Question about EliteGroup ECS P4VXASD2 VIA P4X266A Chipset Ultra ATA100 MATX CPU Type: Intel Pentium 4 478-Pin (59815) Motherboard
AMI 686-HiFlex-Bios V11.25 Can this bios chip be
AMI 686-HiFlex-Bios V11.25 Can this bios chip be flashed for a Pentium 4 1800.0 MHz cpu ???
  • 12,061 Answers
Hi, I have investigated your issue and the short answer is NO. It is unlikely that it would be the BIOS chip itself.
However in saying that, there is NO reason why you could not try to replace this IC, with another to prove or disprove weather it is or not. (Providing you can actually replace it, by unsoldering, difficult, or if it is in a socket, then it is easy.
You can get a replacement BIOS from BIOS Man. link below. There are other BIOS replacement websites to help as well.
http://www.biosman.com/replacement.htm
However one cannot flash a BIOS for another CPU, UNLESS the manufacturer has already written a BIOS to include that particular CPU. and the MB will already work with the CPU you wish to use.
ALL BIOS's will support most standard CPU's though. So if your MB would already support this CPU in it's original mode, then YES you could reflash the BIOS and it will work. Otherwise NO.
It is most likely best though to obtain a MB and BIOS that already supports the desired CPU.
Posted on Sep 30, 2010
Soyo Tech aid response 2A: "different BUSes" on 1999 AMI Bios on ECS P4800 Pro-M VI.0A pc motherboard.Won't boot but stops. How to fix?
Visit http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=574&LanID=9
and compare that is your BIOS updated ? If not, I suggest first update your BIOS to the latest version and see if error is removed ? Try Load Optimal Settings of BIOS. If fail, then try resetting the BIOS. If you have install anything new, try to boot by removing the new device. I suggest from the above URL, you can download the manual of the mother board. I hope trying these steps will remove your problem.
Feb 11, 2016 | Intel PENTIUM-4 FSB800 Mother Board with...
Hi, I need standard spec info of VGA built on Asus P5GC-MX 1333 whether 64 Mb or 128 Mb. Many thanks & regards, Richard
you can use up to a maximum of 224 mb of your computer's RAM for the onboard video chip to use. You can install a video card with any amount of memory (which would give you a lot better video performance).
Jun 18, 2011 | ASUS P5GC-MX 1333 BULK C2D LGA775 945GC...
Vga 686 AMI bios
Hello here is the homepage:
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?DetailID=248&CategoryID=1&DetailName=Feature&MenuID=49&LanID=0
Don`t upgrade the bios, unless you are 100% sure, it`s the right mainboard.
Any drivers missing ??
Good luck
May 16, 2011 | PC Chips (M791G) Motherboard
Upgrade PCChips M925
According to PCChips, the maximum CPU & memory supported for all three is the Intel P4 Northwood (HT) 3.06 GHz 512K,533FSB,Socket 478 and 2GB (2 x 1GB) DDR 266.
Be sure you have the latest BIOS version for your motherbaord.
M925ALU (V7.3) must have BIOS : 030703s
M925G (V8.0) and M925G (V9.1b) must have BIOS : 050510s
Hope this helps you out.
Jan 09, 2010 | PC Chips (M925G) Motherboard
Gigabyte Motherboard wont flash bios
your bios has been corrupted.
The AWARD BIOS has a similar procedure to AMI. To recover an AWARD BIOS you will need to create a bootable floppy diskette and add the desired BIOS file (we recommend using the most recent). Award BIOS's generally are in .BIN format, where as AMI was .ROM format. You will also add an AWARD flash utility (usually awdflash.exe) and an AUTOEXEC.BAT file.
The AWARD BIOS does not automatically restore the BIOS information to the 'system block' like the AMI BIOS does. You will need to add the commands necessary to flash the BIOS in the AUTOEXEC.BAT file. The system will run the AUTOEXEC.BAT file, which contains the flash instructions.
Note: 12345678.BIN represents the name of your BIOS.
Step by Step:
1. Create a bootable floppy diskette or bootable dos cd /usb drive
2. Copy the BIOS file and flash utility to the disk
3. Create an text file with any standard text editor and add the following lines
@ECHO OFF
awdflash 12345678.BIN /py/sn/f/cc/r
Exchange the awdflash with the name of whatever flash utility you are using, and replace the 12345678.BIN with the name of the BIOS file you are using. The parameters are explained here:
py = program yes
sn = save no
f = flash
cc = clear cmos
r = reboot
Remove disk and restart computer
If you found this useful , please rate below
Kind Regards
1234s282
Jul 02, 2009 | Intel Gigabyte GA-8S648FX-RZ Socket 478...
