Question about Amana DLE330RAW Electric Dryer
My dryer has stopped heating, so how do i know if its the actual element that is bad or the thermostat? i am guessing there is a thermostat that turns on the element? thank you ahead of time.
  • Amana Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
This is a FREE answer, Please rate me
Posted on Sep 30, 2010
  • Anonymous Sep 30, 2010
Dryer won't get hot
Find these five areas if your dryer is not heating up:
1. Proper Voltage
2. Heating Element
3. Thermal Fuse
4. Thermostat
5. Timer motor
Sep 15, 2016 | Dryers
Estate Dryer TEDS840PQ0 stopped heating. Is there a fuse or is it a bad heating element?
But its running right? just not heating? if not running u may have bad motor windings, other wise check out the thermistor, and other thermostats and the element with a multimeter, if u get no continuity on ur heating element ? ITS BADDDDDDD SHOULD READ BOUT 1200 OHMS
Sep 14, 2014 | Dryers
Daryer is not heating
The heating circuit of the electric dryer consist of the following parts. The timer, the heating element, the hi-limit thermostat, the safety thermostat, the operating thermostat, the temperature switch and the motor centrifugal switch.
If any of these parts fail, the dryer will not heat. Now, most people when the dryer stops heating, replace the heating element or the timer with out checking to make sure that those parts are bad. Rule number one is, don't assume that the part is bad with out checking it with a multimeter.
The first and most important thing you need to do, is to disconnect the dryer from the wall outlet before doing any kind of work on it. Most parts will need to be checked for continuity and the dryer must be disconnected from the wall outlet.
Most of the times the part causing the problem is behind the dryer and you can gain access by removing the back panel.
Remove the back panel on the dryer. Disconnect one of the heating element wires and take a reading between the two terminals on the heating element. The reading should be between 10 and 50 ohms. If the heating element is good, check the hi-limit thermostat by removing one of the wires and checking for continuity. Continuity means, that electricity could pass through the part that you are checking.
The hi-limit usually blows when there is an obstruction on the exhaust hose, so make sure that the exhaust hose is not obstructed when replacing the hi-limit kit.
If the hi-limit thermostat and the heating element are ok, check the operating thermostat. The operating thermostat is in charge of maintaining the temperature inside of the drum at about 150 degrees. You will need to check from the two terminals with the red wires attached on it.
Those where the parts that fail more often in the Whirlpool electric dryer. The timer, the motor centrifugal switch, the temperature switch are a little harder to check because there are may different one. You will need to use your wiring schematic to see how to check them.
Aug 17, 2010 | Frigidaire GLER341A Electric Dryer
Fisher Paykel DEGX1 no heat, therm tripping - used multimeter
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
May 31, 2010 | Fisher and Paykel DEGX1 Electric Dryer
I have a samsung DV337AEG/XAA Electric Dryer which three weeks stopped heating up. We replaced the heating element, along with the thermostat. after that it heated up for 20 minutes then stopped, replaced...
This one isn't going to be easy, you've already replaced the major things. I'm guessing there's a crack in some connector, or other defect, that heats up like the element and opens up- giving the same symptoms. It could be a faulty connection in the power feed to the element connector, or any other connection en route to it. You might see something suspicious. If you have some electronic skills, you might run the dryer until it happens, then quickly disconnect it, and while it's still hot, ohm out all power connections and wiring that could affect the element. You might get lucky and find the open line, being able to hone in on the bad connection, etc. Good luck!
Mar 25, 2010 | Samsung Dryers
CLOTHES DRYER HEATING ELEMENT
The heating element is SUPPOSED to cycle on and off. That is normal. There is an Internal Bias Thermostat and a Hi-Limit Thermostat that help regulate the internal operating temperature of the dryer. However, if you are experiencing longer dry times, or poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will actually take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter than usual in many cases and the heating element will appear to glow brighter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat beginning to fail.
Mar 15, 2010 | Kenmore 64742 Electric Dryer
Dryer runs hot on low heat setting
What kind of dryer do you have? Some dryers use a bimetal or snap-disc thermostat with a heating element under it to control temperature. the heating element is used for the low heat setting to make it turn off early since it will sense a temperature higher that what is actually there. If the heating element is bad then the thermosat will only operate at the high temperature. You should look at replacing that element.
Nov 29, 2009 | Refrigerators
How do I replace the dryer element on my hotpoint auarius wd640 front load all-in-one
Before you replace dryer element, how do you now it is bad and what tells you it is the element and not 3 or 4 other items that could stop the element from heating? If oyu tested the element directly (and this of course is nearly the only way to know if it is bad) then you obviously has access to it and should see what is involved in removing it. So, I believe you do not actually know if the element is bad. You need to search and test all the controlling items that allow the element to heat before condemning it. I believe you need a skilled service person. Goodluck, macgivor
Nov 09, 2009 | Hotpoint Aquarius WD640 Front Load...
Not heating
Hi, Check the thermostats and the fuse. Make sure the 4" vent to the outsideis cleaned. If it is plugged, it will cause elements and thermostats to go bad.
The thermostats and the fuse must have continuity. If they are open, replace them. All these parts are located in back on blower housing and element housing.
I hope this helps. Please let me know if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
Element does not turn off.
  • actually is sounds like the centrifugal switch in the motor is bad.
  • the element should not turn on unless the motor is running.
  • the thermostats are in place to pick up the heat of the airflow, not necessarily the heat directly coming from the element.
Jul 01, 2008 | GE DCSR483EA Electric Dryer
Amana DLE330RAW Electric Dryer Logo
80 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
