Deltec Model 8186-1 SN 61074. Fault Description / Symptom. 1. Initial system start-up doesn?t complete the routine normally. When the circuit breaker CB2 is switched on, the system displays the message ?STATUS: BYPASS STARTING UP PLEASE WAIT? This message is displayed for 10 minutes until both CB1 and CB2 trip and the system displays alarm message ?OUT VOLTAGE LOW? 2. We have monitored the inverter output voltage at test points TP11, TP12 & TP13 on Interface board A6 and confirmed that output is zero volts during start-up routine. 3. Manual operation with the MC8/9 control panel shows that the converter ready signal (CONV RDY) is NOT true. 4. A check of the system memory location address 4201 reads 00 ?Converter status Normal?. 5. A check of the inverter off signal (INV OFF) on connection J2-25 show that this signal is TRUE (logic high). 6. There are no obvious signs of component damage and no short circuit found across major semiconductors. 7. Four boards have been replaced without change of symptom. Monitor Control Board (A9) 05135241-0 Rev N. Interface Board (A6) 05135233 Rev G. Inverter Board (A7) 05135237-1 Rev G. Static switch board 051352450 Rev-D. Could you please provide any technical support?
  • service670 Sep 30, 2010
    Thanks for your prompt reply.
    I cannot imagine where Fixya got the idea that this is a barcode scanner! It is a 300KG three phase 60Hz UPS!
    I also see that the text has been "crunched" somewhat. I will paste it again to this comment.
    Deltec UPS
    Model 8186-1
    SN 61074.
    President:
  • 2,777 Answers
Wow, you have tried everything I could possibly imagine, and it appears Deltec doesn't even exist anymore, at least not by that name any longer. Is there any way you could return the parts you already purchased?
I will continue to research this, but not even sure where to point you, my suggestion is just to replace the unit. I can't imagine this barcode scanner is worth all that much, I can recommend some good replacements if you are interested...
Is there some specialty application you have that requires a Deltec scanner?
Tim
Posted on Sep 30, 2010
  • Tim Grayson
    Tim Grayson Sep 30, 2010
    Ah, no wonder I couldn't find them! Just out of curiosity have you contact Deltec? Their number is 1-562-926-2304... This is a very specialized issue. I have a lot of experience with large scale UPS systems, and you have done everything I could imagine to get this unit back up and running. It may be time to consult the actual manufacturer and see what their higher level support thinks.
    I am continuing to research this, but I recommend you call them in the morning in the mean time and I will keep updating you as to what I find.
    Thanks
    Tim
Lg phone won't turn on. It pulls up the LG logo, after several minutes it makes the start up tone and the blue TracPhone page appears, that's where it stops
You can try a factory reset, I don't know the model, but here is the usual LG reset routine
Ensure the device is powered off.
Press and hold the Volume Down button then press and hold the Power button.
When the System recovery screen is displayed, release both buttons.
From the System recovery screen, select Factory data reset.
Note Utilize the Volume buttons to highlight and the Power button to select.
Select Yes to confirm.
Note Allow several minutes for the reboot process to complete.
Note To set up the device after completing the factory data reset, refer to Initial Activation and Setup.
Sep 22, 2017 | LG Cell Phones
Sunroof is stuck open and tried to reset it by holding button down for ten seconds and then it moves about half an inch and stays fully open. What do I need to do to get it to close?
Hi Thomas , First you should have it diagnosed by someone who has the tool to do so ! upscale scan tool , factory scan tool !
Diagnostic Starting Point - Roof
Begin the diagnosis with the Diagnostic System Check - Power Sunroof . The Diagnostic System Check will provide the following information:
The identification of the control modules which command the system
The ability of the control modules to communicate through the serial data circuit
The identification of any stored DTCs and their status
The use of the Diagnostic System Check will identify the correct procedure for diagnosing the system and where the procedure is located.
Symptoms
When no DTCs ( diagnostic trouble codes ) are present, begin symptom diagnosis by reviewing the
Sunroof Description and Operation . Reviewing the Description and Operation information will help you determine the correct symptom diagnostic procedure when a malfunction exists. Reviewing the Description and Operation information will also help you determine if the condition described by the customer is normal operation. Refer to Symptoms - Roof in order to identify the correct procedure for diagnosing the system and where the procedure is located.
