I HAVE A WM1832CW WASHER, WHEN TURNING IT ON , THE ERROR DE COMES ON AND THE DOOR DOES NOT LOCK, SOMETIMES IT WORKS FINE, OTHER TIMES I HAVE TO TRY ABOUT 4 TIMES,AND OPEN THE DOOR AND TRY AGAIN, WHEN IT DOES START THE DE, DOES NOT REMAIN. COULD IT BE THE DOOR LOCK OR HINGES. THANKS
  • patmoric Sep 30, 2010
    Thanks, I ordered the door lock assembly, I checked everything else, including the door lock , it must just be worn out as it does make contact after a number of tries, will let you know when I replace the lock assembly.
    Thankks
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. DE is a door open error, you'll have to check the door if it's properly closed. Also check loose electrical connections at the door switch and PWB assembly. If everything appears to be fine then it is the door switch assembly that should be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 30, 2010
  • Rylee Smith
    Rylee Smith Sep 30, 2010
    OK, Please accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
What does the code de stands for
On front-load washers, it can stand for "door error", meaning the main control board thinks the door is open. If the door is actually closed and the de error won't clear, the electric door lock could be shorted, giving a false signal to the main control board. On the Samsung top-loader, it means a "child lock error" has happened. On that washer, you will see "CL" or "DE", the washer will auto-drain and an alarm will sound. To clear the error, close the door, turn off the power, then turn it back on.
Aug 21, 2015 | Washing Machines
Lg wm1832cw de error occurs when starting the washing. after multiple tries, it might start
It is a door lock error caused by bad door lock switch or if your door is very hard to swing closed because the hinge is corroded, then the hinge could be causing the door lock to error.
Jan 04, 2014 | LG WM-2277HW Front Load Washer
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
De error code on LG washer. No clothes b?ocking....mechanism seems fine...unplugged for several minutes and tried again..still the de code. Suggestions>
'dE' stands for 'door Error' indicating that there is a problem either with the lid/door lock or the lid/door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 15, 2011 | LG Washing Machines
Samsung washer machine error code dE
DE indicates a door lock error.
Either the door lock, wiring or main control board can cause this fault. The door lock is relatively inexpensive so it would be worth trying a new door lock first.
Check the wiring between the door lock and the control board. If a new door lock doesn't fix it and the wiring is ok you are only left with the control board.
Hope this helps.
Jul 14, 2011 | Samsung Washing Machines
Error code de on samsung front loader J845
The door lock is the problem... try to push the door harder... or change the door lock! It is usually done in 5 minutes.. .... if it is only 5 months... you have a warrenty!
Jan 26, 2009 | Samsung WF337AA Front Load Washer
Random electrical problems, sometimes it works beautifully, sometimes not!
F11 = Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
FDL=
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Le code d’erreur “Verrouillage porte” apparaît s’il n’est pas possible de verrouiller la
porte. Le système effectue six tentatives de verrouillage avant d’afficher le code d’erreur.
■ Door lock mechanism is broken or removed from door.
■ Door switch/lock unit failure.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Te error on LG frontload washer
ARE YOU SURE IT'S CODE IS TE AND NOT DE
DE IS PROBLEM WITH DOOR LOCK . TAKE THE WIRE OF THE DOOR SEAL AT FRONT . PUT YOUR HAND IN BY DOOR LOCK POSSIBLE THE PLUG HAS COME OF THE DOOR LOCK, IF NOT THE LOCK NEEDS REPLACING.
SWITCH APPLIANCE OF FIRST. GOOD LUCK
Jan 10, 2008 | LG WM-2277HW Front Load Washer
DE error code
That is a door switch error problem.  The door latch is not sensing the door closed.  You may need to replace the door latch assembly.
Oct 23, 2007 | LG WM-2032H Front Load Washer
LE code flashing
Try replacing the sensor assembly. Part number 6501KW2002A. It is on the stator itself where the 4 wire connector clips to. Only costs $17 + change & shipping. Mine works fine now!
May 07, 2007 | LG WM-1832C Front Load Washer
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
