Question about Briggs & Stratton Starter Briggs Stratton 394943 490420 494990
I have sears tractor with a briggs engine # 42E777 the starter would not engage when i tryed to start it so i picked up a new one on e-bay hooked it up an it dose the same thing turn the key over an starter spins but dont engage any info would be a great big help
  • 472 Answers
The Bendick's are bad or it may not be geting full power to it is your cabel good
Posted on Sep 30, 2010
Did a Tune-up, now the Starter just Free Spins, Bendix not engaging, How to Fix, without Replacing Starter?
Try the starter off the mower to see if the bendix works. See if there is any adjustment at the starter mount, play in the mounting holes.
Aug 29, 2015 | Craftsman Garden
I have a sears craftsman tractor,18 hp electric start. No. 917.254860. engine no. 422707,type no. 1522.01. briggs and stratton. engine won,t turn over. Replaced plugs,coil,carborator rebuilt to specs. New...
From your description it seems that the starter is not engaging to turn over the engine. First ensure all the connections of the thicker cables to the battery, starter and tractor frame are clean and tight. If starter motor is turning but still not engaging it will mean that the pinion on the starter motor is binding on the shaft. You can buy a new starter pinion gear from your local B & S agent.
To replace pinion, remove starter motor from engine, remove old pinion and put on new one and reattach starter to engine. If fuel & spark are right you should be up amd running.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Murray ridinglawn mower will not start..everything is new
sounds like you have a safety switch issue, i am the proud owner of 3 different Murray mowers, you have a seat switch, a blade disengage switch, and a clutch pedal switch, depending on model and year, unplug one at a time and re try, need anymore info, email me, niteman87@aol.com :) hope that helps,
May 23, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Briggs 14 HP Vanguard runs well until PTO is engaged
First thing u might want to check is the governor--Make sure the spring and linkage is hooked up properly and the governor is moving freely.
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Starter energizes, won't turn engine.
your battery is in a weak state also the solenoid is shorting out replace the solenoid
Jun 06, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Lawn Tractor won't start Craftsman LT1000 17.5 OHV
The starter bendix is not engaging properly the bendix pushes the starter gear into the flywheel gear when the starter spools up, it may need minor lubrication.
It sounds like the engine is not getting fuel as it should, the main jet may be restricted from varnish if she stumbles under a load especially if the plug tips are white after running for 1/2 an hour.
Remove the float bowl and clean the jet, make sure the fuel is still good, gas that smells like a library is more like varnish and less like fuel.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn Tractor Engine-Start Problems
Ed, I think that when all is said and done you will find that you have a defective STARTER MOTOR. If the BATTERY is at full Charge, and it takes a Battery Charger added to the Battery in order to get enough current to turn over and Start the Motor. I suspect the Starter Motor is defective.
I also have Sears Tractors with Briggs, three of them.
Also clean your Spark Plug when you service the Engine.
Good Luck!
Feb 03, 2008 | Karcher 2500 PSI Pressure Washer
Briggs & Stratton Starter Briggs Stratton 394943 490420 494990 Logo
278 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
