Question about Epson Stylus® C64 InkJet Printer
Epson c64 printer
My c64 printer wont print i colour . it prints in black and white , i have cleaned the heads 6 times and it still hasent worked
  • Gerry Millward
    Gerry Millward May 11, 2010
    It's a long time now without any help forthcoming on this problem. Can you post a new comment updating the situation, so that I can try and help you fix it, or close it as solved!
  • 353 Answers
If you have already done lots of head cleans with no result, and you're SURE you have good ink cartridges properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head
parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean/nozzle check again. If still nothing, post a new comment detailing what you have done and the results.
Posted on Mar 08, 2009
My epson sx215 wont use my new black ink
Help me please my Epson Stylus SX215 black ink won`t print. I cleaned the head 3-5 times and the nozzle but it still wont`t print black , it is brand new.Is it because the printer didn`t work maybe 2 months. Yesterday i bought all inks and the other are working , the black no :[ please help
Aug 04, 2012 | Epson Stylus Multifunction Inkjet Printer/...
All colours except the black appear to be printing on my Epson C64 InkJet printer. What could be the problem?
On this printer, the black colour is a separate cartridge.
It is possible that is has run out of ink or maybe is blocked in some way.
Try removing the black cartridge and hold it up to a bright light to check the ink level.
Make sure the contacts where the ink flows out are clean and not blocked with dirt.
If there is plenty of ink but it still won't print then try a new black cartridge.
Please rate my answer if you find this helpful.
Many thanks,
Chris
Mar 05, 2011 | Epson C64 InkJet Printer
Lexmark Z615 inkjet printer - whetther I print in colour or black and white, I am getting whole lines of text/image missing. When I use the "clean nozzle" function some of the colours - like...
The problem with your printer is the print head. Usually you have to run the clean nozzle thing 5 or 6 times to clean the print head nozzles and if there's still no improvement after that then print head needs to be changed for the printer to work properly. The bad news is that a print head costs almost as much as a new printer.
Jan 30, 2011 | Lexmark Z615 InkJet Printer
Epson stylus c64 does not print in colour only black and cyan, no magenta or yellow but the ink levels are going very quickly on all. Where are they going?
I find by leaving the printer on stand -by it not use as much ink dont swich your priner off, because every time you swich in on it will star cleaning the heads on your printer and that will use lots of your ink up
Jan 23, 2010 | Epson Stylus C64 InkJet Printer
One colour cartridge on epsom sx200 is empty yet it wont allow me to print in black only
umm... this is not a solution because I don't think there is one apart frombuying new inks. Epson and all other inkjet printers do this to preventthe coloured print head nozzles from getting blocked. If they are notused for a long time the ink dries up and blocks the nozzles. Epsonrecommends printingat least once a month with all colours to prevent this. Printing inblack only option will only work if the colored inks are OK. Wheneverthe printeris turned on it performs a head clean, this is why the coloured inksget used over time even though they are not used for printing.
www.Quikshiptoner.com
Nov 25, 2009 | HP LaserJet 2840 All-In-One Printer
I recently installed new black ink cartridge. Since doing so, the colors on anything printed are incorrect. For instance, anything red prints as pink. Anything deep yellow prints as a gold. MY...
Hi maryryherd - yes the C64 is in the list - don't know why you couldn't see it.
The inkjet colour system can be quite confusing. The colours in the cartridges are cyan, magenta and yellow, plus black. Other colours require a mixture of these basic ones. For example, to produce "red" requires a mixture of magenta and yellow. Your problem sounds like you are getting insufficient yellow, and maybe insufficient black.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Are all the 3 colour bands plus black printed OK. If not, try up to three cleaning cycles. If ink is now flowing pretty well, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back with a new comment.
Apr 18, 2009 | Epson Stylus C86 InkJet Printer
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Printing in black & white when color cartridge ran out
One of the possible reason why you can't print black in white because Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. More than that Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head.
Apr 15, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson C64 printing oddity
Are you sure that there is enough ink in tank? If there is then the head got clogged. You can try one thing open the printer head and soak it in Hydrogen Paroxide(It is available in Medical store) for one night. Then do the maitenace through software(Nozle Cleaning etc.). It will work. But in epson printer 4 times rechagre will almost drain the tank. so be ready to have another set of Ink tank.
May 05, 2007 | Epson C64 InkJet Printer
Will not print
Unfortunately, if you have replaced the cartridges and tried many cleaning cycles, then there is no solution other than replacing the unit. A good replacement would be the C88+
Mar 18, 2007 | Epson C64 InkJet Printer
Epson Stylus® C64 InkJet Printer Logo
81 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
