Question about GE Spacemaker JVM1640SJ Microwave Oven
Cleaning the vent
The hidden vent of my spackemaker microwave oven is dirty and i am not sure of how to clean it, i have cleaned the reusable filter and the like but the hidden vent itself when it opens it is dirty and i am trying to figure out how to clean the dust and grime that is in there any ideas?
    Guru:
  • 859 Answers
One trick is to put a Pyrex bowl of water and let that boil for a few minutes or so. This gives the water vapors a chance to collect and exhaust dirt and dust from the vent passage way.
Worldvet
Posted on May 25, 2008
How to set it to high, med or low
Grease filters can be cleaned, according to your manual.
If you've misplaced yours, it's online here.
Charcoal filters cannot be cleaned and must be repaired.
From the manual:
Reusable Grease Filters
The reusable grease filters should be cleaned at
least once a month. Never operate the
microwave without the filters in place. In
situations where flaming might occur on
surfaces below the hood, filters will stop the
entry of flames into the unit.
To Remove Grease Filter
To remove grease filter, grasp the “finger hold”
on the filter and slide to the rear. Then pull filter
downward and to the front. The filter will drop
out.
To clean Grease Filter
To clean grease filters, soak and then agitate
filter in solution of hot water and detergent. Do
not use ammonia or ammonia products because
they will darken the metal. Light brushing can
be used to remove embedded dirt. Rinse, shake
and remove moisture before replacing.
To Replace Grease Filter
To replace grease filter, slide the filter in the
frame slot on the back of the opening. Pull filter
upward and to the front to lock into place.
May 27, 2010 | Microwave Ovens
Why double filter on Maytag Microwave
If your range hood or microwave recirculates back in to the room.
Both filters are required. The mesh filter catches the grease & air particulate. The carbon filter should be changed regularly www.HoodFilterFactory.com ( avoid range fires that spread quickly) & clears the recirculated air from smoke,odors, & airborne particulate.
With yours venting to the outside, you ONLY need the mesh filter. These filters should be cleaned regularly ( Avoid mentioned hazard) & should be replaced when you can no longer clean them enough to see through them when holding up to the light.
Good Luck
Apr 30, 2010 | Maytag MMV4205 Microwave Oven
Steam gets in the door and how can we clean and prevent?
This is usually due to incomplete venting or impaired air flow.
Assuming your hood vent exhaust fan is running properly, be sure your grease filter is clean (or if you use a charcoal type, it must be replaced when dirty) and be sure the exhaust ductwork and outside flapper are all clear.
I recommend that you always run the hood vent exhaust fan whenever you are cooking on the stovetop, too.
You can find links to helpful exploded view diagrams and part ordering help here. You can get new filters there, too.
I recommend that you bookmark that link to your favorites.
Jan 09, 2010 | Amana Radarange Microwave Oven
Oven is installed not outside vented. There is
It could be that the filter elements are clogged and need to be cleaned. Remove then from the underside of the micro hood and clean them using a good quality cleaner, such as Simple Green. Clean and allow to air dry before reinstalling.
While the filter elements are out, you can check for obstructions and run the fan to see if it is better without the filters installed.
If there is no noticeable increase in the air flow, it is possible that the exhaust vent baffle was not installed correctly, when the mircrowave was first installed.
Hope you found this Very Helpful and best regards!
Aug 18, 2009 | GE Advantium 120 Convection/Microwave Oven
My spacemaker keep dripping grease on my wall, what should I clean?
I would suspect a clogged grease filter (which can be cleaned) and/or charcoal filter (which cannot be cleaned and must be replaced).
You can download GE owner's manuals and installation instructions here.
The manual will give you the details.
Also be sure the hood vent exhaust fan is working correctly.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jun 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidaire plmv169dcd not venting properly. Filters are clean.
If it's equipped with a charcoal filter, that needs to be changed (not cleaned) about every 6-12 months, depending on use.
I would also very the installation and venting set up found in the installation instructions.
You can download Electrolux/Frigidaire owner's manuals and installation instructions here.
If all that is proper, then I would suspect an obstruction such as an animal nest in the vent outlet or in the duct work.
Feb 14, 2009 | Whirlpool GH7145XF Microwave Oven
Recirculating over the range micro does not take care of steam
Mayny reason. Does it vent outside? If not you are not getting a great amount of air flow. Are you filters clean? Dirty filters will stop max air movement. These are not the best machines for moving air but they sure are great spacemakers. Not sure if this can be fixed by any means other than a true vent hood.
Jan 26, 2009 | Maytag MMV4205 Microwave Oven
How to clean the air filter of my goldstar microwave model # MV1526B/01
That sounds like the charcoal filter. It cannot be cleaned, and must be replaced. From the owner's manual:
CHARCOAL FILTER REPLACEMENT
If your oven is vented inside, the charcoal filter should
be replaced every 6 to 12 months, and more often if
necessary. The charcoal filter cannot be cleaned.
To order a new charcoal filter, contact the Service
Center.
1. Remove the two vent grille mounting screws.
(2 middle screws)
2. Tip the grille forward, then lift it out
To get a new filter, you can try local appliance parts stores or see customer service or find servicers here: http://us.lgservice.com
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 13, 2008 | Goldstar MV-1526 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
255 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
