Question about Samsung HLM5065W 50" Rear Projection HDTV-Ready Television
Lamp and heat light blink - Samsung HLM5065W 50" Rear Projection HDTV-Ready Television
  • 130 Answers
Hi there
you have a fan problem close to the lamp
could be jam
Posted on Sep 30, 2010
How do I fix 62HM15 picture. Have sound-No Picture. Have red light steady and Green light blinks 8 times and cuts off and back on.
Usually 8 flashes means the lamp is not lighting.
When most lamps go bad , they physically crack because of excess heat.
The problem is probably the lamp or the ballast, which makes the voltage to light the lamp.
Replace lamp and remember to close the lamp access door after replacing, because the lamp will not light if the door is open an
Jan 23, 2015 | Toshiba 62HM15 62" Television
Sharp ar-501 Code H3-00
Heat roller abnormally high
temperThermistor defect
MCU PWB defect
Fusing connector connection failure
Power supply failure
atureCheck the heater lamp blinking
with SIM 5-2.
When the lamp blinks normally:
Check the thermistor and the
harness. Check the MCU PWB
thermistor input circuit.
When the lamp lights up instead
of blinking:
Check the lamp control circuit of
the power supply PWB and the
MCU PWB.
Clear the trouble with SIM 14
Jun 18, 2014 | Sharp AR-5316 Advanced Digital Imager...
Sharp m165 error h4-00 give solution
Heat roller abnormally low temperature
Check blinking of the heater lamp
with SIM 5-2.
harness.
Check the MCU PWB thermistor
input circuit.
When the lamp does not light:
Check for heater lamp
disconnection or thermostat
disconnection.
Check the interlock switch.
Check the power supply PWB
and MCU PWB lamp control
circuit.
Clear the trouble with SIM 14.
May 12, 2014 | Sharp AR-BC260 Color Copier
Al 1217 error code H3
temperature
with SIM 5-2.
of blinking:
MCU PWB.
May 07, 2014 | Sharp AL-1217 Copier
Red light blinks 3 times
Yes, there were and are known issues--"lamp door not properly closed" means that but something else.
What happens is door is warped from heat from lamp----with door off set will not function due to the safety switch----want to know if switch/door are the real problem?
Engage switch with something not metal and try to turn set on--if it and lamp come on do not look at lamp directly----do not operate with level bypassed and door removed as heat can warp the outer plate if no door.
If it comes on door is the problem---look at it edgewise---if warped a little the tab on back of door that engages the lever does not do its job.
If does not come on with lever engaged something else is wrong.
There was a recall that has ended regarding this---some were so bad they melted the lamp housing and even fused the front door of the lamp to the plastic around it.
Let me know what you find.
May 20, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Power light blinking and housing for lamp screws broken
I bet the area around the lamp shows signs of warping and/or cracking too? This is a VERY common issue as the fan that sits above the lamp gets clogged with dirt which allows the lamp to over heat which decreases the lamp life as well as distort the plastic casing around the lamp. The fix is a thermal fuse kit and a new fan and of course a good cleaning of the other fans in these TV's. This should be performed by a service technician.
Aug 31, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony LCD Projection TV turning OFF.....help!!!
Look carefully at the front lights. Usually when these sets shutdown they have a blink code on either the standby light or the lamp light. Update this with those counts. In the meantime, you may be seeing a problem with heat. If the lamp area gets too hot, the set will shutdown the lamp. Once the area is cool again, the lamp will fire.
Update this and we'll hopefully fix the both of them.
Dan
Apr 09, 2008 | Televison & Video
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Samsung HLM5065W 50" Rear Projection HDTV-Ready Television Logo
Henry  Thomas
Henry Thomas
