the center connector made no physical contact with the TV's female connector. I found a RG6 cable to replace the RG59 cable supplied with converter box and all worked then. Also, you must force the antenna's RG6 male plug into the smaller RG59 female connector, but it'll make it.
Posted on May 29, 2008
Moved into house, used auto tune feature on analogue tv get poor reception on everything bar two channels, bought DTV, autotune gave same result, with no digital channels picked up at all. Obviously an...
Yes its antenna problem?maybe your house too closed signal your antenna is getting hard to find signal for your TV.
You must use a Outdoor Antenna to widen your signal range.
And also i suggest that you move you antenna outside your house or at your roof to be able to enhance the signal for your TV.
Hope my solution will help.
Jul 03, 2011 | Computers & Internet
How do i get a truequest digatal indoor antenna to pick up best
Hi, Unfortunately with most indoor DTV antennas you will need to move the antenna by hand for the strongest signal for each channel if, if one comes in worse than the others. If you have the set top DTV converter they sometimes have a signal strength meter to help with this. They also sell a DTV antenna that moves by itself for best reception for each station. I think it's about $60 at the Radio Shack. thanks for asking FixYa, I hope this was of some assistance, good luck-Prodzilla
Apr 18, 2011 | Televison & Video
Why won't my new Vizio DTV work on an antenna without the digital box?
Do you have the antenna aimed correctly and the correct antenna for the distance between your location and the stations? Check antennaweb.org and tvfool.com for the directions to the stations you should be able to receive. Antennaweb assumes an external antenna and is very conservative in the station list. TVfool gives the stations you should get with various different types of antennas. Tall trees and buildings will block signal strength so consider the environment around you.
With digital signals, if you do not have enough signal strength for a given tuner, the channel will not come in. An amplifier may help you get the signal, particularly if the signal is shared to several devices. Failure of an amplifier or lightning surge protection can stop the signal from reaching the TV. A surge through the antenna can damage the tuner.
A damaged cable can also be a source of a problem. Check the outside portion of the wire as well as the interior wires. Replace any that have damaged insulation or ends.
For this TV, if you have done a channel scan with the TV set to the Input TV/DTV, and the Signal Source set to Antenna. Turn the antenna and then set the Additional Scan to On. (Menu > TV > Channels > Additional Scan.) Then do another channel scan.
If you need a copy of the manual, see: http://www.vizio.com/m220va.html#support .
Jan 22, 2011 | Vizio M220VA 22 in. LCD HDTV
I can't get FOX on my converter box--what is the channel # for FOX?
It could be your antenna. Some retailers sold consumers UHF-only outdoor antennas and not VHF/UHF combo antennas. Other outdoor antennas may not have a power boost included for the VHF antennas (rabbit ears). The new DTV signals from stations are now broadcasting in lower power signals than before June 12.
Outdoor Antenna
KMSP/FOX 9 and KARE 11 both broadcast on VHF signals. WCCO and KSTP broadcast on UHF signals. You will need a VHF/UHF outdoor antenna to pick up KMSP and KARE 11 and also get all the other channels.
Indoor Antenna
Check your antenna to make sure it's a UHF/VHF antenna. You may need an indoor antenna that has rabbit ears -- that is the best way to get KMSP/FOX 9 reception on your TV. Your antenna should have a power boost to amplify the VHF signal if you are having trouble getting FOX 9 or KARE 11.
What Antenna Is Right For You?
Need help locating the proper outdoor antenna to receive your local television broadcast channels? Based on geographical maps and signal strengths, AntennaWeb.org locates the best antenna for you, whether it's a home satellite system, high-definition television (HDTV) or a traditional analog set.
Make sure you antenna is pointed toward Shoreview, where FOX 9 transmits from.
CALL FOX 9 FOR HELP: 952-944-9999
Apr 07, 2010 | Televison & Video
Tv wont pick up channels
Have you been into scanning settings and set to DTV , it seems like you are either on ATV or have a bad Antenna connection. If signal is weak from your Antenna you can add a booster in the section between your wall socket and the TV. You cannot use Satellite dish connections to receive either ATV or DTV signals without a set top box ...
Dec 05, 2017 | Coby TF-TV1901 19 in. LCD Television
I can't scan DTV channels on my vizio 52''
do you have antenna or cable? if you have antena hook directly to the coax, go to menu, TV, tuner and pick antenna and scan. If you have cable hook directly to your coax repeat the previous step but pick cable instead of antenna. Notice if you have a cable box, you will not need to scan for channel since it will be on channel 3, 4 or any other input you may use.
Jun 20, 2009 | Vizio L32 32 in. LCD HDTV
Built in tuner not working since digital transition
I do not know if you will get this message but if you do. Here goes. The protron PLTV3250 does indeed have a digital tuner that can be used with an over the air antenna. You need to push "source" on the remote until DTV is selected. With this selected and your coaxial cable from your antenna hooked up to the digital connector (not analog) on the back of this tv you can then press Menu and you will see a totally different looking menu that you are probably not used to seeing and then from there you can do an auto scan for the digital channels and it works great. I have rabbit ears hooked up to this Protron PLTV3250 and this has a beautiful picture. Far better than the picture I get from just the standard digital Directv receiver. You do not need a seperate digital tuner box to use with this TV. It does indeed have an ATSC digital tuner and it works great. You probably are selecting Source "TV" in the menu and that is not what you select for this TV to use the Digital Tuner. You need to select DTV from the source menu. Good luck and please let me know if you already knew this or if this helped you. Thanks, Tom
May 27, 2009 | Protron PLTV3250 32 in. LCD Television
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
Oct 17, 2008 | Emerson EWV603 VHS VCR
I installed an Insignia converter box, Model # NS DXA1, and it worked fine. I did not realize it would decrease the size of my screen, so I disconnected it and figured I would try again later. I have...
