Question about Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 7.5 Hp, 230 Volt 3 Phase, Model - 2475N7.5
My air compressor makes a noise like a lawn mower traying to start after it kicks on, after about 15 or 20 seconds for about 2 seconds and then the noise stops. Dont do it all the time. It runs good pumps good like it should. What could this be? Thanks
  • 35 Answers
Isn't the air compressor just charging or is this a new noise that you didn't hear before. If it isn't broke don't fix it. It could be a valve that isn't opening and closing properly. Use a little pneumatic lubricant on any parts you feel confortable getting into. Don't disassemble anything unless you know how to put it back together. Pay attention to direction of valve spools.
Posted on Sep 30, 2010
APE08AJM1 - GE 115 Volt Portable Electronic Room Air Conditioner - Compressor not kicking on. Manual indicates it's triggering the overload relay? How do I solve this?
There is a start capacitor near the compressor that may be bad. If the capacitor tests OK then the compressor is locked up. A service man can try to get it going with a kicker capacitor but there is no guarantee that that will work.
Sep 14, 2017 | GE Heating & Cooling
I have a 2006 Mazda3. I noticed whenever my air conditioner or heat is on it makes a sound like a lawn mower when I acceralate. Any ideas of what this could be ?
Well, I think you can rule out the AC/heater fan inside the car. That would make noise even just sitting in the driveway.
Many/most vehicles are designed to run the AC compressor not only when the AC is on but also when the defroster is on. This is to keep the AC compressor lubricated through the winter months also.
It should not be a belt problem as that belt is always turning anyway which should then rule out the pulley bearing at the AC compressor.
I do suspect your problem is a major internal failure of the AC compressor. This can be easily checked by a technician [or yourself if qualified]. Locate the electrical connector at or to the AC compressor. Two people: With the AC turned on, in park, increase the engine speed so you can here the noise. Disconnect the AC compressor electrical connector. If the noise stops instantly, the compressor has failed. A quite expensive repair. Have a reputable shop locate a re-manufactured compressor for you. That will help some on the cost.
Bestaluckto you!!
M
May 09, 2014 | 2006 Mazda 3
Mower makes chugging noise like it's gonna stall
Check the air filter to see if it is clogged. If you can park it somewhere that does not kick up dust or grass, then you can remove the air filter and then start it and see if that is what was keeping it chugging. If running smooth, tie the dead man lever or get someone to hold it and then slip the air filter back in place, if it chugs you know that is what it is and just needs replaced.
I hope this helps.
Jul 20, 2011 | Mtd Garden
Compressor won't start in cold weather
It may need a thinner oil or oil change.
Dec 29, 2009 | Garden
I noticed some straining noise coming from my a/c unit today. The fan on top of the condenser runs fine but as soon as the compressor tries to kick on the fan stops for a split second and you get a kind of...
You amy ahave a bvad capacitor on the outside unit. It starts the fan and the compressor. You can change this yourself. Open the outside panel and you will see a silver canister with terminals out the top. Replace this and I think your problem will go away. On the cap. it will say something like 30uf 5uf 370 ot 440 Just get these numbers and get a new one. Russ
Aug 14, 2009 | Goodman CKL24AR24 Air Conditioner
Floods while mowing-remove air filter -gas running out air intake.
First, go outside and stand next to the lawn mower. Then as hard as you can kick it. Keep kicking it until you feel better. Now go down to your local Sears and tell them that you need a new lawn mower and watch all of those guys scramble to make the sale.
Happy Shopping.
Aug 09, 2009 | Garden
Compressor making noise and freezer is kicking cold air out but
Sounds like the start relay, start capacitor and overload have become defective. Turn it off to prevent further damage to the compressor internal overload. Check to make sure the condenser fan and the evaporator fans are running and get back with me with an answer yes or no. Thanks, Sea Breeze
If the model number you have above your post are correct I will also send you part numbers and hot to replace.
Aug 04, 2009 | Maytag PTB2154G Top Freezer Refrigerator
Ac starts kicks on and off every couple mins
Sounds like the compressor is the one making the "NOISE". If the sound sounds like something trying to start, then kicking off, its probably the compressor and not the fan. Hence no cool air.
Jul 26, 2009 | Dometic Rooftop RV Air Conditioner
Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 7.5 Hp, 230 Volt 3 Phase, Model - 2475N7.5 Logo
116 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
