Question about Kenmore Dryers
Kenmore Electric Dryer HE2 model 110.8756 All the buttons work and can change cycles and time. Push the start button nothing happens, then hear a click.
exspert
  • 55 Answers
SOURCE: Dryer not turning on
ok " the timer has points that act like a switch , they get burt and will not work after a long time
replace time , it's just a plug in unit
Posted on Jan 21, 2008
lhendrix04
  • 11 Answers
SOURCE: Kenmore electric dryer won't start
DOOR SWITCH
Posted on Apr 20, 2009
Greg20
  • 149 Answers
SOURCE: kenmore he2 electric dryer error code f-01
always unplug for 10 minutes and retry first.
Posted on Jun 12, 2009
  • 16 Answers
SOURCE: model 110 86574120 how old?
its from 1985 first and third #s after the 110
Posted on Jun 27, 2009
  • 60 Answers
SOURCE: when I push the start button the dryer will not start
May need to replace the starter swithch behind the control panel. MAKE SURE ALL POWER IS DISCONNECTED. If you still hear a humming sound when you hit the start button then it is not the switch, but the motor and if that is the case you may want to look into your warranty.
Posted on Aug 16, 2009
Kenmore HE2 dryer will not start
the relay for the motor is probable stuck recommend service
Jun 03, 2010 | Kenmore 82822 Electric Dryer
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
My kenmore elite he4 dryer-model#110.95087401 keep beeping and the end of cycle lights are going on from off to high and back to off right through the drying cycle.
I had the same problem and eventually none of the cycle buttons light up or the cycle time display. So it would not run at all. After taking it apart once and fiddling with the cycle push buttons, it worked for one load then would not work again. I could see 3 of the led faintly illuminated and unplugging and plugging back in the power changed nothing. Then I removed the plastic ring of cycle buttons that is between the panel circuit board and the outer plastic. (There a several layers to get to the ring.) Now I use a long allen wrench to push on the switch on the circuit board. I left the middle start button in place. That does not seem to cause a problem. Several loads now and still working. So it looks like the ring on plastic buttons don't release from the circuit board buttons causing a problem.
Feb 21, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore he2 electric dryer error code f-01
Jun 12, 2009 | Kenmore 82822 Electric Dryer
New HE5t steam dryer will not turn on
What was wrong with your dryer? I am having that same problem?
Dec 27, 2008 | Kenmore Dryers
HE4 dryer push buttonfor any cycle nothing happens
When you push start does it make a click sound. If so you might have a broken belt, or it may have fallen off. Unplug the dryer. Take off the bottom panel via 3 screws. Reach inside or look with a flash light to make sure the belt is on and has tension. Hope that helps. Dave www.washermd.com
Dec 16, 2008 | Kenmore Elite HE4 Electric Dryer
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
First time use, not working
The door switch is not closed or the board is not sensing the door is closed.
Push in at the top of the door to make sure it is latched at the top.
This is a common problem on the HE4's that was not a problem with the HE3's. We are hearing from Kenmore and Whirlpool that a fix is coming, a different latch I think.
Even if pushing in at the top makes it work, call for service so the problem can be addressed.
Post back if you have any questions.
Nov 12, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
561 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
