Question about Mitsubishi WS-55511 55" Rear Projection Television
Unable to get power button light to stop flashing
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Sep 30, 2010
Power restart problem.
Hold down the volume and power button for a count of 20 seconds. This should cause the light to stop flashing, then push the power button and it should power up as normal.
also try taking battery out for about 30 seconds then put back in this should also cause it to power up normally. But try the buttons first.
Mar 15, 2015 | Samsung Galaxy Note 2
When pushing the power button on the tower, the power lights on the tower, mouse, and keyboard continually flash, and the computer does not actually turn on. The only way for the flashing to stop is by...
The power supply is receiving power from the source but is unable to properly distribute it to the components. This means that either your power supply is bad or the motherboard. Try removing all devices attached to your computer and check your USB ports to see if they are damaged.
Jan 09, 2011 | Dell Dimension 2400 PC Desktop
Waste ink absorber is full and needs to be replaced. how do I do about it. Unable to print
This is all procedure, no need to disassemble printer.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Dec 28, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Green light won't stop flashing. Unable to turn off/on or reset.
Unplug the unit for 5 minutes then plug it again. Turn it on. If it does not power up, press the SYSTEM RESET button on the front panel with a pointed object such as the point of a pencil or end tip of a paper clip. The green LED light will flash quickly for about a minute then stops. You may turn on the TV then. The changes you made most recently, before using
SYSTEM RESET, may be lost. Changes you made previously, however, are not lost.
Aug 21, 2009 | Mitsubishi WS-48515 48" Rear Projection...
Service m6500 after last wash the start button contiues to flash unable to use washer even if power is turned of
My washer did the same until i relalised that after the wash when light is flashing, turn control to stop position and wait until it stops flashing before turning machine off. Sometimes i have to turn control right around again for it to stop flashing but this is how it works.
Dec 07, 2008 | Washing Machines
Canon pixma ip2200
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Nov 03, 2008 | Canon PIXMA iP2200 InkJet Photo Printer
Flashing lights
Canon IP 2000 / reset
1. Turn off printer
Aug 26, 2008 | Canon PIXMA iP2000 InkJet Printer
Power light remain blinking
hi, i noticed before when i pressed on the reset button of my dlink, the power started flashing, n when i stopped pressing the reset button it wont stop flashing anymore..did you happen to press the reset button or power button too long, sometimes it is dislocated so the power light wont stop flashing, just by pressing on it one more time should fixed it, though if it was previously configured it will go back to default settings...thats also the reason why you cant ping or go to the config page because its not relaying the info..i stongly suggest you contact dlink for this so that they could give you more info about it...because for power light its just that or its already defective...i hope this would help, pls feel free to ask if you have anymore questions
Nov 29, 2007 | D-Link AirPremier DWL-2700AP 802.11g/b...
Unfixable?
all lights are flashing
the printer may need to be restarted
1. Press the Power button to turn off the printer, then press the Power button to
restart the printer.
Proceed to step 2 if the lights continue to flash.
2. Press the Power button to turn off the printer.
3. Disconnect the printer's power cord from the electrical outlet.
4. Reconnect the printer's power cord to the electrical outlet.
5. Press the Power button to turn on the printer.
If these steps do not work. It will need service, as a bad board may be the problem.
Here is the manual.
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=304431&cc=us&lc=en&dlc=en&product=304431&dlc=en&lang=en
Nov 09, 2007 | HP DeskJet 5150 InkJet Printer
Remote 15-2144
Hello, you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Apr 09, 2007 | Radio Shack 4-in-1 Kameleon Touch-Screen...
Mitsubishi WS-55511 55" Rear Projection Television Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
