Question about Fedders A6Y18F7BCOM Air Conditioner
Control board deffective/where i can find service center
  • 382 Answers
Dear sir '
please use blow link for know your nearest fedders dealer :
www.fedders.com/contactus.asp
hope answer the question
thank you
please vote!
Posted on Oct 01, 2010
Panasonic tc-21xy on after 5sec automatic off,what section or component is deffective?
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 02, 2014 | Televison & Video
Vertical lines on screen looks very bad
maybe your TV have a deffective LCD PANEL,cause those are the systoms of the deffective lcd panel..better to put your unit the nearest service cnter or well trained technician to do the job,,goodluck
Feb 25, 2012 | Samsung SyncMaster 740N (Silver) 17 inch...
I have Samsung HL-S5087W for about 5 years and it is turning off by itself-any suggestions?
i hope your TV is getting ''off '' by itself when you are trying to turn ''on'' - not when you are watching TV...........then following is the situation ..........IF LED IS BLINKING then---- usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective ..........IF LED IS ALSO OFF then on main board in power section area some component is deffective ... MAIN BOARD SHOULD BE CHECKED COMPLETELY........ so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore.....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact samsung service centre.........
Apr 22, 2011 | Proton MM2701VT 27" TV
When I open my RCA TV 25648 it shut down after a few second. Is there any way to fix it ? Thanks
IF LED IS BLINKING then............. usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective ..........IF LED IS ALSO OFF then on main board in power section area some component is deffective ... MAIN BOARD SHOULD BE CHECKED COMPLETELY........ so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com ) .....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact RCA service centre.........
Apr 21, 2011 | RCA F25648 25" TV
Will not turn on
if LED is blinking then following is the solution.....usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective ......if LED is not blinking then.....on main board in power section area some component is deffective.....MAIN BOARD HAS TO BE CHECKED COMPLETELY...... so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com ) .....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact philips service centre.........
Apr 20, 2011 | Philips Televison & Video
27f530t not powering on power to switch but not on
IF LED IS BLINKING then following is the situation..............
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective - so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 (US$ 12) - iam service engineer (computers, laptops, printers,etc) - bangalore - domlur - 09986222774 - sathyavijayasarathibabu@ymail.com - if you are in bangalore then you can call me for service - i think you are living somewhere in america /australia..... - problem is simple but i don't have any idea about EHT COMPONENT 's price & service charge in your place....... IF LED IS ALSO NOT BLINKING then following is the situation............fuse is gone due to deffective component in power section ....BOARD HAS TO BE CHECKED.............. so my suggestion contact near by TV service engineer or approach RCA service centre ....this problem cannot be solved by user unless user is a technical person, having idea about components (resisitors,transistors, diodes, ...etc), having tools like multimeter ,soldering iron , soldering lead ,flux, desoldering coil, etc....
Apr 14, 2011 | RCA 27F530T 27" TV
Blinking red light
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective - so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 to Rs.600 - iam service engineer (computers, laptops, printers,etc) - bangalore - domlur - 09986222774 - sathyavijayasarathibabu@ymail.com - if you are in bangalore then you can call me for service
Mar 26, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Olevia will power up for a few secs and then turn itself off
power supply board deffective..bring it to the service center for repair or inquire it to your dealer
Sep 06, 2010 | Olevia LT42HVi 42 in. LCD Television
Samsung TV is clicking and taking a long time to turn on
Hello gerijc, hi, The symptoms is probably caused by a deffective power supply circuit, and Im not sure it is serviceable by user. call your dealer first and ask if the TV is still on warranty, if not ask for service.
The service is removing the back cover, and gain access to the power supply board, replace the board with an exact spare and test. the board is available at service centers, check the phone directory or inquire about it on your dealer.
Jan 13, 2010 | Samsung LN46A540 46 in. LCD TV
Red circle and yellow tint in our white
If you have RED color that starts from Center of the Screen,(no red color on sides ) 100 % your light engine is deffective..
In order to solve this issue Replace Light Engine Control Board (also called Driver Board ) attached to light engine.
Good Luck
Do not forget to Rate!!
Dals123
Jan 03, 2009 | Hitachi 60V500 60" Rear Projection...
Fedders A6Y18F7BCOM Air Conditioner Logo
73 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