Ok, you have 2 issues:
1) Consult the manual page 8 for setting the 'type' of TV either 4:3 (Standard) Aspect Ratio or 16:9 (Widescreen) Aspect Ratio. Then the Picture Size for 'each individual station' can be Selected via the button on your remote in the upper right hand corner. It's labeled "ZOOM". As you push the button, it will rotate through the size types available. If you have an older standard TV (4:3) and want to fill the entire screen, then select 'CROPPED' for every channel(my preference). You will only see a center cut of the entire picture and will lose some picture on either side, but most of the action will remain in the center of the screen. If you select "SET BY PROGRAM" then some programs will appear in their actual Aspect Ratio so some will be in 16:9 and some in 4:3. More and more programming will end up being 16:9(the new DTV/HDTV Standard). Set this to your liking.
2) This is going to take a bit of explaining:
Depending where you live geographically, whether in a home or an appartment, and the Type of Antenna you are using, your reception problems may be affected by a combination of these. The FCC was not completely forthcoming in letting the public know that the best way to get DTV signals(and Analog) is with an Outdoor Antenna and that indoor Antennas may be useless. Plus most of the 'fancy HDTV touted" Indoor antennas are various degrees of bad when it comes to VHF reception. The new system they(FCC) selected has lowered significantly the power at which TV stations broadcast. So most people using Indoor Antennas may not get all of their favorite channels even with the best of indoor antennas and doing everything right with the 'placement' of that antenna. The same goes for and Outdoor Antenna. Just because you have a premium outdoor antenna and it has worked perfectly for the last 10yrs.(of more) with Analog TV, DOES NOT MEAN THAT it will work perfect with DTV for a few reasons:
1) DTV Signals, because of their lower power, require very deliberate placement of an antenna. Just pointing it in the right direction is not enough. DTV signal reception is a bit like 'Swiss Cheese' meaning if your are getting poor results and think that rotation will fix it, you may be wrong. If you are in the 'hole' and rotate, you are still in the hole. Sometimes moving your antenna a couple feet laterally can make a huge difference.
Why? Because the direct DTV signals coming from the TV stations are in the Kilowatt range (analog was usually more than a million watts!) They have now become more sensitive to interference from the back and sides of your antenna. Some sources of interference can be a reflection of the same signal off of a nearby tower or building which cancel some of the direct signal resulting in low or no signal. FM Radio transmissions, an Analog TV station from Canada(they don't go digital until 2010) operating on the same channel as your favorite Channel's new channel assignment can inject so much noise that your tuner cannot process it. Remember, runnig through just about every neighborhood are many other Wireless/Microwave Services: Phone, Internet, TV, Paging Systems, etc.. These, too can ave some affect.
So by moving your antenna to a position that I refer to as the "Sweet Spot", you are allowing your antenna to get more of the direct signal and 'de-tune' the unwanted signals from the back and sides.
Why did the channels you found before not show up the next time? Well, based on your current antenna's position and the signal strength its receiving from those stations, the level may have dropped off due to some of the above. Every DTV and Converter Box has a 'lower signal level cut-off point', meaning it needs so much signal before it cuts off. Because DTV either gives you a perfect picture or its gone, the old method of looking at picture quality to make sure your antenna was placed correctly is not valid. So the maker of the Converter Boxes put "Signal Strength Meters" in every box. Get to know where this is. It is your new best friend and is the only way you can be guided when placing your antenna. It can usually be accessed by pressing a button on the remote labeled :"SIGNAL or METER" and sometimes "DISPLAY or INFO". Some Boxes, like many DTV Sets, require you to go into the menu settings to locate this feature. Usually the sinal strength is indicated by a RED, YELLOW & GREEN scale and may have a % indication. To have reliable pictures, you should be above 60% or in the GREEN Zone. If you are only getting less than 60% or Yellow Zone, you may see the picture break-up into little squares or 'Pixelate' as it is known. If you are in the RED Zone or less than 30% your Box or DTV will not lock and give a "NO or LOW" signal indication. It is normal to see the meter indication 'hunt' or move up and down a bit due to atmosheric conditions and the swaying of the TV station's Towers.
Gee, Can you tell that I explain this often? Yea, I work for a TV Station in Cleveland. This switch has generated more than 700 phone calls all of which I attempt to call back on a daily basis. The public needs to be re-educated on this new system and how to make it work for them. Every installation is unique. In many cases, it will require the help of a qualified TV Antenna specialist to find the "Sweet Spot". Those of you in Apartment buildings, and anyone that may be a shut-in or senior with limited help or finances, my heart goes out to you.
Hope this helps!
Sep 09, 2008 | Televison & Video
No signal converter box.
Why is this in the computer section?
Anyway, don't exchange the box just yet! First, can you access the converter's menu? Because mine automatically comes up with the "no signal, call customer service" message, but I can access the menu fine -- so the hook-up is not the problem. If you can access the menu, let it autosearch for you, because mine can't be used until I do this. If you get the "weak antenna signal message", refer to the user manual to find out how to check your antenna signal strength; if it's in the weak range, you have to buy a better antenna, most likely from the official source: http://www.accessHD.tv
You can always exchange the box and repeat the process. Getting the "no signal" message is a good indicator that you've hooked everything up right, especially if it's accompanied by a customer service number. You can email me at kalalkb@gmail.com and I'll try to help you troubleshoot the problem if you like. I'm up all night.
Jun 25, 2008 | Computers & Internet
Insignia Digital-to-Analog Converter for Analog TVs Logo
132 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
