Question about Samsung PN63B550 63 inch 1080p Plasma HDTV
Television has a blue rectangle in the middle of the screen towards the bottom that states "Check fan No. 3" How do I do that?
  • 130 Answers
Hi there
first cafully remove back cover and check these
fan located at top of your tv
Posted on Sep 30, 2010
Top, middle of screen there is a constant flicker. The flicker starts at the top, middle and goes about half way down the screen.
I have a blue line about 3/4 inch wide from the top right to the middle bottom. ( not a straight line ) I replced thr projection lamp with no fix to the problem. I added an additipnal fan and cleared up the problem. On furthe investigation I replaced the air filter and kept only the original fan and the problem was solved. Can you explain this.
Dec 06, 2009 | Zenith D52WLCD 52" Rear Projection...
Picture problems
check for cold solder joints around the flyback transformer and a open pico type fuse very close to it. they are rectangle in shape and ususually the one in the middle of the three is the culprit. The problem is in the pincushion circuit
Jan 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red Blue and Green colors are not aligned and looks concave
replace fuse looks like cap next to flyback transfomer FL231 it will be the one in the middle.there are 3 of them next to FBT.
May 28, 2008 | RCA D52W19 52" Rear Projection Television
Which part(s) to replace?
If the screen looks OK after extended cooling is provided, you may just have a failed cooling fan.
Turning the blade with the power off will tell you if the bearings have failed or stuck, or just look at it with a flashlight to see if it is turning.
Check this first before you start replacing boards.
May 05, 2008 | Samsung HCN4226W 42" Rear Projection...
Toshiba 50H72 Rear Projection Television
You will need to replace both convergence ICs they are STK392-110 you can get replacement ICs at the following link and they will provide free instalation instructions with pics and also free on line tech support so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
May 04, 2008 | Toshiba 50H82 50" Rear Projection...
Water look at the bottom of screen
Probable bad Optical block Assy. part # A-1606-008-A
at cost.....750.00 + 600.00 core............................T.
Dec 17, 2006 | Sony Grand WEGA KF50WE610 50" Rear...
Picture Distortion
you have a convergence problem.. If you understand how this works then you can go into the set find the convergence ic's and replace them and sometimes you need to do some alighnment as well. Its always best though to let a service tech do a job like this as he will have all the proper equipment to adjust and troubleshoot the set Good luck
Mar 30, 2006 | Sony KP-53HS30 53" Rear Projection...
Samsung PN63B550 63 inch 1080p Plasma HDTV Logo
132 people viewed this question
Henry  Thomas
Henry Thomas