Important: If the suspected cause of an inoperative sunroof is a power interruption to the sunroof module, the sunroof must be re-initialized. Refer to Sunroof Motor/Actuator Synchronization .
Important: The following must be completed before using the symptom tables.
  1. Perform Diagnostic Starting Point - Roof in order to verify that all of the following are true:
  2. ?€¢
    There are no DTCs set.
    The control module(s) can communicate via the serial data link.
  3. Review the system operation in order to familiarize yourself with the system functions. Refer to Sunroof Description and Operation .
Visual/Physical Inspection
Inspect for aftermarket devices which could affect the operation of the Power Sunroof system. Refer to
Checking Aftermarket Accessories in Wiring Systems.
Inspect the easily accessible or visible system components for obvious damage or conditions which could cause the symptom.
Intermittent
Faulty electrical connections or wiring may be the cause of intermittent conditions. Refer to
Testing for Intermittent Conditions and Poor Connections in Wiring Systems.
Symptom List
Refer to a symptom diagnostic procedure from the following list in order to diagnose the symptom:
Power Sunroof Inoperative
Power Sunroof Does Not Open to Express Position
Retained Accessory Power (RAP) On After Timeout in Retained Accessory Power, if the power sunroof should operate longer than 20 minutes after the ignition has been turned OFF
This information is right out of GMC service repair manual !
Synchronization will be necessary anytime the sunroof module battery positive voltage circuit is interrupted. The sunroof module will be synchronized when the controller learns the full vent position. The sunroof system will ignore any open request until the system has been synchronized.
To synchronize the sunroof:
  1. Turn ON the ignition, with the engine OFF.
  2. Using the close/tilt up portion of the sunroof switch, operate the sunroof glass until it reaches the full vent position.
  3. Verify that the system operates normally.
Once the sunroof glass reaches the full vent position, the actual position is stored in the memory of the sunroof module. The sunroof module will stop the motor one motor revolution before the defined actual positions.
Mar 24, 2015 | 2004 GMC Yukon XL
2005 Dakota will not stay running
Here are some tests you can try. The list is generic and you may have tried some of these already. It sounds like a vacuum line issue to me. For other info try this website:
Repair Guides Symptom Diagnosis no Codes What To Do When There Are No...
Preliminary Checks
Prior to starting this symptom test routine, inspect these underhood items:
  1. All related vacuum lines for proper routing and integrity.
  2. All related electrical connectors and wiring harnesses for faults (Wiggle Test).
  3. Check the throttle linkage for a sticking or binding condition.
  4. Air Intake system for restrictions (air inlet tubes, dirty air filter, etc.).
  5. Search for any technical service bulletins related to this symptom.
  6. Turn the key to off. Unplug the MAP sensor connection and restart the engine to recheck for the idle concern. If the condition is gone, replace the MAP sensor.
