Question about GE 25GT240 25" TV
No jacks in the back
The GE 25GT240 only has a cable jack is there and adapter to hook up dvd?
    Brigadier General:
  • 6,966 Answers
This is a very basic TV with only a single ANT/CABLE/RF INput. If you intend to use a DVD player whose outputs are the yellow, red & white RCA, then you would need either:
1. an RF modulator similar to this one or
2. use an old VCR to accept the yellow, red & white RCA cables as INputs. The VCR would then have to be connected to the ANT/CABLE/RF INput using an RF patch cord. The TV wold then have to be tuned to either Channel 3 or 4.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 25, 2008
Old TV
I can assume the input for your tv has only a coax input to it. Meaning a threaded connector on the back. If so, first connect the Wii to the input of the dvd player, second, from the output of the dvd player, this is where your solution is needed. run a coax cable from the tv to the DVD player and at the dvd player you will need an adapter from your local Radio Shack or electronics store. It should be a female coax to RCA adapter (male Red White and Yellow).Red and white for audio and yellow for video. Post a pic of the back of the tv if this doesnt solve it for you. Good luck, fingers crossed.
Sep 07, 2012 | GE 25GT240 25" TV
NEED INSTRUCTIONS FOR HOOKING UP WIRELESS HEADPHONES FOR VIZIO TV
From the manual:
1. Plug the stereo audio cable into the headphone jack of your audio
source (e.g., stereo, TV, CD player, DVD, etc.). If your audio source
has two RCA output jacks instead of a headphone jack, use the
supplied Y cable to connect your headphones to the two (red and
white) RCA jacks.
2. Connect the other end of the stereo audio cable to the AUDIO IN
socket at the back of the recharging cradle/transmitter.
3. Connect the AC/DC main power adapter to the DC IN power
supply socket at the back of the recharging cradle/transmitter. Then,
connect the adapter to an electrical outlet.
Important: This power unit is intended to be correctly oriented in a
vertical or floor mount position.
Manual:
http://audiovox2.info/docs/common/AW772/AW772_OM.pdf
Jun 10, 2011 | Acoustic Research AW-772 Headphones
How do you hook audio speakers to a portable dvd player
I am guessing that by this question you mean using computer speakers with a 3.5 mm jack with a portable dvd player which might have a 3.5 mm jack or you could get an adapter cable composite audio (red and white) to a audio jack.
Hope this helps
May 03, 2011 | Sony Audio Players & Recorders
Can you connect earphones to this TV? -GE25GT240 Serial #943516018
There is no front panel earphone jack for this TV. From the owners manual I can't find the rear view of this television. If there are connections on the back for AUDIO OUT there will be two connections for an RCA type connector. All you need to do is to get an adapter (from Radio Shack) and plug that into the two Audio Out connectors on the back of your television and plug your headphones into that adapter.
I recommend this one: http://www.amazon.com/Male-3-5mm-Stereo-Female-Y-Cable/dp/B000I23TTE
If you have a 1/4 headphone connector (the old type) you can convert the 1/8 to 1/4 inch with this one. http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Delectronics&field-keywords=1%2F8+inch+male+to+1%2F4+inch+female&x=16&y=24
Apr 16, 2010 | GE 25GT240 25" TV
Whehe do plugs go on back of unit? have direct tv
First off, you need to hook up audio and video by using an A/V cable to connect the DVD player to the TV, yellow, white and red jacks are coded, match the jacks up, put one end of A/V cable to DVD player OUTPUT jacks and the other end to INPUT jacks in back of TV. Also same with Direct TV receiver, hook top set of jacks to TV, with A/V cable, also connect coaxial cable from satelite to matching satelite input jack. Connect power cables, and then you're set. Good luck to you!
Dec 12, 2009 | Televison & Video
I cant get my dvd to play using my rf modulator
instead of plugging in the rf modulator before the cable box, i plugged it in after it
Jan 24, 2009 | GE 25GT240 25" TV
Can't get my VCR to work
FIRST!!! Make sure you have the coax or AV cables plugged into jacks marked out on the machine.....then....
*If you have it hooked up with a Coax cable, you should immediately have picture and sound when you turn it on. Make sure you have a dvd/vhs running and switch between channel 3 and 4. if this doesn't work, make sure that you have the cable connected to the one marked 'in' or 'cable in' or 'ant in'. then retry the previous steps.
*If you have it hooked up through A/V cables (Red/Yellow/White), make sure you have them all connected to the same set of jacks. They should be labeled Aux 1 or something similar and are generally surrounded by a box molded into the TV's plastic casing. You will then have to use the TV remote to switch TV/Video settings until you get to the one that matches the Aux jacks you have it plugged into. Again...make sure a dvd or vhs is running and keep flipping until you find a picture.
Hope this helps!!!
Dec 29, 2008 | GE 25GT240 25" TV
31GT720 GE Stereo Monitor
I have the same TV. Make sure you have hooked up the red, white, yellow leads from the "out" jacks on the DVD to the same colored "in" jacks on the back of the TV. You also have to make sure your TV is set to Video Mode. I do this with the GE remote that came with the TV. There is a WHO-INPUT button on the left side of the remote, 3rd from the bottom. Toggling this button should switch you between TV and Video mode. Hope this works for you.
Nov 15, 2008 | GE 31GT720 31" TV
I cant find a aux on my tv to hook up the dvd.
I am guessing that your game is hooked to the cable connector on the back of the tv and is switched. Do you know you can get a special adapter that uses the rca jacks (white,red,yellow) out of the dvd to the adapter and then out of the adapter with coax to the cable connector on the tv where the signal goes. I think you can get them at WalMart or Radio Shack. Upgraded tv's have the red white and yellow inputs for dvd. Hope this helps.
Dec 29, 2007 | Televison & Video
Audio / Video input and output jacks
i have this same set and the answer is no-not worth the extra expenses to do alot of reworking.
Oct 25, 2007 | GE 25GT240 25" TV
GE 25GT240 25" TV Logo
156 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
