Question about Canon PowerShot S2 IS Digital Camera
S2 IS I have the stuck iris issue, but do not know how to create 15 sec exposure in TV mode. Available range shows up to 2 seconds
See the following:
http://www.fixya.com/support/t295396-canon_s2_black_screen
When you set to TV mode, will see 1/125. Try to press the left of the button with up/down/left right arrows to decrease it to 1/15 that is 15 sec you're looking for then try solution at the above web site.
Posted on May 31, 2008
When the camera is on, no images are shown. why is that?
Dunno if this is old info to someone, but anyway id like to add the possible solution here too. To make it available to many who is searching it.
Put the camera in the Tv mode from the dial. (in Record Mode ofcourse) Select 15" from the omnibutton (pressing it left) Take a picture, count to 6 and release the batteries in the middle of everything. With mine this worked with the first time. It is reported that this might require several tries.
The iris is in some weird oil, and it gets stuck.
When you have image again take several pictures (maybe hundreds) to make the "iris" more free. I got this camera very cheap nowadays, alomost free. and it works fine now.
Oct 17, 2010 | Canon PowerShot S2 IS Digital Camera
The lens is stuck out in the off positiona and im getting a e18 message
You've got to clean the battery compartment contacts with a cotton swab (dampened) with rubbing alcohol.
Nov 22, 2009 | Canon PowerShot S2 IS Digital Camera
Camera turns on, lens goes out, but it is black, see nothing through it or on lcd screen (yes, cover is off). There is no error messages, still takes pictures but just black. Can view previous pictures on...
It coud be a very common IRIS/Shutter stuck problem...this has been reported on lot of S3 IS & S2 IS cameras... just search for this on web and you'll find a temporary solution also (related to taking battery out in the middle of taking picture during a long exposure (15" in Tv mode), but for more permanent fix you need take it back to Canon service center
Aug 03, 2009 | Canon PowerShot S3 IS Digital Camera
Canon DIGITAL IXUS V2
The problem is the iris is stuck.
The solution is:
1. Move the camera to TV mode(the wheel with AUTO,M,TV,...)
2. Set the exposure time to 15 seconds(15")
3. Take a picture.
4. After 7 seconds remove the batteries and put them back on.
5. Repeat the procedure until it works.
Jan 30, 2009 | Canon IXUS V2 Digital Camera
Camra dosent show pic
Please see similar problem titled "black screen". Welsbar posted a possible solution as a clarification request. It involves switching your picture mode to TV and changing the shutter speed to 15 seconds, depressing the shutter button for 7 seconds, then opening battery enclosure. Repeat as necessary - I did this twice before I started to see anything on the screen. Twice more before photos start to look okay. Don't know yet if this is a lasting solution, but at least now I can start using the camera again and find out!
According to Welsbar, the problem is an internal part (iris?) that gets stuck when camera hasn't been used frequently.
Nov 04, 2008 | Canon PowerShot S2 IS Digital Camera
No image in viewfinder or on screen
I found this solution on a different page and it fixed my camera that was having the same problem.
In the case where you get a black image, the following may be of help:
This is a common problem in older Canon S2 IS cameras, especially ones that have not been regularly used. What happens is that the lens iris gets stuck at a small aperture. Most often you can get function back. Here's how:
Turn the camera on in shooting mode.
Turn the mode selector to shutter priority ("Tv").
Use the four-way button on the back to set the shutter speed to 15 seconds. That's right, 15 seconds. (To do this you keep pressing the left direction on the four-way button until it goes from 1/1600 or whatever it might be all the way to 15")
Press the shutter release. Count to seven, then pop open the battery compartment.
Wait several seconds, then close the battery compartment.
You may need to repeat the above sequence several times to unstick the iris. If that does not accomplish it, you will likely have to send the camera in for repair.
Once you have it working again, you should use the camera regularly to keep it from sticking again.
This sounds like a pretty ghetto solution but it worked for me and I know it has worked for others. So before you go wasting your time writing letters, give this a shot.
Oct 17, 2008 | Canon PowerShot S2 IS Digital Camera
Overexposure problem after the black screen
Given that the 15' batteries out trick is just a way of forcing the iris to get un stick i think your iris is probably still getting stuck (but this time open a bit).
you could try doing the 15' trick a few more times in the hope of loosening it a bit.
ultimately once you have had this issue i think you are living on borrowed time before it happens again unless you get it fixed by canon.
Aug 25, 2008 | Canon PowerShot S2 IS Digital Camera
CANON POWERSHOT S2 IS 5 MEGA PIXELS
I bought mine 2 1/2 yrs ago too. Found this solution on this site and tried it. It worked perfectly.
Turn to TV mode, set the exposure to 15 seconds by pushing the little "arrow dial" until you have 15"
Push the button to take the picture.
Wait 7 seconds from when you push the button, then turn over and open the battery door while it is "taking the picture."
Close the battery door and turn back on.
I did this three times and the last time, it worked and the iris became unstuck.
Then I took a million pictures to get the iris moving.
Jul 11, 2008 | Canon PowerShot S2 IS Digital Camera
Black lcd screen when switch on
i had the same problem and couldn't find an anser anywhere, so i just hit it.
seems to work fine now :)
Jul 11, 2008 | Canon PowerShot S1 IS Digital Camera
Shutter priority mode?
s I understand it from what I have seen on the Web, the 3000Z can operate in several modes: 1. Fully automatic (camera select both 2. Manual (user sets both aperture and shutter speed). 3. Aperture Priority mode - user sets aperture and camera chooses correct shutter speed to get a good exposure Apparently there is no Shutter Priority mode (user cannot set only the shutter er speed and allow the camera to set the aperature to get a good exposure). This option is available on the Epson 850Z camera and this seems like a silly ommision to make on a "high-end" camera like the 3000Z.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
80 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