Wndows vista
All the drivers for that motherboard can be download from the official site at http://www.asrock.com/mb/download.asp?Model=Wolfdale1333-GLAN/M&s=775
Good luck
Jun 20, 2009 | Computers & Internet
Overclocking a CPU Type Intel Pentium IIIE, 581 MHz
If you have an adjustment for the VCORE voltage in your bios, bring it up by one value, then try overclocking the CPU.
Apr 20, 2009 | QDI Group QDI Advance 10T Motherboard
I have so fat
Here the Infos about your mainboard:
ASUS P5S800-VM Allgemein MPN: 90-MBL0K0-G0EAYZ, P5S800-VM
Produkttyp: Motherboard
Formfaktor: Mikro-ATX
Breite: 24.5 cm
Tiefe: 24.5 cm
Kompatible Prozessoren: Pentium 4, Celeron D
Prozessorsockel: LGA775 Socket
Chipsatz: SiS661FX / SiS964
Maximale Busgeschwindigkeit: 800 MHz
BIOS-Typ: AMI
Storage Controller: ATA-133, Serial ATA-150 (RAID)
Prozessor Installierte Anz. (max. unterstützte Geräte): 0 ( 1 )
Speicher Unterstützte RAM-Technologie: DDR SDRAM
Installierter RAM (Max.): 0 MB / 2 GB (Max)
Unterstützte RAM-Geschwindigkeit: PC2100, PC2700, PC3200
Video Grafik-Controller: SiS Mirage
Videospeicher: Shared Video Memory (UMA)
Audio Audioausgang: Soundkarte
Signalprozessor: SiS964
Audio Codec: Realtek ALC655
Soundmodus: 5.1 Channel Surround
Kompatibilität: AC '97
Telekommunikation / netzwerk Netzwerk: Netzwerkkarte - Ethernet, Fast Ethernet
Besonderheiten BIOS-Funktionen: Wiederherstellung nach Stromausfall (Wiederaufnahme bei Verlust der Wechselspannung), DMI 2.0-Unterstützung, WfM 2.0-Unterstützung, ASUS MyLogo2, SMBIOS 2.3-Unterstützung, ASUS EZ Flash, Hyper-Threading-Technologie, RAID-Unterstützung, DMI 2.0-Unterstützung, WfM 2.0-Unterstützung, ASUS MyLogo2, SMBIOS 2.3-Unterstützung, ASUS EZ Flash
Sleep / Wake up: Wake-On-LAN (WOL), Wake on Ring (WOR)
Hardwarefeatures: ASUS Instant Music Lite, Chassis Intrusion Detection, ASUS Q-Fan, C.P.R. (CPU Parameter Recall), CrashFree BIOS 2, Jack Retasking, ASUS Instant Music Lite, Chassis Intrusion Detection, ASUS Q-Fan, C.P.R. (CPU Parameter Recall), CrashFree BIOS 2
Produktbeschreibung des Herstellers Das P5S800-VM unterstützt die neuesten Intel Pentium 4 LGA775 Prozessoren. Mit 800Mhz FSB, 1MB L2 Cache, Hyper-Threading Technologie und Spitzenleistungen von 3.6GHz und mehr ist der LGA775 Pentium 4 einer der schnellsten Desktop Prozessoren, die es zur Zeit gibt.
Dec 31, 2008 | ASUS P5S800-VM Motherboard
I want my display drver
http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=1704&areaid=2&LanID=0
thats the driver for the intergraded video on a ecs P4VMM2 motherboard
Driver Name : S3 ProSavage Display Driver P4M266_KM266-P
Nov 27, 2008 | Computers & Internet
Need help with my laptop
Did you laptop come with a RESTORE CD or DVD?
Look for the application on the media that came with the laptop.
You can also get it online
ONLY for AMI BIOS and Windows NT 4.0.
ftp://ftp.necam.com/pub/Catalog/3620/HDPrepNT.exe
HDPrepEZ version 1.9 for AMI BIOS. Supports FAT32 partitions.
Windows 95, Windows 98
ftp://ftp.necam.com/pub/Catalog/3646/Hdprepez19.exe
This is the page with all support downloads for your LapTop:
http://support.necam.com/downloads/
Select you type / make / model and you will have access to all service releases.
Hope it helped.
Mar 03, 2008 | NEC Versa SX Notebook
EliteGroup ECS P4VXASD2 VIA P4X266A Chipset Ultra ATA100 MATX CPU Type: Intel Pentium 4 478-Pin (59815) Motherboard Logo
319 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