Test 2: Rough, Low or High Idle Speed Condition (Continued)
Test 2 Chart
Step Action Yes No 1 Step Description: Verify the rough idle or stall Does the engine have a warm engine rough idle, low idle or high idle condition in P or N- Go to Step 2. Fault is intermittent. Return to the Symptom List and select another fault. 2 Step Description: Verify idle speed & timing Verify the base timing is within specifications Verify that the base idle speed is set properly Are the timing and idle speed set properly- Go to Step 3. Set the base idle speed and timing to the specifications and then retest for the symptom. 3 Step Description: Check AIS / IAC Operation Check the AIS or IAC motor operation Inspect the AIS/IAC housing in throttle body for restricted passages. Clean as needed. Set the parking brake, block the drive wheels and turn the A/C off. Install the Scan Tool. IAC Motor Tester - Turn the key off and then connect the IAC tester to the IAC valve. Start the engine and use the IAC tester to extend and retract the IAC valve. ATM Test - Start the engine. Use the tool to change the speed from min-idle to 1500 rpm. Did the idle speed change as commanded- Install an Aftermarket Noid light and check the operation of the PCM and AIS or IAC motor circuits. Check the motor for signs of open or shorted circuits. Replace the IAC motor or PCM as needed or make repairs to the IAC motor wiring. If all are okay, go to Step 4. If the AIS/IAC motor passages are clean and engine speed did not change as described when the AIS/IAC motor was extended and retracted, replace the AIS/IAC motor. Then retest for the condition. 4 Step Description: Check/compare PID values Connect Scan Tool & turn off all accessories. Start the engine and allow it to fully warmup. Monitor all related PIDs on the Scan Tool. Verify the P/N switch input in gear and Park. Check the O2S operation with a Lab Scope. Are all PIDs within normal range- Go to Step 5. Note: An IAC motor count of over 80 indicates the pintle is extended and an IAC count of (0) indicates the pintle is retracted. One or more of the PIDs are out of range when compared to "known good" values. Make repairs to the system that is out of range, then retest for the symptom. 5 Step Description: Check the Ignition System Inspect the coils for signs of spark leakage at coil towers or primary connections. Check the spark output with a spark tester. Test Ignition system with an engine analyzer. Were any faults found in the Ignition system- Make repairs as needed Go to Step 6. 6 Step Description: Check the Fuel System Inspect the Fuel delivery system for leaks. Test the fuel pressure, quality and volume. Test the operation of the pressure regulator. Were any faults found in the Fuel system- Make repairs as needed Go to Step 7. 7 Step Description: Check the Exhaust System Check Exhaust system for leaks or damage. Check the Exhaust system for a restriction using the Vacuum or Pressure Gauge Test (e.g., exhaust backpressure reading should not exceed 1.5 psi at cruise speeds). Were any faults found in Exhaust System- Make repairs to the Exhaust system. Then retest the symptom. Go to Step 8. Repair Guides Symptom Diagnosis no Codes What To Do When There Are No...
Mar 20, 2014 | 2005 Dodge Dakota Quad
95 jetta will start then die
Symptom Diagnosis Test 4 - Cuts-Out Or Misses Condition
Preliminary Checks
All related vacuum lines for proper routing and integrity Search for any technical service bulletins related to this symptom.
Test 4 Chart
StepActionYesNo 1Step Description Verify Cuts-out condition Start the engine and attempt to verify the Cuts-out or misses condition. Does the engine have a cuts-out condition-Check for any stored codes. If codes are set, repair codes and retest. If no codes are set, go to Step 3.Go to Step 2. 2Step Description Condition does not exist! Inspect various underhood items that could cause an intermittent Cuts-out condition (i.e., EVAP, Fuel or Ignition system components). Were any problems located in this step-Correct the problems. Do a PCM reset and "Fuel Trim Relearn" procedure. Then verify condition is repaired.The problem is not present at this time. It may be an intermittent problem. 3Step Description Check/compare PID values Connect a Scan Tool to the test connector. Turn off all accessories. Start the engine and allow it to fully warmup. Monitor all related PIDs on the Scan Tool (i.e., ECT IAC Counts and LONGFT at idle). Were all PIDs within their normal range-Go to Step 4. Note The IAC motor should be from 5-50 counts. Watch fuel trim (%) for a large shift into the negative (-) range (due to a rich condition).One or more of the PIDs are out of range when compared to "known good" values. Make repairs to the system that is out of range, then retest for the symptom. Test 4: Cuts Out or Misses Condition (Continued)
Test 4 Chart (Continued)
