Question about Samsung Televison & Video
My Samsung tv clicks like it's going to turn on but then 2 secs. later it clicks off again. it keeps doing this over and over again but there is NO picture.
    Habit-Forming:
  • 130 Answers
Hi there
we have like 9/10 post on this site a defective power suply board that has a couple of capacitor to be replace
Posted on Sep 30, 2010
SOURCE:
IA THIS RVICE FREE I HAVE BEEN UNEMPLOYD FOR 2 YEARS AND IHAVE RIEND THAT I THNK AN D TEWORK IF I CAN DETERMINE THE PROBLEM
Sounds like the power supply capacitors have failed. If you can't replace capacitors on a circuit board on your own, it's time to take in to a repair shop.
Dec 08, 2014 | Samsung HL56A650 56 in. TV
Want to use samsung 2233SW LCD monitor as TV
Yes you can, if you has PC desktop, plug your lcd to it. change LCD resolution from your PC.
-- Right Click on desktop
-- Click properties >> click settings tab
-- You will see Screen Resolution, change to the lowest (800x600)
-- Nnplug VGA cable from PC
-- Now plug the cable tou your TV Tuner.
Feb 08, 2010 | Samsung SyncMaster 2233SW Monitor
Samsung hp-t4234
The color wheel have been broken, do not turn on your TV again to avoid big trouble with the DMD board, the most expensive part in your TV. Call technician to replace it.
Aug 14, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Compressor will come on for approx 3 sec and then go off with click and 8-10 sec. later try again
The start relay device on the compressor is faulty. replace this start device asap.
May 26, 2009 | Kenmore Freezers
I have a Samsung rear projection TV, model no SP61L2HX. When switched on and waiting for the lamp to warm up it switches off. Then it turns on again and keeps on repeating this cycle.
    According to the symptom this problem called hicking.And in this situation various components could be shorted.
   The main cause is power supply,Check the unit may be there could be capacitor leakage.Safty resistor could be open.
  If you can do it by yourself and expert then ok.But if you have no earlier experience then plz contact any expert nearby.
  Thanks for using fixya.
Dec 15, 2008 | Televison & Video
Tv turns off
Hi there, my husband fix the problem. My small son had changed the settings for the HDMI. My husband switched the tv to DVD mode started a dvd & changed all the settings back. After changing all the settings he also reboothed the setbox machine.
Apr 11, 2008 | Samsung LN-S2651D 26 in. LCD Television
PROBLEM WITH SAMSUNG DLP TV
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Apr 07, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
103 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
