Question about Jensen's VM9312 Car DVD Player
It will not turn on. There is a red light that comes on on the power button on the reciever, but the Dvd player will not funtion. I dont not have the Pink (parking brake wire) on the Dvd player connected to anything. Does that have anything to do with it? Thank you :)
  • 959 Answers
Yes... the park wire needs to be grounded in order to play a DVD
Posted on Sep 30, 2010
I have bought an Antsig universal remote control for my Sony DVD CMT-GP8D but the 4 diget code is not in the operation book. Please help
Have you tried the manual option? Turn on your DVD player. Press "TV" or maybe a different button for DVD players, then a red light on your remote blinks once. Then hold both the "up" volume and "up" channel button down until your red light is permanently on. Then whilst holding your remote control 1mm away from your DVD player signal light (usually red too), hold down the "power" button until your dvd player switches off. Then switch it on again and try other buttons. However, I've only tried this on an LG TV, but took me 2 days until I really put the remote in front of that signal light. Took about 1 minute or more while holding down the "power" button. Hope it works =)
Jan 30, 2011 | One For All URC4110 Remote Control
How do I connect a sony cd/dvd player to a onkyo receiver model Tx-SR600 to a Mitsubishi big screen TV model no. WS-65411 . I cannot get a picture for the dvd when I turn on the player I have sound coming...
If your using compsite cables, Yellow , Red and White cables the red and white is sound you connect to reciever, then yellow to the coposite in on the Tv Screen. If it is a HDMI cable connect to Tv Screen not Reciever. What cables are you using?
Nov 08, 2009 | Sony Televison & Video
No Power From My Reciever
Mook_trakzz, your device is most likely roasted and ready or scrap. Sorry.
Guest, check if the cables are connected properly, specially the cable between the device and the sub is quite easily shifted thus losing your sound.
timtlc, seems you have had some powerfailure during that night, you can try to remove the powercable for at least 15 seconds, that should reset the device.
to all, information from Philips on this device:
  • Press the STANDBY ON button on the front of the DVD system to turn on the power.
    If the device powers on at the unit and not the remote, the unit may have been turned off with TV selected as the source on the remote. The standby button on the remote will operate most Philips TV’s when TV is selected as the source. Change the source to disc or any other source than TV on the remote.
  • To completely reset the player, unplug the AC cord from the AC outlet for 15 seconds.
Feb 21, 2009 | Philips HTS3450 System
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
DVD will not come on
This model of player tends to have its power circuit fail. Unfortunately it would cost more to repair this circuit then replace the whole player.
Sorry I couldn't help you further.
Thanks for reading!
Apr 22, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD Player S99
just use yelloew out and red white for sound left right those red whites are into tv input on back 1 or 2 yellow in yellw for video red in red for right sound white for left sound then turn on dvd player use tvs remote select input 1 or 2 thats it hit play
Mar 13, 2008 | Amphion Mediaworks S99 DVD Player
It not turn on
Not sure what kind of connections you have, but be sure your unit is recieving good clean power. Try using another 12v constant and possibly a good 12v switched power source. Double check your ground wire as well. The unit may also be broken and might need service.
Oct 29, 2007 | Pioneer AVIC-D3 Car DVD Player
Coby dvd player
do you see the laser light come on when the disk spins if not it has probably lost power or failed, if so sometimes the laser head gets moved to close to the drive mechanism and the motor cant pull it out. i have found several of these that had this problem.
Oct 19, 2007 | Coby DVD-207 Portable DVD Player
DVD player froze, now only turns off
Sounds like the power supply in the dvd player has failed. It works just well enough to turn on the led infront but as soon as you go to do anything it shuts off. This is common in cheaper dvd players. Unless you can troubleshoot electronics. Or know someone that can. Your best bet is to unplug the unit and disassemly and retrieve your dvd.
Jan 13, 2007 | Philips DVP642 DVD Player
Jensen's VM9312 Car DVD Player Logo
185 people viewed this question
Top Jensen's Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