StepActionYesNo 4Step Description Check the Ignition System Inspect the coils for signs of spark leakage at coil towers or primary connections. Check the spark output with a spark tester. Test Ignition system with an engine analyzer. Were any faults found in the Ignition system- Make repairs as needed Go to Step 5. 5Step Description Check the Fuel System Inspect the Fuel delivery system for leaks. Test the fuel pressure, quality and volume. Test the operation of the pressure regulator. Were any faults found in the Fuel system- Make repairs as needed Go to Step 6. 6Step Description Check the Exhaust System Check Exhaust system for leaks or damage. Check the Exhaust system for a restriction using the Vacuum or Pressure Gauge Test (e.g., exhaust backpressure reading should not exceed 1.5 psi at cruise speeds). Were any faults found in Exhaust System- Make repairs to the Exhaust system. Then retest the symptom. Go to Step 7. 7Step Description Check the PCV System Inspect the PCV system components for broken parts or loose connections. Test the operation of the PCV valve. Were any faults found in the PCV system-Make repairs to the PCV system. Refer to the PCV system tests. Then retest for the condition.Go to Step 8. 8Step Description Check the EVAP System Inspect for damaged or disconnected EVAP system components Check for a saturated EVAP canister. Were any faults found in the EVAP system-Make repairs to EVAP system (use the EVAP tests in this manual). Retest for the condition.Go to Step 9. 9Step Description Check the AIR system Inspect AIR system for broken parts, leaking valves or disconnected hoses (see graphic). Test the operation of Secondary AIR system. Were any faults found in the AIR system-Make repairs as needed. Refer to the Secondary AIR system tests. Retest for the condition.Go to Step 10. 10Step Description Check Engine Condition Test the engine compression. Test valve timing and timing chain condition. Check for a worn camshaft or valve train. Check for any large intake manifold leaks. Were any faults found in the Base Engine-Make repairs as needed to the Base Engine. Refer to the Base Engine tests. Then retest for the condition when repairs are completed.Go to Step 2 and repeat the tests from the beginning to locate and repair the cause of the "Cuts Out or Misses" condition.
Nov 29, 2011 | 1995 Volkswagen Jetta
Check engine light is on. Does replacing the oil filter fix the problem? The codes are: P171, P174
very Unlikely this will have any affect. sounds more like an air leak to me.
You will find all codes available at http://www.bluejag.co.uk/decode.php
Fault Code:- P0171 Indicates a Power-train fault
The fault is generally due to a problem in the Emission Management (Fuel or Air) area
Fault Description: Bank 1 combustion too lean
Action of ECM:- ECM Default:- Bank 1 catalyst warm-up ignition ****** inhibited- Bank 1 closed loop fuel metering inhibited- Canister purge inhibited- Maximum engine speed reduced
After clearing the DTC, complete the Start engine and bring to normal operating temperature> 82 °C (180 °F) Idle for 10 minutes
Check for a reoccurrence of fault DTC.
Possible Fault:- Engine misfire Air intake leak between MAF Sensor and throttle Fuel filter / system restriction Fuel injector restriction Low fuel pump output HO2 Sensor(s) (1/1, 1/2) harness wiring condition fault Exhaust leak (before catalyst) ECM receiving incorrect signal from one or more of the following components: ECT Sensor, MAF Sensor, IAT Sensor, TP Sensor
Fault Code:- P0174 Indicates a Power-train fault
Fault Description: Bank 2 combustion too lean
Action of ECM:- ECM Default:- Bank 2 catalyst warm-up ignition ****** inhibited- Bank 2 closed loop fuel metering inhibited- Canister purge inhibited- Maximum engine speed reduced
Possible Fault:- Engine misfire Air intake leak between MAF Sensor and throttle Fuel filter / system restriction Fuel injector restriction Low fuel pump output HO2 Sensor(s) (2/1, 2/2) harness wiring condition fault Exhaust leak (before catalyst) ECM receiving incorrect signal from one or more of the following components: ECT Sensor, MAF Sensor, IAT Sensor, TP Sensor
Sep 09, 2011 | 2004 Jaguar X-Type
The gauge in my yamaha fz6 2006 is blinking, the manual says there is a electrical circuit problem. I check all the ligths nad fuses and they seem in order, what else could it be?
I believe you count the amount of blinks to read the codes. First blinks are first number, and second set of blinks are second number. Chaz Moto DC
Fault Code: 12
Symptom: No normal signals are received from the crankshaft position sensor.
Fault Code: 13
Symptom: Intake air pressure sensor-open or short circuit detected.
Fault Code: 14
Diagnostic Code: 03
Symptom: Faulty intake air pressure sensor pipe system
Fault Code: 15
Diagnostic Code: 01
Symptom: Throttle position sensor-open or short circuit detected.
Fault Code: 16
Diagnostic Code: 01
Symptom: A stuck throttle position sensor is detected.
