Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
Error code F1 - Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
  • 552 Answers
the link below is a video that explains how to fix this issue.
the main control has failed and needs to be replaced.
http://www.appliancerepairlesson.com/2011/02/23/cabrio-bravos-oasis-f1-error-washer-repair/
Posted on Mar 06, 2011
  • 15,935 Answers
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((((**))))
Posted on Sep 30, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Tip
    Troubleshooting KitchenAid oven, range and microwave error codes
    Here list of Kitchen Aid range and oven codes.
    F1 - E0 EEPROM communication error
    F1 - E1 EEPROM checksum error
    F1 - E2 UL A/D error
    F1 - E4 Model ID error
    F1 - E5 Calibration shifted
    F1 - E6 Latch signal mismatch error
    F1 - E9 Stack overflow
    F1 - E3 Wiring harness cavity size does not match stored value
    F2 - E0 Shorted touch pad
    F2 - E1 Keypad cable connection error
    F2 - E5 Cancel key drive line open
    F2 - E6 Cancel key drive line open
    F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
    F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
    F3 - E2 Oven temperature is too high (Cook mode)
    F3 - E3 Oven temperature is too high (Clean mode)
    F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
    F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
    F3 - E6 Drawer sensor open
    F3 - E7 Warming drawer sensor shorted
    F4 - E1 Meat probe malfunction - shorted
    F5 - E0 Door Switch
    F5 - E1 Self clean latch will not lock
    F5 - E2 Latch during CLEAN error
    F5 - E5 Self clean temperature not reached within 45 minutes.
    F5 - E6 Door is open, but latch is locked
    F5 - E7 Self clean latch will not unlock
    F6 - E0 Return line not connected
    F7 - E1 Common switch wire defective
    Two digit codes:
    F0 ERC Board failure
    F1 ERC Board failure
    F2 Oven temperature is too high
    F3 Oven temperature sensor open
    F4 Oven temperature sensor shorted
    F5 ERC Board failure
    F7 Function key stuck on ERC
    F8 ERC Board failure
    F9 Oven door lock failure
    Microwave and Microwave combo error codes:
    F1 - E3 or F1 - E4 Electronic control malfunction
    F2 - E0 or F2 - E1 Keypad connection error
    F2 - E3 Keypad held down too long, or keypad is shorted.
    If you get an error code, try first resetting the code:
    1. Disconnect power for about two minutes.
    2. Connect back power.
    3. If code re-appears, test and eventually replace faulty part.
    on Apr 24, 2015 | Kitchen Ranges
    Tip
    F5 - E0 Door Switch
    Two digit codes:
    Regards.
    on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
    What is the error mean f1 E1 on my may tag front loader washing machine
    Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    have E1 and F1 error code fleshing and wate Sears PartsDirect
    http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
    Appliance Repair Forums
    Error code F1E1 null ShopYourWay
    Central Control Unit CCU Maytag MHW6000XW Washer
    Mar 07, 2016 | Washing Machines
    Fix f5 e 1
    F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
    2. Re-apply power and observe for at least one minute.
    3. If code re-appears, replace control board (also called ERC or clock).
    Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
    Jun 05, 2015 | KitchenAid Architect II Superba EQ Series...
    What causes error code F1 in my Electrolux convection microwave EI303BM60MS?
    Thank you for your inquiry, Leanne!
    From the information you have provided your Electrolux microwave is displaying an error code of "F1". I am showing that an "F1" error code is not valid. I would recommend resetting your microwave and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not correct your issue and you continue to experience an "F1" code please reconnect. -Matt
    Apr 27, 2015 | Electrolux Microwave Ovens
    What does F1 fault code mean?
    Whirlpool Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
    Jan 08, 2010 | Kitchen Ranges
    66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
    Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
    KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
    F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
    KENMORE - 911 Series (General Electric/Roper)
    F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
    KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
    F1-E0 EPROM Error - Electronic Range Control (ERC).
    F1-E1 EPROM Error - Electronic Range Control (ERC).
    F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
    F1-E3 Fuel Type Fail
    Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
    “9” for gas-If code changes again-replace Electronic Range Control (ERC).
    KENMORE - 790 Series Electronic Oven Control (Frigidaire)
    F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
    Runaway Temp = Replace Electronic Oven Control (EOC).
    Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
    Thanks
    Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
    KitchenAid KESS907 Electric Range E1 F1 Error Code
    F1 E1, replace Electronic Range Control.
    In other words, the controller board has failed.
    Jan 29, 2009 | KitchenAid KDRS807SSS Dual Fuel (Electric...
    Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
    330 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
