Question about Canon PowerShot A710 IS Digital Camera
The lens cover is stuck partially covering the aperture and I don't know how to open/close or reset it. Can you help please. Thank you. Alexis
    Brigadier General:
  • 3,006 Answers
Your camera almost certainly has a lens error. This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses (in your case a stuck lens cover which is a less serious variation of the same fault) are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Canon service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Posted on Sep 30, 2010
Aperture lever stuck to wide open
On a film camera, the internel electronics determine the shutter speed and aperture. The camera computer figures out a higher shutter speed against the aperture speed. You have a lever on your lens that, when mounted on the camera, will keep the aperture open until you fire. That allows viewing in the brightest light. Then that aperture arm is allowed to close to what the exposure setting the camera determines when you click the shutter. You should be able to take off the lens and easily move the aperture arm and have it snap closed. If it takes a few seconds to close.. then the lens has oil on the aperture blades or the grease inside the lens is bad. These days, unless is it a very expensive lens it's replacement time. Canon lenses will fit any Canon (except Fd) film or digital camera.
Jul 27, 2017 | Canon T70 35mm SLR Camera
Automatic lens cover will not open.
please try resetting your camera to the factory settings..the procedure to reset is found in the instruction manual as well as in the cd that came along with your device. thank you for using fix ya
May 26, 2009 | Canon Cameras
Automatic lens cover won't open.
Try this only as a last resort after blowing lots of compressed air in there to clean the mechanism. Also with the lens barrel extended, tap it with a pencil (a grain of sand is usually the culprit, this may help to dislodge it). If that doesn't work, it may be necessary to go in there. The following repair will expire your warranty, so be forewarned.
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But for the A620, you might want to extend your zoom all the way out before removing the camera's batteries. Also you'll be applying the ring loosening rubbing alcohol around the barrel's perimeter instead of the front as shown in the procedures.:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Good luck, and remember to do this only as a very last resort. Oh, and if you do decide to try the repair, please post how it went.
Oct 17, 2008 | Canon PowerShot A620 Digital Camera
Sony cybershot 6.0 mega pixels
Hi
Do you mean the outer lens covers that open and close when you turn the camera on and off, or do you mean the aperture inside the lens that adjusts the amount of light that gets through?
The outer lens covers can usually be repaired if you can get the parts, or you can try taking it apart, cleaning it and then put it back together.
If it's the aperture then you can maybe repair the lens by tearing it down and rebuilding it, or you can replace it yourself or have somebody replace it for you.
We are a digital camera repair shop, we have W55 lens repair listed in our store for only $65 if you're interested just let us know.
Good luck from Darntoothysam com
Thomas
Oct 04, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Black screen
Hi
Your lens is aperture is most likely stuck closed and the lens needs to be replaced. If you can see menus but can take only solid black photos then it is either the CCD or the aperture; most likely the aperture.
We have never been able to repair a stuck aperture, we always have to replace the lens on the camera. A CCD can be replaced, but you need a CCD to use and they are only sold as part of the entire lens assembly.
There are online places that will do it for a decent price and there are others that overcharge by way too much.
I know this because I OWN ONE that charges a reasonable price to do the repair! (Google 'darntoothysam')
Just let us know if we can help! Good luck from
Darntoothysam com
Thomas
Jul 15, 2008 | Canon PowerShot SD850 IS Digital Camera
My canon A520 lens cover don't open
lens opens about 25% . Will not close back.
Mar 15, 2008 | Canon PowerShot A520 Digital Camera
Lens cover slide stuck closed
Take a butter knife and slide it where the crease is. move the close/open button till it open it could just be stuck due to moisture. Hope this helps.
Mar 09, 2008 | Canon PowerShot S70 Digital Camera
Kodak DX7440 Lens Cover does not open or close properly
It is a common, but in most cases intermittent problem with many cameras regardless of brand/model. I also own Kodak DX7440 since late 2004, and I had this problem twice, in 2007 and 2008. First suggestion: fully recharge the battery, it helped me the first time. Second: play with the lens cover, that is try to open/close it with the camera on/off. With me, in 5 min of these attempts, it suddenly fixed itself and stays this way for one month now. Another suggestion: dont use a toothpick, since it can scratch the lens. Use a q-tip, and to avoid cotton threads sticking to lens, wet the q-tip and let it dry.
Jan 03, 2008 | Kodak EasyShare DX7440 Digital Camera
Lens cover stuck open
I recently had the lens cover stick partly open.  There are 4 segments to the lens cover, and if we number them from the top, number 2 was not closing.
I gently flicked the segments a few times, in case there was a grain of dirt causing it to stick (although the camera has never been in a dirty or dusty environment).  This caused the lens cover to close fully each time, but now it would not open fully, segment 1 would not open, although it would stay open if moved by finger.
Anyway, after a bit of fiddling, I got it working properly again.  The way that the lens cover appears to work is that only segments 2 and 3 are pushed open or shut by springs, segments 1 and 4 are pushed open and shut by tiny tabs that catch on segments 2 and 3.  If the segments somehow get pushed out of alignment, then they either bind (causing the cover not to shut), or they get disconnected (causing the cover not to open fully.
Now I am not sure exactly what I did to get the mechanism form the stuck open state to the not opening state, but from there the way to fix it is to:
-With the lens open...
- Hold segment 2 in the closed position with firm finger pressure (which will tend to push it towards the lens).
- Push segment 1 towards the open position until you can see that it has cleared the edge of segment 2.
- Lift segment 2 way from the lens so that it will rub past segment 1 as you...
- Move segment 1 to the open position.
- Repeat if necessary to get the technique right.
I can't provide any guarantees, and I am not about to repeat the excercise on my camera, but it was a lot easier than sending it off for repair.
Dec 12, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens cover
I know this is an old post, but for those who want to fix it themselves: try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk):
Jan 16, 2007 | Casio Exilim EX-Z120 Digital Camera
Canon PowerShot A710 IS Digital Camera Logo
327 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