Fault Code: 19
Diagnostic Code: 20
Symptom: Open circuit in the input line of ECU No4 terminal is detected when the start switch is pressed.
Fault Code: 21
Diagnostic Code: 06
Symptom: Coolant temperature sensor-open or short circuit detected.
Probable cause of malfunction: Open or short circuit in wiring harness.
Defective coolant temperature sensor.
Malfunction in ECU.
Improperly installed sensor.
Fault Code: 22
Diagnostic Code: 05
Symptom: Intake air temperature sensor-open or short circuit detected.
Defective intake temperature sensor.
Malfunction in ECU.
Fault Code: 30
Diagnostic Code: 08
Symptom: The motorcycle has overturned. Probable cause of malfunction:
Overturned.
Malfunction in ECU.
Fault Code: 33
Diagnostic Code: 30
Symptom: Open circuit is detected in the primary lead of the ignition coil (# 1, #4).
Probable cause of malfunction: Open circuit in wiring harness.
Malfunction in ignition coil.
Malfunction in ECU.
Malfunction in a component of ignition cut-off circuit system.
Fault Code: 34
Diagnostic Code: 31
Symptom: Open circuit is detected in the primary lead of the ignition coil (# 2, #3).
Malfunction in ECU.
Fault Code: 41
Diagnostic Code: 08
Symptom: Lean angle cut-off switch-open or short circuit detected.
Defective lean angle cut-off switch.
Malfunction in ECU.
Fault Code: 42
Diagnostic Code: 07, 21
Symptom: No normal signals are received from the speed sensor; or, an open or
short circuit is detected in the neutral switch.
Defective speed sensor.
Malfunction in vehicle speed sensor detected unit.
Defective neutral switch.
Malfunction in the engine side of the neutral switch.
Malfunction in ECU.
Fault Code: 43
Diagnostic Code: 09
Symptom: Supply power to the injector and fuel pump is not normal
Probable cause of malfunction: Open circuit in wiring harness. (red/blue line or blue/yellow line)
Malfunction in ECU.
Fault Code: 44
Diagnostic Code: 60
Symptom: An error is detected while reading or writing on EEPROM.
Probable cause of malfunction: Malfunction in ECU. (The CO adjustment value is not properly written on or read from the internal memory).
Fault Code: 46
Diagnostic Code: --
Symptom: Power supply to the FI system is not normal. Probable cause of malfunction:
Malfunction in "CHARGING SYSTEM".
Fault code: 50
Diagnostic Code: --
Symptom: Faulty ECU memory. When this malfunction is detected, the code
number might not appear on the meter.
Probable cause of malfunction: Malfunction in ECU. (The program and data are not
properly written on or read from the internal memory.)
Fault code: Er-1
Diagnostic Code: --
Symptom: No signals are received from the ECU.
Probable cause of malfunction: Open or short circuit in wiring sub lead.
Malfunction in meter.
Malfunction in ECU.
Fault code: Er-2
Diagnostic Code: --
Symptom: No signals are received from the ECU within the specified duration.
Probable cause of malfunction: Improper connection in wiring sub lead.
Malfunction in ECU.
Fault code: Er-3
Diagnostic Code: --
Symptom: Data from the ECU cannot be received correctly.
Malfunction in ECU.
Fault code: Er-4
Diagnostic Code: --
Symptom: Non-registered data has been received from the meter.
Malfunction in ECU.
Feb 23, 2010 | 2005 Yamaha FZ6
Battery voltage not known for UPS-DELTEC PRR 2200i
It uses 4x12v @ 26AH batteries in series, making a total of 48v (more like 52v if charged).
Jan 19, 2009 | Compaq UPS T2200 XR UPS System
Battery voltage not known for DELTEC PRR 2200
For deltec PRR2200i you got 4 pcs of 12 volts batteries and it was just connected in series
CODE 07 10 43 61074 FOR WC C2424
That is a print head positioning fault.
Normally caused by 2 things. One or the other.
There is a stainless steel pivit block on the lower left side of the frame. It gets spill over ink in it and the print head does not move properly.
The Print head wiper also sticks ot the print head due to improper shut down or a power failuer
Aug 20, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
